Question about Kenmore Refrigerators
Our Kenmore 596-76533500 bottom freezer/French door fridge stopped cooling. Please please help?
  • 173 Answers
Check the evaporator fan . open the cover and see if defrost problem occured
Posted on Jun 02, 2014
SOURCE: Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
Posted on May 10, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
tech master
  • 120 Answers
SOURCE: kenmore fridge model#596.52679200 side by side
remove back cover on evaporator inside frezeer if is full of ice all over then you have a defrost problem and you might have a faulty defrost timer or defrost thermostat repl both so you wont go wrong if the coils are clean and not frost is on coils then check compressor to see if its running just by touching you can find out if it si not running then you have a faulty relay or overload repl and compressor should start.if there is only partial frost then you have a leak or restriction depending when you bought it most refrigerators have a maufactures warranty on compressor for about 5 years call for service on the number on the sticker inside refirgerator
Posted on Oct 14, 2008
duby1990
  • 370 Answers
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Posted on Nov 20, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Fridge is not cold freezer works fine.
Try changing the damper settings in fresh food compartment. Your refrigerator has a control board and it is possible the board is no longer working correctly. If your board is bad I can help you locate one. If the fridge is still under warranty I would have the technician come out. He would possibly just change out the board without testing to original board. Other things that could cause problems are thermistor and defrost thermostat located inside the freezer and attached to the evaporator coil. If you continue to have problems, let me know, Thanks, Sea Breeze
Posted on Mar 24, 2009
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Both freezer and fridge just stopped cooling. The lights come on when the doors are open and it sounds as if it's trying to run, but no cooling.
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. This are basic possibilities which first needs to be checked. But if this possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Aug 07, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I have the same problem that someone else on here has, my freezer is working but my fridge is warm. What could be the problem?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 05, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Freezer still working. Refrigerator not cooling. Hot to top on inside of left hand door as you face refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Kenmore Elite Trio 7855 (25 cu. ft.)...
My refrigerator has stopped cooling - though my freezer is still cooling just fine. Please help!! Model # is Maytag MFD2561KES
heatman101
Nov 01, 2010 | Maytag MFD2561KES Stainless Steel Bottom...
My bottom freezer refrigerator will not cool the top but the freezer is good, the fan and compressor are running, but that is all
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 09, 2010 | Kenmore 24.8 cu. ft. Trio French Door...
Our Kemore Elite French Door Fridge is not working. The Freezer is freezing but the fridge is not cooling at all.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jul 22, 2010 | Kenmore 77552 Bottom Freezer French Door...
My Kenmore Elite french doors bottom freezer drawer fridge has condinsation in the top of my fridge what is causing this?
bad/dirty door seals allowing fresh moist air in.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 24, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
Refrigerators Logo
99 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
