How do connect my midi keyboard straight into my x1222 mixer
  • 549 Answers
Here is the link to Behringer website. This is where you can either email or call to get support and they will tell you how to connect. BEHRINGER Warranty and Service Information
Posted on May 13, 2014
Where do you connect a midi controller on a Behringer Xenyx 1204usb mixer?
You can connect where it is possible. I hope you will understand.
Aug 04, 2016 | Behringer Music
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
I want to record from my Korg M50 to Cubase LE4 on my laptop.
Hello, To record into a lap top you will need a USB mixer, your audio output from the SYNTH will go into the mixer, you use the midi USB cable from the mixer to the lap top. this will help pre amplify your synth to normal audio levels. hope this helps.
Feb 17, 2014 | Korg M50 61-Key Music Workstation Keyboard...
Midi problem
i think this problem is related with the power of the mixer, see the guide of that mixer and learn how to connect it on right way.
good luck
Feb 17, 2013 | Computers & Internet
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
How do i fix the humming noise from my mixer to my computer?
Hi Joe, you probably need something to remove the ground hum, like this http://www.maplin.co.uk/Module.aspx?ModuleNo=33172
hope this helps
Mar 15, 2009 | Mackie Tapco Link.MIDI 4x4 (663961007992)
Sound module & mic (connected to a Tascam US-224) not working
I may be able to help.  I am a longtime Mac and Tascam control surface user.  I am currently running a MacBook Core 2 Duo 2.0GHz running OS 10.5.6 with a Tascam FW-1884 audio interface/mixer/control surface connected.
Setup is fairly easy in the Mac OS.  Here are the steps I'd follow:
NOTE: Before beginning the following process make sure that ALL of your MIDI gear is connected.
- Tascam connected to USB port of computer
- MIDI Keyboard "OUT" connected to Tascam "IN"
- Roland "IN" connected to Tascam "OUT"
1) Open your "Applications" folder.
2) Open the "Utilities" folder.
3) Double-click on "Audio MIDI Setup."
4) At the top of the window select "MIDI Devices"
5) In the pull-down menu on the left select "New Configuration."
6) Title your configuration and press "OK"
7) If your gear has been detected automatically their names and icons should appear in the main window.  If so, skip down to step 12
8) Click on the "Add Device" button
9) Double-click on the "new external device" button that has now been created.
10) Select your device's manufacturer and model (i.e. Roland, JV-1010).
11) Adjust any other settings appropriate to your setup.
[In the main window there should be a Tascam US-224 button.  On it there should be one pair of arrows that indicate the MIDI In and MIDI Out ports of the device.]
12) Click (and hold) on the MIDI Out arrow of the US-224 button.
13) Drag the "cord" and attach it to the MIDI In of the Roland JV-1010 button.
13) Click (and hold) on the MIDI In arrow of the US-224 button.
14) Drag the "cord" and attach it to the MIDI Out of the "keyboard" button.
This should get you setup from a Mac OS/Device routing perspective.  For the appropriate US-224 Control Panel settings refer to the User Manual.
Feb 07, 2009 | Tascam US-224 DIGITAL AUDIO WORK STATION...
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Cakewalk software: Midi vs. Sound
You can get a music keyboard for around $200 and up.
http://www.zzounds.com/cat--2684
Or use it as is, with your computer keyboard. There should be a printable template on the disk, if not in the package.
Getting midi to register
Your question is very confusing. Try rephrasing it. You should try drawing a diagram with this and uploading it to your question to better explain yourself. If you can't upload it (I know I can through the answer, but I'm not so sure about the question) you can e-mail it to me. My address is johnkennick@yahoo.com , if not just put some more detail into the question and try rephrasing it. I'm not really sure about the details of your system.
Mar 12, 2008 | Tascam US-122 USB Audio/MIDI Interface...
 Grubhead
Grubhead
