Question about GE JVM1650 1000 Watts Microwave Oven
How do I remove the keypad on JVM1540?
I need to remove the keypad on my GE JVM1540 Microwave, but I can't tell what screws, tabs, etc. are involved. Can anyone describe the steps to remove the keypad? I'd like to try cleaning out the connectors and stuff to fix a problem with the keypad (seems to be a short).
    New Friend:
Remove the air grill first. Should be a couple of screws. Then you will see one screw holding the keypad in on top. Take it out and it will tilt forward. Make sure you unplug any power source first before you try removing any screws. Once you have the keypad leaning forward there will be some connectors holding the keypad in. Unplug those and lift the keypad up and out.
Posted on May 14, 2014
SOURCE: Cannot remove the front grill of GE Micro to replace filter
I have a new ge 1540 and needed to remove the grill to install the charcoal filter.
After removing the two screws on top, you need to slide the grill about 1/2" to the left. Then the grill will wiggle loose and can be removed.
Posted on Dec 11, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave Model JVM1540
If you mean the control panel, at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you mean the door, you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Feb 16, 2009
Richie_asg1
  • 1036 Answers
SOURCE: GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Posted on Aug 20, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: keypad not working after boiling water below
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Otherwise, the keypad may be damaged or worn out, or control unit may be damaged.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
Your full model number would be one of these: JVM1540DM1BB JVM1540DM1CC JVM1540DM1WW JVM1540LM1CS JVM1540SM1SS
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 10, 2010
  • 277 Answers
SOURCE: I have a GE Spacemaker Microwave Model JVM1540.
Rlfoster.
It is not a filter problem.. but a relay (electrical)
There is a electronic board that may becomming defective.
If there was a spike in the electrical it could have erase the memory,
You or I cannot reprogram but only replace the board. I don't the price of that board
Posted on Jul 24, 2010
Micro is three, front panel not responding
If I understand you, the front keypad is not responding. In that case you will need to replace the keypad control board.
Apr 08, 2012 | GE Spacemaker JVM1540 Microwave Oven
We have the same F3 problem with our rangetop microwave. ..GE JVM 1650. We have a replacement keypad that a repairman ordered 2 years ago but did not need. How do you remove the old keypad and install...
Hi, I have a jvm1631 modle that looks like yours,on mine you need to remove the grill on top and then you should have a screw above clock,remove screw and lift up and the whole assemby will pop off.Then you will see tabs all around edge that you psuh in to remove plastic cover then you can unplug all wire harnesses and replace keypad. Just remember to unplug M/W first.Hope this helps.
Mar 05, 2011 | GE JVM1650 1000 Watts Microwave Oven
Touchpad doesn't work on ge model #jvm1540sn1ss
The membrane keypad has failed.
The keypad itself is not available as a separate part, so the control panel frame with keypad would have to be replaced.
This is actually a pretty simple DIY job.
You can part number WB56X10826 from the Pros here for $114.62 plus shipping (that compares to $166.50 from GE!).
You can also find helpful exploded view diagrams at that link.
Then disconnect your keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
May 24, 2010 | GE Spacemaker JVM1540 Microwave Oven
Touchpad isn't responding. GE JCM1540 the touchpad isn't working--stuck at "press clock"
I'm guessing that full model number would be JVM1540xx###?
But in any case, you have a failed membrane keypad.
On JVM1540 models, the membrane keypad the membrane keypad is not available as a separate part, so you would have to order the control panel assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Here are the proper model number formats in this series:
JVM1540DM1BB
JVM1540DM1CC
JVM1540DM1WW
JVM1540LM1CS
JVM1540SM1SS
May 22, 2010 | GE JVM2070 Microwave Oven
Having trouble removing front grill to install filter..removed top screws but grill will not come loose
Just installed a GE Spacemaker - my instructions tell me to remove screws and then slide grill to the left and then remove. Have you tried that?
Jan 05, 2010 | GE Spacemaker JVM1540 Microwave Oven
GE 1540 handle...bottom fastener is broken. How
remove w putty knife the inter face. you can see the screws at this point ,. just remove screws and reinstall handle . pop interface back in **** . you can get a brake down of how this fits on sears web sight . **** / hope this helps ( it;'s not a hard job /time 1/2 hr / mm .
Dec 22, 2009 | GE Spacemaker JVM1540 Microwave Oven
How do you install the charcol Filter?
Take out the two screws on the top as directed, then slide the grill to the left about 1/2". Then pull it toward you.
Sep 16, 2009 | GE Spacemaker JVM1540 Microwave Oven
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
286 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
