Question about Bissell Cleanview Helix Vacuum
The light turns on but not the vacum - Bissell Cleanview Helix Vacuum
  • 39 Answers
Chanses are the motor is out or locked up with dust.
Try taping around the motor with a rubber mallet. Do not take it apart just turn it on and tap it. Hard as you dare without breaking it. Tap around the motor case. It may jar the carbon brushes lose.
Posted on May 14, 2014
The bristles will not turn when vacume is on and I try to vacume
Alot of those vaccums have a little drive belt on them. You might look for that. Also some string might be caught on the side of the brushes.
Sep 13, 2014 | Vacuums
No suction
hey, how are you ?
here are a ew things that could be causing you sorrow
1.) Check your vacume to ensure that it isnt clogged anywhere
2.) before your compressor and after the filer, this part is where the suction takes place, check to see that it isnt clogged or that it isnt broken...
3.) check your packing (diapharam) in the vacume oto see if it ruptured(has a hole or broken)
4.) Check for lears on the vacume, basically run a pice of paper all over it and see if it is pulled to the vacume.
Once air is coming out the back, it means the compressor is working, but it alos means that the vacume is clogged, or a compartment that is u\supposed to be sealed is broken, or it has a leak somewhere..
My bet is that it is clogged somewhere, take it apart you will find it..
Jan 09, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Electrolux Unirapido not working green light flashes when start button is pressed!
I have the same problem with this type of vacum. I have tried a lot of things but the problem is with the software included in a 20 pins chip on the pcb so it can not be repaired. But, if you look in the back of the vacum there is a rubber stopper wich hides 2 pins. Maybe those pins can be used to reset the vacums pcb. I really dont know because in can't test it any more. I solved my vacum bypassing the vacum mainboard (pcb). Now my internal battery is directly connected to the 2 motors using a simple switch to powering on and off. The original pcb is conected only to the batery, recharghing wires and led wires so i can recharge the batery as usual. Sorry for my english, hope you understanded what i was trying to explain. good luck
Apr 15, 2013 | Vacuums
When the power head is turned on it goes from green light to red light and stops. The belt is fine and there is no obstructions in the brush to stop it from turning.
this will happen only when the brush or motor does not turn the right speed
make sure to pull the end caps off the brush and clean any hairs or fibers from it
the motor you can try and turn it by hand with out the belt on and see how free it is
Oct 19, 2010 | Fantom Vacums Lighting Canister Vacuum
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Oreck XL 21
My old vacume had the same problem - the wire had a 'plug' on both ends. 1 to the wall outlet and 1 to the vacume, which you could pull out of the vacume. It was making poor contact at the vacume and eventialy burned out (melted)
See if the plug/wire to the unit is removable, if so is it damaged?,
could need a cleaning, or it may not be pushed in all the way.
Good Luck
Mar 22, 2008 | Oreck XL21 Bagged Upright Vacuum
My vacum power head wont work
fan belt might have snapped.  take off top by snapping out plastic over light.  good luck!
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacums
check belt not broken - could have happened when you caught tassle in head
Bissell Cleanview Helix Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
