Question about Samsung ML-3471ND Network Mono Laser Printer
How to replace the pickup roller
The manual feed pickup roller isn't picking up anymore. Can that be easily replaced in office?
3 Suggested Answers
SOURCE: Pickup Roller wear
I have had the same paper jam nightmare as many CLP-300 users and just as I was on the verge of throwing it away I appear to have solved the problem. The paper tray has adjustable plastic guides on either side. I loosened them slightly to allow an spare eighth of an inch each side and I've had no problems since. I can't believe the problem that plagued me for months was so easy to fix.
Posted on Mar 05, 2009
boatadjare
  • 195 Answers
SOURCE: I have recently replaced the pickup roller and
log on to www.feedroller.com/Store/clean_inkjet_printers.php
Posted on Jul 20, 2010
My HP LaserJet P1606 does not pick up paper anymore. I grinded somekind of gears, and all of a sudden the pickup roller and associated bar does the rotate enough to pickup the paper when printing.
Open the front and remove the toner cartridge. Turn the paper feed roller by hand until it clicks and goes slack. This is the rest position. Try it again. It doesn't sound good that you said you 'grinded some gears'. You may need HP professional service or a new machine.
HP LaserJet Pro P1606dn Printer Software and Drivers
Nov 17, 2017 | HP Office Equipment & Supplies
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
Error 13.01.00 hp 3005
Thank you for contacting FixYa with your printer inquiry.
This is usually a paper pickup error where paper pickup roller is not contacting the paper in the default paper tray or Pickup roller is worn smooth and not picking up the paper.
Turn the printer around and lift the flap behind the paper tray. If you have a flashlight, get it. You want to watch the action of the paper pickup roller. By observing to see if it is rotating, slipping on the paper or whatever, you should be able to determine why the paper isn't feeding.
Solutions: Make sure the paper size adjuster in the tray (Paper Backstop) is against the paper and correctly set for paper size.
Paper roller slippage - Needs to be replaced. Order a new one. Clean with water or alcohol in the interim while waiting for replacement. Eliminate all the paper dust. Sometimes works.
Part Number: RL1-1370-000CN Paper pickup roller - Picks up media from the paper input tray.
Venders: http://partsurfer.hp.com/Search.aspx?SearchText=Q7814A - HP Parts Surfer
http://www.laserprinterservices.com/parts.html
https://www.partsnow.com/Forms/Login.aspx
http://www.thelaserguys.com/Printer-Error-Codes_ep_42.html
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 07, 2011 | HP LaserJet P3005n Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Cards not feeding through on SP35
You will need to replace the Pick Roller (the first roller you see from the card hopper.
You most probably have a smooth roller and the new type are ribbed. The printer has to be dismantled to replace the roller. Suggest you contact your local reseller.
Jun 24, 2009 | Datacard SP35 Printer
Manual feed pickup
replaced the manual feed tray separation pad (it is right under the pick-up roller). The HP part # is RG5-2703. First remove the pickup roller then you can pops it out with a small straight slot screw driver.
Jan 23, 2009 | HP LaserJet 8150n Printer
Paper feed
Yep the paper feed roller wears and will need replacement (open front cover in centre of machine tabs on either side it just clicks out.
should also change sep pad (multi feeds)
Here in LINK to purchase items pic below
Dec 21, 2007 | HP LaserJet 1000 Printer
HP 7110 printer paper rollers
usally when a printer picks up too many sheets the pickup rollers are dirty or covered with paper dust use a microfiber towel moistened with water or rubbing alcohol wipe them off then if it still picks up too many sheets the surface of the pickup roller is worn.replace pick up roller the printerworks .com may have parts or hp partSurfer.com
Oct 20, 2007 | HP OfficeJet 7110 All-In-One Thermal...
Samsung ML-3471ND Network Mono Laser Printer Logo
22 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
