Question about Hunt 73126: Rapid 20EX Personal Electric Stapler
How do you install the batteries on the Rapid 20EX
My 1999 stratus just rapid clicks when i try to start it
Rapid clicking where ? At the starter , a relay in the under hood fuse box ? Bad battery or connections , battery cable problem , starter . How to voltage drop test starter motor circuit .
How to Test Car Battery with Multimeter
Apr 13, 2017 | 1999 Dodge Stratus
Why so long to charge cordless tools
depending on the saw you bought, (or other tool) some come with what is called a "rapid charger" and some come with a small "trickle" charger. most cordless tool batteries take about 1 to 1 1/2 hour to charge (from empty) using a rapid type, the trickle charger will take up to 8 hours to charge a battery. if you want fast, but the rapid charger, and usuallly when you buy one you can get a free battery with the deal.
Mar 22, 2011 | kawasaki Saws
Car won't start. Makes a rapid clicking noise when ignition is in start position
The rapid clicking noise is caused by low battery voltage, you eiother have rub the battery down or the battery is defective or the battery cables are loose or corroded
Dec 20, 2010 | 2004 Pontiac Grand Prix
How to change to a rapid loader head on an echo
line up the hole on the collar that the trimmer head is installed against with the arrow or notch on the gear housing, insert a punch or the brass colored pin that most Echo pieces of equipment come included with, this will lock the head. now turn the head clock wise, IT IS LEFT HAND THREADED! so righty loosey lefty tightey. now install the rapid loader with the included washers and10mm gold colored lefthand thread nut
May 18, 2010 | Echo Rapid Loader, Trimmer Head
My calculator drains a set of four batteries with every use. Why?
I am not sure what every use means: duration, programs running etc. But that drainage is properly excessive. TI estimates that with 2 hours a day of usage, the batteries should last a school semester.
Possible causes of rapid drainage.
The most common causes of rapid battery drain are mismatched batteries
  1. Batteries of different brands
  2. Batteries of different types (alkaline (1.5V + rechargeable NiMH 1.2V)
  3. Batteries of different charge levels (new batteries with old ones)
  4. Negative charge build up
Another cause of rapid battery drain is the use of third-party programs: Certain of them keep large amounts of data in memory. Some of them are tweaked to bypass the TI power management scheme and disable the TI APD (automatic Power Down ) after 5 minutes of inactivity.
Possible remedies
  1. Remove all batteries (main batteries and backup battery)
  2. Leave them out of calculator for about 15 minutes. (Beware that this will clear the contents of the memory and that data will be lost along with all applications installed). However Applications cam always be reinstalled once calculator returns to its normal state.
  3. The possible benefit of the removal of all batteries is to make the negative charge build up disappear.
If that fails
If the foregoing steps fail to restore the calculator to its normal behavior, you may have to contact TI Customer Assistance by filling out and submitting a customer assistance form.
Dec 18, 2009 | Texas Instruments TI-84 Plus Calculator
Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
Aug 12, 2009 | Motorola Radio Communications
Hunt 73126: Rapid 20EX Personal Electric Stapler Logo
Top Hunt Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hunt Office Equipment and Supply Expert? Answer questions, earn points and help others
