Question about Philips HDD065 MP3 Player
Battery for GoGear HDD065/05
I'm not getting any power to my device. When I try to charge it up I only get a light flickering of light. I've been advised to try I new battery but can't find where to get on from on the web. Does anyone know where I can get a battery for the HDD065/05 model?
  • Anonymous Feb 12, 2008
    My Philips HDD065 MP3 player won't turn on at all, even when connected to a charging cable.
    Problem Solver:
  • 12 Answers
Hi, you can get a battery on ebay, there is another solution if you know someone with the same player. The player will not charge or start up if the battery gets too low. Borrow a friends player HDD 065 / 075. Remove their fully charged battery (make sure their player is off) and place it in your player. Switch on the player (should work now) and plug in the mains charger. Without turning the player off or unplugging the mains charger remove your friends battery and replace yours. Leave the player to charge the battery until full. This should solve your problem provided your battery is flat and not damaged. Do not place the flat battery in your friends player as this can cause problems if they have upgraded firmware.
Posted on Feb 29, 2008
It would probably be cheaper to buy a new one from ebay http://www.buyspares.co.uk/cgi-bin/product.pl?PID=1226951&query=Philips%20065
Posted on Nov 24, 2007
My headlights and some dash board lights are flickering. Its getting worse.
AS YOU STATE THE PROBLEM MIGHT BE ON THE ALTERNATOR AND MOST PROBABLY THE REGULATOR IS THE FAULT OR THE BRUSHES. THEREFOR YOU NEED THE HELP OF AN ELECTRICIAN TO TEST YOUR ALTERNATOR FOR CHARGING AND ALSO THE BATTERY CHARGING CAPACITY AND POWER LEFT THEREIN.
Oct 22, 2012 | 2005 Dodge Neon SXT
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
It will not turn on or charge
Hi, the Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
2. Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Hope it helps...
Have a nice day.
Feb 22, 2011 | Philips GOGEAR SA6045 MP3 Player
Batterylife,GoGear Vibe 4GB how long between each charge, getting 5 to 6 hours.
The battery life is rated at 25 hours for audio and 4 hours for video. If the charge is not holding you can try ensuring device is secured while charging. If this does not work the battery is bad and should be replaced. This is not horrible news, batteries for the GoGear Vibe 4GB are only $10.00.
Aug 05, 2010 | Philips GOGEAR SA6045 MP3 Player
Yellow light flickers 4 times when trying to turn
If you don't get the flickering lights when you try to boot up with the AC adapter hooked up but no battery, it sounds like the problem is most likely a bad power adapter. Your battery is dead, and that's why you get the flickering lights, but the AC adapter is bad so you can't use it to power the laptop or charge the battery.
You can typically get a new adapter for $20 or so, or maybe even cheaper on eBay.
May 29, 2010 | Toshiba Satelite A10 Notebook
My mp3 won't turn on is it broken?
PLEASE DON'T FORGET TO RATE !
Apr 18, 2010 | Philips GoGear SA5285/37 Digital Media...
My mp3 is fully charged and wont turn on no more and i cant no more music in it
Hello :
Apr 18, 2010 | Philips GoGear HDD075/17 MP3 Player
Wont stay turned on.
1) Make sure the usb charger is in the lock position before trying to charge.
2) Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
3) after repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
-Tha Mp3 Doctor
Feb 07, 2008 | Philips GoGear SA178 MP3 Player
Philips Gogear - please help!
Check that battery still has the original voltage if not you need to b=get it back to it.
Jun 13, 2006 | Philips GoGear HDD060 MP3 Player
PHILIPS GOGEAR HDD060 DOES NOT TURN ON
Here's a better solution - no offense, silly girl. First, find out if the computer will recognize the GoGear when you plug it in. If so, then use the Repair function in the Philips Device Manager.
If the computer doesn't recognize the player: Disconnect the GoGear from the computer, and turn the player off. Hold in the volume + button and continue to hold it as you re-plug the GoGear back into the computer. After 45 seconds to one minute, Windows will go into recovery mode and resucitate your player.
Also, the number for the Manufacturer - Philips - is
1-866-PHI-LIPS (or was it 1-888? - one of these is an adult line, the other is not) :-)
-Tha Mp3 Doctor
Apr 09, 2006 | Philips GoGear HDD060 MP3 Player
Philips HDD065 MP3 Player Logo
294 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
