Question about Sony Playstation 3 (PS3) Console
My ps3 will not work with the component cables is their a fix?
Component cables not working
  • 552 Answers
4 Suggested Answers
PiratedFixer
  • 27 Answers
SOURCE: Component Cable problem
Ok there can be a quick solution to this problem if you have ever used a hdmi cable this could have caused the problem. try to do a front reset turn off the ps3 with the switch in the back then hold the front power on switch while still holding it turn on the back switch stll hold it and wait till it beeps twice on the second beep release this should sole the problem. if not reply back.
Posted on Jan 26, 2009
scrodamoon
  • 659 Answers
SOURCE: ps3?
Check the couplings at either end of the cable. Sometimes these will loosen and can cause a lack of signal strength.
but its probably not the cable, its probably the ps3. HDMI cables don't really break because they are just wires, they don't have moving parts. Try connecting your PS3 to your TV with the regular cable red, white, and yellow connectors that you got when you bough the PS3. If the PS3 doesn't work with the original red, white, and yellow connectors then you know its the PS3. If the PS3 does work fine, you know its either the HDMI cable (still unlikely) or the HDMI connection on your TV or PS3 (more likely
Posted on Oct 12, 2008
rommelalilin
  • 2178 Answers
SOURCE: My ps3 will not work
AV is composite, not component. Check the output settings and select component.
Posted on Feb 07, 2011
My playstation 3 will not play in 1080p. It used to work, but when we switched cables, it wont work in HD.
When you switched cables, you mean you changed the cord running from the PS3 to the TV? HD content requires an HDMI connection from the PS3 to the TV. It is possible that when you changed cables, you replaced the PS3's HDMI cable with Component Cables which can only deliver in Standard Definition and not in High Definition (720p, 1080i and 1080p).
HDMI:
http://www.playstation3hdmicable.com/images/hdmi2.jpg
Component: http://www.componentcable.net/images/Component%20Cable%20PS3.jpg
Apr 29, 2011 | Sony Playstation 3 (PS3) Console
When I turn my ps3 on I get no video on my tv and I just bought the wire so its not the wire... How can I fix this?
Obviously, first make sure the PS3 and television/projector are actually on. Then confirm the television actually works, and that the port you're connecting to on the TV works (connect another console, for example).
You should then make sure all cords are firmly attached to the PS3 and you television.
If the cables are snugly in place and you still have the issue, you should make sure the PS3 is outputting the correct video. To do this, power off your system, then press the power button to turn it on, but keep it held down for a couple of seconds (around 5 seconds I believe). It should beep and your video settings will be reset.
Still nothing? Make sure the cables are working. Swap them out with cables you know that work, or test the cables in question on something else (another PS3 or old PS2 for the regular cable, anything that has HDMI out for the HDMI cable). I know you said it's not the wire but you should confirm it because the next solutions are kind of a last resort...
You might have to send it in to Sony, which can be done here. They take forever to send it back though, and if you're out of warranty it costs $150 (it's free if you're under warranty though!).
Alternatively, if you're awesome and feeling adventurous, you can fix it yourself. Here's a guide, and more can be found online.
Regardless, hope everything works out!
Mar 23, 2011 | Sony Playstation 3 (PS3) Console
Tried to hook up ps3 to a different, older tv. was hooked up with hdmi cable and optical audio cable. bought a component cable that works with the ps3. I can't get a picture or sound. or anything else. ...
HDMI is a digital signal, so your TV and your PS3 are basically talking to each other over the connection at all times. That's why when you plug an HDMI connection into your PS3, it can detect the connection and try to switch right to it. Component cables don't work the same way, they only output information, so it's a one way street. Your PS3 is still outputting information, but it still thinks it needs to output to the HDMI port. The fix is pretty simple, and there are two options.
The Long Way
  1. Plug your PS3 into an HDMI TV.
  2. Change the Audio settings first, so your console outputs audio to a Component source.
  3. Now change the Video settings last, so the PS3 is outputting to a Component source as well.
  4. Your screen should go blank once you do this. Hit the X button once, wait a moment, then use the power button on the front of the PS3 and turn it off.
Now just plug the PS3 into the other old TV with the Component cables, and turn it on. You should have picture and sound now.
The Short Way
  1. Leave the PS3 plugged into the old TV, and turn it off with the front power button. Once the light has turned Red, hold the power button down for at least 5 seconds. Don't let go until you should hear the system beep twice.
Now you should be able to use your PS3 on the older TV without a problem.
The Short Way is a simple reset of your video card, it causes the PS3 to revert to outputting to it's out-of-box settings. If neither of these ways worked, check here at the Sony website, and one of those solutions may better fit you, but it sounds like one of the two solutions above should solve it.
Please leave a comment or rating letting me know if this solved your problem, constructive feedback is always welcome. Good luck with your console and good luck with your games.
Dec 29, 2010 | Sony Playstation 3 (PS3) Console
Sony Surround Sound, LG TV and PS3 connection problems
sounds like you are going to have to get the component cables for the PS3, you can get them on amazon, the only thing about the component cables is that the quality cant go as high as the HDMI cable but its close. but thats the only way i can tell you to have surround sound with your PS3
May 09, 2009 | Sony Playstation 3 (PS3) Console
Sound but no picture on PS3 using AV3/4
if it's happening with your ps2 and your ps3 on teh same tv, try it on a different tv. if you're getting sound but no picture, tehn it's something with your cables or your tv. restting the display setting should get your picture back up. make sure the system is in standby and then hold down teh power button. it will turn green and beep, then flash green and beep again. it should brng up a picture. if not, check your component cables, especailly if it works with the original cables.
Apr 06, 2009 | Sony PlayStation 3 40GB System
the best configuration is using component AudioVideo cable.component video out from ps3 use 3 wires going to component video input to your tv (Y-Pb-Pr) and two wires for audio left.right. use av1 input on your tv to hook the audio and video. let me know if you still have issue.
Apr 05, 2009 | Philips Televison & Video
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
Ps3?
Oct 12, 2008 | Sony Playstation 3 (PS3) Console
Ps3
not really sure what happened, but if you put the component cables back in the tv, making sure the ps3 is in stand by, then as switching it on hold the power button for about 5 seconds, it runs the optimal screen settings page, and should auto select the best option for the cables fitted, if this does not work , then do all of that again but with original cables fitted and it should be back to original settings(how it came out the box) hope this helps
May 30, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
