Question about PIAA 2002 Chevy Astro - All Astro models - Xtreme White Bulbs
Where is the knock sensor located on a 2008 scion tc?
Where is the 2008 scion tc intermediate Shaft Speed Sensor located? thanks.
you are looking for Transmission revolution sensor NC (speed sensor NC). its under the battery and air cleaner assembly on top of the transmission. advise it could be the harness or ECM
Nov 22, 2016 | 2008 Scion Tc
How to clean my 08 scion tc throttle body?
Buy a can of CRC Throttle Body Cleaner
Instructions are on the back
Google a picture of it (Location)
ALWAYS bolted to the intake manifold
Some times in ducting before it
Cleaning it, is just cosmetic, for the most part
Makes the inside look nice
50/50 it will fix anything
Aug 11, 2014 | 2008 Scion Tc
Where are airbag sensors located 2008 scion tc
which sensors?
there are numerous sensors , what is the problem causing you to be conserned about the loaction of the sensors?
Mar 25, 2013 | Cars & Trucks
What kind of oil does my 08 scion tc take?
there should be a label under the hood telling you what kind of oil you need if not stop by your local Toyota or Scion my wife 2005 Scion XB use 5-30- Synthic wish you the best of luck Michigan Man
Oct 24, 2010 | 2008 Scion Tc
I have a Scion TC. AC worked, than startedto blow warm air, Mechanic said that I need a new ac sensor...where is the sensor located?
first it might just need a charge, and not the sensor, before you go and change parts, go to parts store and ask them about refrigerant
Aug 24, 2010 | 2006 Scion tC
Scion tc 2005: door indicator on gauge wont shut off?
check all of your door latches to see if they all work. If there are sensors on the body where the door closes toward the center B PILLAR of the car it has sensors for the doors, then push them in and see which one is bad. Sometimes the door sensors are located in the door actuator which usually goes to the driver;s door due to it's high use.
Jul 16, 2009 | 2006 Scion tC
PIAA 2002 Chevy Astro - All Astro models - Xtreme White Bulbs Logo
Top PIAA Optics Experts
Lawrence Oravetz
Vernon Taylor
Are you a PIAA Optic Expert? Answer questions, earn points and help others
