Question about HP LaserJet 5200 Printer
HP 5200 prints light at beggining of page then prints normal.
I having problems with a HP5200. Prints light for the first 3 inches and then prints normal. Tried new toners. Cleaned laser. Econo mode is off. Need direction on want could be causing this.
  • HP Master
  • 1,121 Answers
Print half way test page.,chk leading edge is same as you noticed?..
If yes: Chk transfer roller, clean it, chk side locks..if required replace it..
If no: chk fuser Teflon sleeve., is there toner deposits in surface? Replace Teflon sleeve if available or else replace fuser assembly..
Half way test page:
browse: http://www.printertechs.com/printer-troubleshooting/halfway-test
Posted on May 14, 2014
  • 66 Answers
SOURCE: HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
Posted on Jan 02, 2009
  • 81 Answers
SOURCE: HP color laser 2550l prints only yellow
Are you sure that none of the other colours are empty? If they are then this could be the problem
Posted on Jan 03, 2009
SOURCE: I have an HP 2015 laser printer and It has started
stake problem
Posted on Dec 04, 2009
KingDWS
  • 1606 Answers
SOURCE: Bad Printing and Stripes on Printed Sheets on HP 1100A
It isn't a fuzer problem it is most likly a image drum problem. To fix you have two choices replace the image drum with a oem part or a refurbished part or replace the printer. sometimes it is cheaper to get a replacement printer than to replace this part.
Posted on Dec 30, 2009
My HP 5200 printer prints very light as if its cartridge is low while its toner is full, this problem was present from the very first day i purchased it, changed toner cartridge but no effect, (meaning no...
Try changing you Print Quality Settings.
1. Go to your Printers and Faxes(XP), Printers(Vista), Devices and Printers(Win7) 2. Right Click on Your Printer Icon 3. Click on Printing Preferences 4. On Print Quality, Choose Best. 5. Under Features -- Check the box for Print in Maximum DPI.
I hope this helped a little :)
Feb 04, 2011 | HP LaserJet 5200 Printer
HP laserjet 5200 printer taking too much time to print a page..
HP 5200 prints 35 pages/minute, however, system configuration and software reduces print speed. So, If there are no changes in those parameters, you're document is too complex to print quickly.
Try to send a test or a text page to calculate the difference.
Also bare in mind that first page takes longer to print due to printer heat-up procedure.
Nov 09, 2010 | HP LaserJet 5200 Printer
Dec 30, 2009 | HP LaserJet 1100 Printer
Because my Deskjet 932C wasn't printing at all, I downloaded a new driver for it from the HP site. Now it prints but prints only the top portion of a page -- sometimes about 1.5 inches, sometimes 3 inches,...
I would recommend uninstalling the installed driver from your system, disconnect the USB cable (if one is installed), reboot.
Once the system comes back up, turn off your anti-virus. Now install the printer driver again. Install the USB cable for the printer (if that's how you're connecting) and finish the install.
Re-enable your anti-virus.
Aug 29, 2009 | Office Equipment & Supplies
Hp5200
how to open the printer
Apr 06, 2009 | HP Hewlett Packard LaserJet 5200 Printer
C6180 printing slow
This could be from the image you are printing. If you are printing from a computer or memory card, the dpi (dots per inch) may be higher than some.Standard printing is typically 400dpi, and you can change the settings on your computer or the printer directly. Memory cards and some photos from your computer may be 600dpi and will likely take much longer to print since there is more "color information" that it is trying to fill.
Let me know if this helps.
Jan 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
I wish to download photos from digital camera finepix, to subsequently print using my HP5200
in hp laserjet printer 5200 how to open the for replacement of teflon sheet problem
Aug 01, 2008 | HP Office Equipment & Supplies
HP PSC 2210 Vista prints part of page
Call HP tech support - they walked me through an easy work-around that solved this problem for me.
Dec 06, 2007 | HP PSC 2210 All-In-One InkJet Printer
73 people viewed this question
Seeker5211
Seeker5211
