Question about Watches
I have a Illinois pocket watch, serial number 3538525. When was it manufactured?
  • 552 Answers
escapement
  • 2334 Answers
SOURCE: opening an elgin pocket watch
The best tool to do it is watchmakers knife, but any proper knife with hardened steel blade can do the job. Make sure the blade is NOT flexible.
Check carefully the sides of your watch and you will notice the groove. Place knife blade into that groove and press it in. At the same time try to make a scooping turn to lift the caseback. Usually there must be underlayed caseback as well and it opens exactly in the same manner.
Make sure you do all this carefully and do not let the blade to slip or your watch will end up with nasty scratches or even damaged movement.
That job isn't a big deal, but requires some skill, so, BE CAREFULL.
Don't forget to rate, please.
Posted on Jan 05, 2009
SOURCE: illinois pocket watch stem removal.
First you must say what type as there are differences depending on the mfg and model.Be the following basics apply.
1- Put the stem in the setting position (usually pulled out if stem set).
2 Them open cover to expose the movement. ( Screw off or snap open).
3- Remove the movement (Usually held in place with 2 screws at the outer edge.
4-Then if there is a screw in the part that holds the stem loosen that.
5- The stem can be held with a pair of pliers on the flat and the crown unscrewed. Be careful not to damage the square (FLATS), with the pliers. A rag or other safety measure should be taken.
6- then inside the stem hole, looking from the ouside the is an annular area around the stem that has a ferrule screwed into the case this has to be unscrewed and will bring out the stem and the ferrule.
This siounds complicated but the steps are more involved to write than they are to perform.
There are many variations to this process, and each type should be understood before proceeding.
mrmel.mrmel@gmail.com
Posted on Nov 24, 2009
  • 2501 Answers
SOURCE: I have a silver case Jos. Johnson key wind pocket
If you go to Wikipedia and type in "
Joseph Johnson (watch maker)"
you will see there are a number of reference documents listed. The information you look for may be in one of these.
Posted on Jan 05, 2010
cmcduncand
  • 714 Answers
SOURCE: I was able to buy an elgin pocket watch which is
You Bet.
GOTO:
http://www.awci.com/
Find a local repair man.
r/
David
Posted on Jan 22, 2010
cmcduncand
  • 714 Answers
SOURCE: deuber watch co. Pocket watch serial no. 2549465
If the serial number came off of the movement the pocket watch was manufactured between 1909 - 1910.
Hope this tips.
r/
David
Posted on Mar 03, 2010
I have an Illinois pocket watch with serial number 4449272, how much would this be worth
mcdevito75 here, An Illionis pocket watch doesa have collector value, how much is really up to the collector buying the watch, if the watch works well and the watch is clean , no rust or brassing it could bring up to $100.00 Check on ebay and see what they are going for, also check at your local jeweler see what they say.
Jun 14, 2010 | Watches
I have a Ingeroll Mickey Mouse pocket watch. The
As you can see by the serial number these watches has been manufactured in vast numbers. I can't give exact date when the watch was manufactured, but it was definitely in 1960-1970-ies. Some watch manufacturers still do produce editions of M. Mouse themed watches, but now they are not in trend, so, not too many people buys them. Worthiness of your watch can be given if the experienced watchmaker/watch dealer see it in the flesh, as there are too many things to be considered: type of movement, overall looks, time keeping, even the type of picture of M. Mouse. All I can say is: do not expect a fortune. The best way for you is to make evaluation of the watch and then put it on specific watch/clock auction. Rate me,plz.
Mar 31, 2010 | Watches
I have a waltham 9k gold pocket watch, its serial number is 21772651, its 7 jewel.i cant find what its valuation is and any infprmation about it.
Pocket watch manufactured 1917-1918
RECOMENDATION:
Seek professional help for watch value.
In short, demand for antiques pocket watches are up the real question is what is it worth to you?
Keeping it in running condition increases its value to you and the next generation.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 21, 2010 | Chase IK7A Waltham Antique Watch
Deuber watch co. Pocket watch serial no. 2549465
Hope this tips.
r/
David
Mar 02, 2010 | Watches
I have an Illinois pocket watch and I can't figure out how to open it to get the proper info to look it up. Can you help me plz?! Thank you
The back screws off.
Turn it Counter clockwise.
The numbers you need is the actual serial number off of the movement not the case.
We then can provide you the production information on your particular run of antique pocket watch.
r/
David
Feb 19, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
Have a waltham pocket watch in an illinois case enameled dial with a recessed seconds dial at bottom with a numeric 6. seconds on face also. can't find year or pic of this watch
If you go to the web site "www.antique-pocket-watch.com/waltham-pocket-watch.html", you will find information about Waltham watches and if you read the serial number off the movement (open the back and read it off the back plate), you may be able to find out the year of manufacture.
Feb 10, 2010 | Chase C6A Waltham Antique Ps Bartlett...
How find serial number on ~1910 hamilton pocket watch?
The serial number is usually engraved on the movement. If you open the back of the watch, you should be able to see it.
I looked at the Hamilton pocket watch site (in might be helpful if you visit the site, simply type "hamiltonpocketwatches.com" into your search engine and your will be able to examine photos of a number of movements).
The position and size of the number varies but it shouldn't take to long to find. One of the pictures I found impossible to see the number but the rest I found, although sometimes you had to look quite carefully.
Jan 29, 2010 | Sterling J3E Hamilton Antique Pocket Watch
Can I find out from the serial number on an Illinois pocket watch if it is a dual time zone watch?
All the pocket watches that I have seen are designed so that the back hinges open (using your finger nails to open it).
All the watch information is usually inscribed on the mechanism.
Jan 15, 2010 | Watches
I have a silver case Jos. Johnson key wind pocket watch made in Birmingham. Cas serial number 2508. Can yo tell me the year of manufacture?
Jan 03, 2010 | Watches
Illinois pocket watch stem removal.
Dec 15, 2007 | Watches
Watches Logo
87 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
