Question about Acer eMachines Black EL1850G-42w Desktop PC with Intel Celeron E3400 Processor and Windows 7 Home Premium... (884483099900)
Which firewire card is compatible with Acer eMachines ET 1331G?
Which model firewire card would you recommend for an Acer eMachines model ET1331G 64bit Vista?
    Sergeant:
  • Acer Expert
  • 464 Answers
Hello Mark
I researched you computer and you will need a PCI-E firewire card to install. Here are some options I found on ebay for you.
348results for pcie firewire card
Posted on May 13, 2014
3 Suggested Answers
  • 13433 Answers
SOURCE: Removeing panel from acer aspire to install firewire card
Generally you have two or more screws in the back of the computer, maybe a lever that you have to pull to release the side panel and it should come off, releaving the internals.
Posted on May 19, 2009
bishopx_svk
  • 159 Answers
SOURCE: I need a compatible Firewire Card for my eMachines
This should work for you
http://www.newegg.com/Product/Product.aspx?Item=N82E16815158020&cm_re=firewire_adapter-_-15-158-020-_-Product
Posted on May 02, 2011
Testimonial: "Oh my God!, thank you so much, this site rocks"
My emachine computer worked fine last night, but today it will not go into windows at all and also will not let me do a full system recovery. The screen remains black with no activity at all. What d
yeah that means that the windows have fallen u have to re-install ur windows by downloading one ( if u know how to install ) or go to a computer shop to solve this problem.
also YouTube has lots of instructions on how to setup a windows in ur computer good luck =)
Jan 13, 2013 | E-Machines eMachines Desktop PC
I have a acer aspire, ,what kind of pci card do i need so i can have a firewire port ieee 1394
Hi John,
The Acer Aspire 3502WLCi does not has the ability to use any PCI which can be compatible with Firewire IEEE 1394.
The model was designed not to support such type.
Regards,
Suhail
May 22, 2012 | Acer Aspire 3502WLCi Notebook
I need a compatible Firewire Card for my eMachines EL1850G-42W Can you redirect to the right one. Thank you.
May 01, 2011 | Acer eMachines Black EL1850G-42w Desktop...
I have an Emachine ET1331g. How do I open the casing to reveal its inner contents?
The eMachines ET1331G desktop computer uses the eMachines NexGen 3 computer case.
Looking at the computer from the Front, the Left Side Panel removes.
Looking at the back you will be viewing the Right side.
There are two screws to remove, then the side panel is slid Back. (Towards the rear of the computer)
There is a raised protrusion in the middle of the Side Cover on the back. This is where your fingers go to pull back on the Side Panel.
There is one screw coming down from the top, on the edge of the Side Panel, and one screw coming up from the bottom.
(Philips head screws)
Remove them.
Slide the Side Panel back. It will only slide back so far, as there are tabs coming from the Side panel, into slots of the computer case.
Once it stops sliding back, take it straight out to the side. Lay the Side Panel aside.
Here is a photo detailing the back of the ET1331G from eMachines Support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The two screws on the Right side, as you are viewing the computer from the Rear, as shown here.
NOTE*
1) Computer UNPLUGGED from power
2) Observe Anti-Static Precautions BEFORE reaching inside the computer, and BEFORE handling hardware parts.
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components in a computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH the metal frame of the open computer case to relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to touch the metal frame again upon your return.
For additional questions please state in a Comment.
Regards,
joecoolvette
Nov 19, 2010 | E-Machines eMachines Desktop PC
Can I upgrade the processor on the emachine ET1331G-07w, and how high? it comes with a Athlon X2 250U @ 1.6Ghz
the am athlon x2 250 3.0 ghz 65w worked perfectly my et1331g-07w no bios update required just plug and play
Oct 20, 2010 | Acer Computers & Internet
Expansion slota
eMachines Support > ET1331 desktop computer > Product Views > Rear View,
The metal covers that have the Plus sign ( + ) holes, are Expansion Slot Covers.
Insert a flat tipped screwdriver blade in the + sign hole.
Insert the screwdriver blade horizontally, in the + sign hole, on the right side. ( ---- , not vertical I )
Gently bring the back of the screwdriver down.
This will make the metal slot cover, bend the small metal tab that is holding it.
Go to the + sign hole on the Left side. Do the same on the Left side as the above.
Bring the back of the screwdriver up.
Keep working the metal expansion slot cover back, and forth, until the two small metal tabs that are holding it in, break.
Remove the metal expansion slot cover.
Before you begin, ensure that the expansion slot cover you wish to remove, lines up with the wireless adapter card.
Have any questions concerning this, post in a Comment.
Jun 25, 2010 | E-Machines eMachines Refurbished EMA...
I recently purchased an HP Officejet6500 E709 printer, etc. for my new e-machine, model ET 1331G, that I bought a couple of months ago and I tried to install it but it keeps telling me that it hasn't been...
Try Installing as Administrator. Try setting compatibility mode, for the main, install, setup, .exe , set as XP SP 2. If you use a 64 bit system turn digital driver signing OFF. (F8 at boot up & select).
Feb 17, 2010 | Office Equipment & Supplies
ET1331G-03w Multicard reader problem...
I would check all the slots if that is the only slot giving you problems then that slot may be bad.
Jan 04, 2010 | E-Machines eMachines Desktop PC
Looking for new computer that will support 4 monitors.
i may be wron but i'm not aware of any standard pc that will support 4 monitors. I used to run two monitors when i used my pc for djing on but that was down to the garphics card, many better spec cards will support dual monitor output. You could try getting 2 graphics cards that support dual monitors ans running them in SLi mode, that would give you 4 monitor outputs. Have you checked the Nvidia website? it's possible they have software that would support multi monitors.
Nov 21, 2009 | E-Machines eMachines Desktop PC
Acer eMachines Black EL1850G-42w Desktop PC with Intel Celeron E3400 Processor and Windows 7 Home Premium... (884483099900) Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
