Question about Electrical Supplies
Generac troubleshooting 4800 watt rv generator
Wont shut down after starting
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
CarlGehrke
  • 169 Answers
SOURCE: 10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
Posted on Apr 06, 2009
SOURCE: I have a Generac 15000 watt portable generator. It
I have solved the flooding problem . unfortanetly you must remove the carb to fix it. once you remove the carb you need to remove the fuel bowl. In the bottem of the fuel bowl there is a electronic seloniod that controols the amount of fule going to combustion. this aria had varnish and gunk built up around the plunger of the selonoid, long story short clean this out with carb and chook cleaner and put it back together. start her up and she will run like a champ.
Posted on Apr 27, 2009
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
  • 26 Answers
SOURCE: Attempted to start Generac Guardian 15 kw air
I work on these every day. Its either gonna be the rotor or stater, the voltage regulator, but most likely its a bad stepper motor which is the throttle motor, or control board. Thats all that could be causing that so its one of those. If its the rotor or stater thats bad it causes the generator to RPM up because it thinks its not producing enough power due to that. I had the same problem with the same one we just fixed and it was the slip rings on the end of the rotor so bad rotor.
Posted on Jul 09, 2009
I have a 4500 watt generac lp rv generator. When I run it, it sounds like it's flooding. I have to have the gas valve almost closed for it to run right. What's wrong with it?
Sounds like the valves in the Carburetor are stuck open, or the choke is stuck closed. either way the Carburetor will need to be removed and serviced.
Nov 28, 2015 | Generac Rv Generator 4500 Rated Watts
I have a Guardian RV 3600 watt generator than wont run more than a few seconds. I have to hold my hand over the breather to get it to fire then as soon as it revs up it shuts off.
carburetor restricted due to long time storage drop carb fuel bowl unscrew the jet and pull down the fuel tube clean them and your generator should run much much better
Aug 16, 2013 | Guardian Rv Generator 4800 Watt, Gasoline,...
My generac 40g rv generator will start fine but no power. I noticed that when it starts the microwave will power up for just a second. I can turn the generator off and on a couple of times and then it will...
It may be demagnetised. If you turn off the generator before unplugging the load this may happened. Try to put a strong magnet (like those from loudspeakers) in contact with the body of alternator. I do this in the past and it work.If you do not know how to do this ask an electrician, he can help you .
Sep 30, 2010 | Guardian Rv Generator 4800 Watt, Gasoline,...
Generac NP 50G Stops after 2-30min.
check the oil sensor circuit. I know when I take out or short out the sensor ckt on mine, it'll keep on running. low oil isn't good for any motor.
Oct 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
2008 Gaurdian Generac 3cyl diesel shuts off after hitting bump
If you dont find a solution here. Call Generac in Waukesha WI. and get the number for Robert Schwalm Co. He is the best in the Country for Generac I used to be #2 but I havent worked on all the new Generacs. Give me an old RV unit and no one is faster!
May 20, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Have a 16k propane guardian generator have to manually start and
Is this an RV generator?
If you have to really choke an LP engine but it runs more or less normally once started you need to troubleshoot the demand regulator and the fuel supply lines (look for air leaks). I'd also check the fuel inlet pressure before the demand regulator.
Rate me,
Carl
Nov 19, 2008 | Guardian Rv Generator 4800 Watt, Gasoline,...
Electrical Supplies Logo
189 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
