Question about managemylife.com
My lawn mower starts but it is slow and then dies
  • 3,287 Answers
Hi Debbie,
Most problems with gasoline powered equipment are related to the carburetor. This happens frequently if this equipment is not stored for the "off season" properly. Fuel remaining in the equipment can form varnish that will interfere with movement of carburetor's internal parts, clog the tiny orifices, etc. Often, disassembly and through cleaning with solvents and clearing clogs will return the engine to good running order with little to no need for replacement parts. Making adjustments to the screws and springs on the carburetor is looking for trouble - don't do it. The carburetor is a simple device - but has some pretty small parts that are easily lost of you're not expecting them to fall out during disassembly. Your best bet is to have the mower serviced by a pro. If cleaning is all that is required, it shouldn't cost more than $50 - $75.
You can save yourself this headache next year by either running the engine until it is out of fuel - or removing any fuel from the tank and then run the engine until all remaining fuel in the lines and carburetor has been used completely. This is a good time for an oil change and maybe even a new spark plug. If you didn't do it last year, you might want to have the pro do it for you when he works on the carburetor.
Posted on May 13, 2014
Have a black/decker electric mower that motor slows and dies while mowing.
Your battery is in its death throes and not charging properly. Ergo, it runs "out of gas" fast.
Mar 07, 2016 | Electric Garden
Have a 6hp craftsman mower starts and runs for 30 sec dies have replacer carb with running mower carb replaced plug replaced coil flywheel key fuel tank sounds like it is seizing up slows down for a
you have bad valves seats probably broken loose do to overheating replace short block or by new motor short block cost to much 300.00 new motor 225.00 to 245.00
Sep 07, 2014 | Garden
Techumseh 195cc lawnboy runs fast then slow then stops
Replace spark plug and air filter.
May 27, 2013 | Garden
Have a Honda HRU173PU lawn mower recently serviced by a dealer; new plug etc but slow to start and when under the pump cutting semi long grass it starts to backfire and the it dies.
Why you are not on the horn with the dealer, demanding that this thing be fixed is beyond any answer that I can give you! I think you know what to do or do you?????
Nov 18, 2010 | Honda Garden
My throttle position markings have worn off. Is start position to the front or rear? It cranks in both but quickly dies.
Usually if you push the lever forward that is the start position (or choke position) once started in this position from cold start, slide back this should be fast, slide a little further back and this should be slow then all the back should stop. Have not worked on a lawn boy silver for about two years now but all are about the same, anyhow give that a go, good luck!
Oct 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn mower chugging
better late than never, I have the same mower
there is no throttle control on these mowers, if you look under the air filter the throttle is balanced by a spring pulling in one direction and a lever controlled by engine speed. if the spring breaks or falls off the lever will wiggle back and forth, more gas if the engine slows, less if it speeds up. you end up going fast/slow/fast/slow etc.
The tension spring slows the switching down and smooths out the engine speed.
Jul 11, 2009 | Mtd 22" Yard Machine Push Mower
managemylife.com Logo
116 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
