Question about Briggs & Stratton Hammering
Can I use unleaded fuel in my 1972 3hp engine
  • 3,287 Answers
Lead is basically a lubricant with additional octane boosting properties for gasoline powered internal combustion engines. Engines intended to run with leaded gasoline that are provided with with unleaded gasoline instead are subject to overheating and failure. Read more about lead here:
Why Lead Used to Be Added To Gasoline
Your best bet would be to use leaded gasoline - or in the absence of a leaded gasoline source, a lead additive or substitute. Most autoparts stores sell this - and if you're not near one that does - Amazon has it:
Amazon com lead additive for gas
Posted on May 13, 2014
What cuases valves to burn in an engine
Weak mixture is main cause ,but what is the psec on this engine as modern fuel is unleaded and if this is a 1990 then it could have been made to only run on leaded petrol ,unleaded engines have a stelite coating on the valve and the seat in the head to run on unleaded fuel ,or the valves have been ground in more than once and the coating has been worn away .Check with the dealer if this model is designed for unleaded fuel ,if it has a cat on it then its designed for unleded fuel
Mar 23, 2012 | 1990 Toyota 4Runner
What kind of gas does a maxima 2001
According to page 10-3 of the 2001 Nissan Maxima Owner's Manual:
FUEL RECOMMENDATION
Unleaded premium gasoline with an octane
rating of at least 91 AKI (Anti-Knock Index)
number (Research octane number 96)
If unleaded premium gasoline is not available,
unleaded regular gasoline with an
octane rating of at least 87 AKI (Research
octane number 91) can be used.
However, for maximum vehicle performance,
the use of unleaded premium gasoline
is recommended.
Engine "knock" is not just an unusual sound - but over time can cause real damage to the engine. You *should* use fuels with the recommended octane levels, but if you choose to use fuel with a lower octane level due to reduce fuel costs - do not repeatedly use fuel that causes engine knock. Find the "sweet spot" between the cost of lower octane fuel and an octane level that does not cause knocking. Expect fuel economy and performance to drop with lower octane fuels, too.
Feb 12, 2012 | 2001 Nissan Maxima
Could you please let me know. 1] Can I use E10 fuel in my new RLT 30 CET 30cc trimmer that I have just purchased and am yet to start up? 2] Is 50 to 1 50mm of oil to one litre of petrol?
Hi and welcome to FixYa, I am Kelly
First off the engine is designed to operate on unleaded fuel. The manufacturer makes no statements at all about E-10 Fuel. I will tell you from experience that you can use E-10 Fuel but.... should you ever have a warranty claim make sure the entire fuel system is 100% unleaded pre-mixed fuel. Your not going to hurt the unit using E-10 fuel as long as you maintain the proper fuel-oil mixtures. If anything a splash more of 2 stroke oil as in 22 mm / liter vs 20 mm. Or (+) 8 mm per gal.
Manufacturers statemenrts and recommended fuel mixtures below:
Thanks for choosing FixYa,
Kelly
n This product is powered by a 2-stroke engine and
requires pre-mixed petrol and 2-stroke lubricant . Premix
unleaded petrol and 2-stroke engine lubricant in
a clean container approved for petrol.
n This engine is certified to operate on unleaded petrol
intended for automotive use with an octane rating
of 87 ([R + M] / 2) or higher.
1 Litre + 2 0 ml =
2 Litres + 4 0 ml =
3 Litres + 60 ml = 50:1 (2%)
4 Litres + 80 ml =
5 Litres + 100 ml =
The full operators manual is here:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Feb 27, 2011 | Ryobi 15" Electric Factory Reconditioned...
Can 94 jetta run on leaded or unleaded petrol
It is best to run this engine on unleaded petrol. A high grade unleaded will give you extra performance and cause no damage. Leaded fuel was designed for cars made in the 60's to 80's that had used softer materials in their cylinder heads, leaded fuel pro-longed cylinder head life and reduced pre-ignition. Unleaded fuels are a cleaner, safer fuel to use.
Jan 24, 2011 | 1994 Volkswagen Jetta
What fuel is recommended? Regular or unleaded?
The engine comes from japan, a daft statement but the engine was designed to run on unleaded petrol in japan and when they came to England we still ran fully leaded petrol the engine is quite happy on ether fuel the motor may be unsettled for a while but will stablise if you change over from one to the other.
Oct 11, 2010 | 1980 Honda CX 500 A
Unleaded gas in a diesel fuel tank
do not worry about draining it, pour about 6 to 8 ounces of engine oil in it, and top it up with fresh fuel, it will be fine. The only way to drain the tank is to remove it and turn it over.
Apr 26, 2010 | 2006 Dodge Ram 2500
Does anybody know anything about ariens rotavator 90100. will it run on unleaded fuel
All engines manufactured after 1975 will run on unleaded fuel. If it is older, the internal wear on the rings will add enough lubrication to operate on unleaded fuel.
DO NOT add a lead additive. Small engines cannot operate on it.
Oct 30, 2009 | Garden
What kind of gas should i use? I have a 2002 Saturn SC2--just bought it used and I forgot to ask what gas it takes--reg, prem?
Regular unleaded. Cars are designed to run on specific types of fuel and the fuel rating has to do with the temperature that the fuel ignites. The timing for saturn sc2's is set to run on unleaded. Premium will get you worse gas mileage, lower horse power, and possibly do damage to the engine by igniting at the wrong point during the cycle of the engine. As it says in the owners manual and on the gas clap, use unleaded.
Jul 03, 2009 | 2002 Saturn SC
About super unleaded and unleaded fuel
Hi,some manufacturers recomend either super or regular unleded ,the diference is the octane rating ,this will not afect your motor but you allways should stay with the factory recomendations......
Aug 17, 2008 | 1996 Mercury Mystique
Unleaded fuel
Am afraid nothing much you can do since you have to make do with what is locally available. However, a couple of things you can keep in mind:
1. Using leaded fuel with a car intended to use unleaded fuel would destroy your car's catalytic converter faster than normal wear and tear;
2. At times unleaded would be available, pls use as much as possible to help clean/remove the lead additive, tetraethyllead that will cover some soft engine parts with the lead-containing material;
3. you may have to tune your engine's timing to compensate for the leaded fuel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 15, 2008 | 2007 Kia Sorento 4x4
Hammering Logo
451 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
