Question about Samsung Rv511 Series Laptop Intel I-core Cpu Heatsink Ba62-00546c
My samsung laptop charger gets hot and starts to melt when pluged in and powered up and does the same if i take the battery out please helptried a new battery and new charger could it be the jack on the board
  • 2,509 Answers
I'm unclear however
Does the new charger get too hot? If so the problem is not the charger or the socket.
Does the laptop work with the new charger plugged in but no battery? If so the socket on the laptop is probably ok
Is the actual charger melting or is it just the plug that goes in the laptop that's getting hot, if it is the plug on both chargers then the socket will need repairing or resoldering, they are a weak point, the soldered pins go high resistance and can generate a lot of heat around the plug and socket. Its usually obvious if the socket is faulty because as you move the plug it makes contact intermittently.
DONT USE THE CHARGER THAT'S MELTING and if both are getting hot have the socket repaired.
If only the one charger getting hot the short is probably in the plug on that charger but read on
On a different note the genuine chargers should be over current protected and overheat protected, they should never melt.
Posted on May 13, 2014
  • 549 Answers
It could be a short at the plug, but if you replace only one of the 2 items (charger or battery) at a time, either of them could have caused damage to the other. They need to be replaced at the same time when this problem occurs.
How do i fix charging problem in hp Compaq Presario laptop
If you are using a pattern charger, there may not be enough current to power both battery and laptop.
Sep 26, 2016 | HP Computers & Internet
Samsung r730 laptop
It could be, though power supplies typically work or don't work.
Sep 03, 2014 | Samsung R730 Notebook
Please help
Check the charger. Could be broken - not giving enough power. Laptop should start with no battery - just charger pluged in. If it does - you have a broken new battery
Oct 28, 2012 | HP Pavilion Computers & Internet
Laptop only turns on every now and then, charger pluged in but charger light not on, when trying to turn on fan kicks in, charger light flashes, then nothing, please help?
It sounds like you have a bad charger cord. Does it do the same when powered off the battery? Like it is tryin to start up. An d also make sure battery is plugged in good to the laptop,
Oct 31, 2010 | HP Compaq nx5000 Notebook
Help please
If you have a local PC repair shop near you, take it in and see if they have another charger they can try out on your machine. They shouldn't charge you anything, we are just trying to find out if your charger is bad and not allowing enough voltage through the device to power the laptop up.
Aug 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
HP Ze2000 laptop charger overheats
CHECK THE POWER OUTPUT RATING ON YOUR POWER SUPPLY AND SEE IF IT IS HIGHER THAN THE COMPUTERS POWER RATING, THIS INFO IS ON BOTH THE LABELS OF THE COMPUTER AND SUPPLY, IF ONE IS HIGHER THAN THE OTHER THAT WOULD EXPLAIN THE OVERHEAT, IF THAT IS NOT THE CASE, THEN GO TO ACERS TROUBLESHOOTERS WEBSITE OR CONTACT THEM DIRECTLY FOR HELP... JON T
Dec 07, 2008 | HP Pavilion ze2000 Notebook
Charger overheating and melting the tip, Irregular charging
First, Check for damage (frays, tears, melting, or cracks in/on the insulation) on the power unit from tip to wall socket. If all looks well then I would check the voltage on the power unit by using a voltmeter. If it's within manufacturer printings on the box, then you might have a possible short.
Hope this helps.
Oct 13, 2008 | Compaq Presario M2000 Notebook
I hav a phone problem and a samsung 1gb mp3 player
both of your device have some hardware problem send it to service center for details checking.
Jun 20, 2008 | Nokia 6600
Samsung Rv511 Series Laptop Intel I-core Cpu Heatsink Ba62-00546c Logo
102 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
