Question about Whirlpool Cooktops
Whirlpool wfe361lvq electric range - Whirlpool Cooktops
  • 2,509 Answers
And the problem is? please post afresh with full details
Posted on May 13, 2014
What does the code"F5E2" mean when trying to use the self-cleaning function?
This error means that the door lock didn't engage properly. This could be a wiring problem or a problem with the switch. First disconnect the range from power and check the wiring and switches from the control to the switch and back. If the door was locked when the F5E2 error was observed, then replace the door switch.
If the door was not locked, then check the door switch and the latch switch. Replace the bad switch.
The rear door switch is part W10107830, https://www.partstore.com/Part/Maytag/Maytag/MER7765WW/Whirlpool/Whirlpool/W10107830/New.aspx . A useful parts diagram is here: http://www.searspartsdirect.com/model-part/mer7775ww0/3048/0124111/W0908230/00003.html .
After replacing the bad part, reconnect the power to the range. Press and hold any key for a minute to clear the F5 code from the memory. Then press Cancel to clear the next code you see. Check if the range works.
I hope this helps.
Dec 23, 2015 | Maytag MER7765WW Freestanding Smoothtop...
I need to know the specs for whirlpool rs630pxk
Do you need the size of the RS630PXK range? The range is 30" wide, 31 7/8" high and 22 3/4" deep. The installation opening needs to be larger to allow for air circulation around the range. It needs 120V AC power. The specifications for the size and the installation space size is given in the installation guide. Whirlpool has the guide on their product support page. The direct link to the installation guide is http://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%20311433.pdf . All of the documentation can be found by searching on the model number starting here: http://www.whirlpool.com/manuals/ .
I hope this helps.
Sep 30, 2015 | Whirlpool Stove / Oven / Range Cooktop -...
My oven wont work, the display wont appear
check the power to your oven and make sure that you have 110 volt in your outlet using a voltmeter.
Oct 19, 2014 | Whirlpool Gold GY399LXU 30 in. Self...
Whirlpool self-cleaning feature not available
Because the features mention utilize 220 VAC power, I do not advise you attempt any corrections. Very dangerous; unless you are a trained technician. If the unit is in Warranty, get the Whirlpool folks out to you home ASAP.
Dec 19, 2013 | Whirlpool Gold GGE388LX Double Oven...
Oven will only heat to 170 degrees
I can't access Netflix from my playstation 3...it says my internet connection is not detected
Oct 07, 2013 | Whirlpool GY397LXUQ Gold 30" Slide-in...
Eo f2 code shows it constantly beeps and was wondering how to fix
Hi
Thanks for using FixYa. Error F2-E0 in your Whirlpool range indicates shorted keypad. To resolve this issue you’ll have to replace the electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Whirlpool 30 in. RC8700 Electric Cooktop
The cooktop indicator light on my Whirlpool range, model RF265LXTY, won't go off, all of the knobs are in the OFF position. The hot surface light is off.
most cook tops the light that maches the burner is on if sw is on . if light doesnot fo off replace that sw . if only one light for all burners you will have to fint the shorted one.. good luck mm ..
Dec 12, 2009 | Whirlpool RCC3024 Electric Cooktop
Fuses
These heating elements use limiters to control the temp range and here is a link that shows where they are http://www.pcappliancerepair.com/model-display.php Hope this helps...
Sep 11, 2008 | Whirlpool GJC3034 Electric Cooktop
Cooktops Logo
Top Whirlpool Cooktops Experts
Timllfixit
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
