Question about Mtd Garden
Mtd hydrostatic riding lawn mower blades will not engage
Mtd series 175 hydrostatic 42"
    Habit-Forming:
  • 78 Answers
Check the springs on the deck unit to make sure that when the engagement lever is activated its moving the springs, often one end comes off and that is all the problem is. The other thing we find is the belt has broken, and people are not even aware that it did, as covers and guards prevent you from seeing it until you really get looking into the deck drive system.
Posted on Jun 03, 2015
  • 549 Answers
There are five things that could be wrong. no.1 the switch to turn it on is bad, no.2 the electric clutch is burned out, no.3 the wires are broken or bad connection, no.4 a blown fuse, no. 5 broken drive belt or belts. I have provided a link to the MTD website with an 800 number you can call to verify this. MTD Products
Posted on May 13, 2014
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
  • 2841 Answers
SOURCE: mtd riding mower: right mower blade cutting
The blade can be bent or the deck is not level. Adjust the deck and level it from side to side. Now level it from front to rear with the front of the deck 1/4" lower than the back. If after leveling it, you find it still cuts uneven remove all blades and inspect them. You will more than likely find one is bent. Replace a bent blade.
Posted on Sep 18, 2009
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
SOURCE: MTD RIDE ON LAWN MOWER SOLENOID
CHANGE DRIVE BELTS
Posted on Nov 09, 2010
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 | Garden
Mtd hydrostatic lawn tractor blades will not engage
mtd makes a hydraulic driven mower blade what's it's model number ?
May 13, 2014 | Mtd Garden
I have a 42" mtd lawn tractor. The blades do not
The blades engage via a belt, that goes around a series of pullies, one of those pullies is a tension pulley that is connected to your pto lever by springs, the engine has nothing to do with your blades until after you engage the lever, I would check your belt. It could be loose, and if you engage the blades it could take it a few to get up to speed, thus making it seem like its only when the engine is warm.
Does everything else work fine? As in the tractor moves when the blades are not engaged?
Jul 11, 2012 | Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I want to be able to back up with the blade
cut the wire on the safety switch just under the belt housing
Sep 19, 2009 | Mtd 22" Yard Machine Push Mower
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
116 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
