Question about Samsung Rv511
Please help my samsung rv511 laptop charger get really hot and starts to melt when i plug it in but when i take the battery out it doesnt when pluged in without the battery in the same problem occurs help pleasetried new battery and new charger
    Problem Solver:
  • 13 Answers
Your battery may be bad, I advise you buying a new battery
Posted on May 13, 2014
Testimonial: "thanks for ur help much appreicated had new battery and charger and still the same also the jack port hole has started to melt and it gets very hot around the jack area of the laptop"
  • 552 Answers
You may have fried the battery already and because the charger got hot, it is probably fried too. The original cause may have been the battery being faulty which is common. Amazon has some chargers and batteries for you computer at a reasonable price. Laptop Notebook Charger forSAMSUNG RV511 19V 3 16AAdapter Adaptor Power...
Testimonial: "thanks for ur help had a new battery and charger and still the same but thanks for ur help much appreciated"
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 73 Answers
It's most likely the connector on the mainboard (an unfortunate designflaw). There's constant glitch and this produces very short but high temperatures. It has to be replaced, this requires a new dc-plug, tools and skills/knowledge, sorry....
Posted on Feb 23, 2017
    New Friend:
  • 14 Answers
You should check you'r chrging power cuircle in you'r lap .all that if you shure the new battery or charger is good or not.
then looke at the charging ice it's neer the battery port if it's dameged
or any switch with it.ithink the ice is (ISL 655)
Posted on May 14, 2014
3 Suggested Answers
DJ Skywalker
  • 507 Answers
SOURCE: I have an RV511.
Power management software in Windows Vista
Understanding battery charging issues
If the notebook battery is not charging or the notebook does not indicate that the battery is charging, the most likely scenario is that the battery itself is operating correctly, but its power management software may have become corrupt. In order to correct the problem, you will need to uninstall and reinstall the power management software by using the Device Manager. This document will explain how to uninstall and reinstall the ACPI Battery listings in Windows Vista, as well as how to obtain and install updated BIOS files, if needed to correct other battery issues.
Uninstalling and reinstalling power management software in Windows Vista
In order to correct problems with the battery's power management software, follow the steps below.
1. Click Start and type device in the search field, then select Device Manager .
2. Expand the Batteries category.
3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes .
Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging.
Posted on Jun 24, 2011
  • 564 Answers
try removing the battery and just use the mains power. If the laptop works you may need a new battery. If it doesn't your charger is faulty.
Posted on Nov 26, 2012
Samsung rv511 wont shut down properly
Pull the battery and then put it back and see what that does. My concern is that it maybe too hot. Go to and download the free program called speedfan. Run that program and it will tell you temp of the cpu and the hard drive.
Jun 30, 2016 | Samsung Rv511
My samsung laptop charger gets hot and starts to melt when pluged in and powered up and does the same if i take the battery out please helptried a new battery and new charger could it be the jack on the...
I'm unclear however
Does the new charger get too hot? If so the problem is not the charger or the socket.
Does the laptop work with the new charger plugged in but no battery? If so the socket on the laptop is probably ok
Is the actual charger melting or is it just the plug that goes in the laptop that's getting hot, if it is the plug on both chargers then the socket will need repairing or resoldering, they are a weak point, the soldered pins go high resistance and can generate a lot of heat around the plug and socket. Its usually obvious if the socket is faulty because as you move the plug it makes contact intermittently.
DONT USE THE CHARGER THAT'S MELTING and if both are getting hot have the socket repaired.
If only the one charger getting hot the short is probably in the plug on that charger but read on
On a different note the genuine chargers should be over current protected and overheat protected, they should never melt.
May 13, 2014 | Samsung Rv511 Series Laptop Intel I-core...
When i plug charger samsung rv511 laptop its showing plugged in not charging .how to fix to fully charge
maybe the battery is full charged. run without plugging in that is best. pluging in and battery at full charge is not a good thing.
Mar 14, 2014 | Samsung Rv511
Samsung rv511
Faulty connector?
Dec 30, 2013 | Computers & Internet
Adapter from power cord gets power, but is not charging samsung rv511 laptop
Step 1:
b> If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
Feb 12, 2013 | Samsung Rv511
My Samsung RV511 Laptop isn't getting power.
Most likely problem in this instance is a loose dc socket. it is a cheap fix or you can re-solder it yourself, if you have the ability.
Nov 26, 2012 | Samsung Rv511-a01 Laptop
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
My samsung RV511 laptop seems to be overheating a lot. Whenever the computer is under a heavy load it just shuts off. I bought 2 different cooling mats and they do not help. It is to the point now that...
Check the cooling fan at the bottem of the laptop see if is working ,also use a can of compressed air and blow out the fan give it a thorough cleaning if need you might have to replace the fan .If you will supply me with a model number I will get instructions on how to disassemble to put in a new fan
Sep 07, 2011 | Computers & Internet
Why would the plug melt on an Acer 5315?
Plugs melt when the connections 'short circuit'.
This means the positive and negative energy paths are touching.
Even the smallest AAA or 9V battery will get really warm if your connect the terminals together, and the power supply of a laptop computer pushes more more power (amps) than a little battery.
If it is indeed the power connection of your laptop has some melting damage, I must recommend you have your laptop and its power supply serviced or replaced, and to not plug it into the wall until you do. Fires have started by malfunctioning/damaged cameras and computers.
I hope that helps.
Aug 21, 2010 | Acer Aspire 5315 Notebook
I hav a phone problem and a samsung 1gb mp3 player
both of your device have some hardware problem send it to service center for details checking.
Jun 20, 2008 | Nokia 6600
Samsung Rv511 Logo
203 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
