Question about Gateway One ZX4970G-UW308 All-In-One Desktop PC with Intel Pentium
How do i remove the back leg stand to mount onto wall?
  • Gateway Master
  • 2,072 Answers
Usually you will have to remove the back panel or part of it and there should be screws underneath.
Posted on May 14, 2014
I need 1 leg of a stand for a Philips BDL 4231 TV. One of our legs snapped when moving the tv and we don't want to wall mount it. \r\nThanks, AOM
Electronics stores do not stock extra stands for TVs. Each TV comes with one stand and that stand goes with the TV.
If you contact Philips directly you may be able to purchase a stand on it's own, but this isn't likely if your TV is over a few years old.
Check ebay and see if anything is available in your area, if not, you may be limited to purchasing a hybrid stand to mount on or wall mounting.
Mar 15, 2011 | Philips BDL4231C LCD TV
I have a 42 in. Vizio Galleria and need to remove table top stand so I can wall mount. How do I remove base stand?
1. Unplug all of the cables and cords from your GV42L FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and flat surface (blanket, foam, cloth, etc) to prevent any damage to the TV.
3. Pull the stand cover off by squeezing the sides to release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws (screw's specs: M4, 0.7 Pitch, 15mm long) so that the stand base can be removed.
5. Gently remove the stand base
6. Now, the GV42L FHDTV10A can fit securely to a mount (sold separately) by utilizing the mounting holes in the center of the back panel of the TV. Please make sure to read the instructions of your specific mount to properly hang the GV42L FHDTV10A
Mar 13, 2011 | Vizio Gallevia GV42LF 42 in. LCD...
Im having trouble removing the base stand, I'm trying to mount it on the wall. I removed the 4 screws on the bottom but cant get the metal legs off.
Generally the stand is screwed on from the back of the TV. there should be 4 screws that will come out all the way and allow for the stand to be removed
Mar 13, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
I want to wall mount a FX2490HD and cannot remove the base I have remove the screw form the back but the base will not move
Hi, there are two screws underneath the legs of the stand and one other screw to hold the attachment that the legs connect to. If you have removed all three screws then try swiveling the legs.
Feb 12, 2011 | Samsung Televison & Video
Needing to wall mount a samsung 19in tv how is the leg part of the stand removed
It depends how the stand is attached to the TV, model number? Try downloading manual from www.tv.manualsonline.com
Nov 01, 2009 | Televison & Video
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
How can i take the bottom stand of my monitor before i mount it t
Generally speaking, LCD monitors have a plastic cover that snaps onto the back side which covers the hinge and screws holding the base plate 'post' to the monitor. Remove the cover, and remove the screws. The post that engages the base plate will come off with the hinge intact.
tom
Dec 21, 2008 | Hyundai Computers & Internet
Mounting an Acer AL2416 to the wall
Hello Poet,
I recently purchased two of the Acer AL2416W to mount onto a monitor stand. I ran into the same problem, it looks as though you have to remove the entire rear of the Monitor to take the factory leg off. I believe I was trying to make it too complex, just gently pry the rear cover off of the hinge this will expose 4 screws remove these and you are all set.
Mark
Jul 02, 2008 | Acer AL2416W 24 in. LCD Television
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Gateway One ZX4970G-UW308 All-In-One Desktop PC with Intel Pentium Logo
73 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
