How to disable blue touch pad on dell lat.d820
Arrow jumps around ,letters get mixed up ,bad function.
    Scholar:
    New Friend:
  • 92 Answers
Try going to Control Panel and look for a touchpad icon. Failing that, there might be one for "input devices". Once there you should be able to disable the touchpad and activate a mouse.
Posted on May 13, 2014
jmgldsmth
  • 1869 Answers
SOURCE: disabled touch pad
you must re-download and, re-install the driver software again
Posted on Apr 29, 2009
Demmy
  • 59 Answers
SOURCE: sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Posted on Oct 02, 2007
  • 630 Answers
SOURCE: I have a Dell XPS M1710 laptop. The touch pad does not work.
Unless it is a hardware fault open the control panel>system>mice and uninstall the touchpad. Then rebott. It should solve the problem.
Posted on Jul 25, 2009
  • 7993 Answers
SOURCE: can't disable touch pad
Windows hides rarely used icons. If your does, then the task bar shows a left pointing arrow < . Click it and look for the icone for touchpad.
If you cant find that icon,
In WINDOWS XP
1. Start
2. Contol Panel
3. Right click the Mouse icon.
4. Under the Touchpad ON/OFF thumbnail, put a check mark in the disable option.
5. Use the same procedure to enable touchpad
Posted on Aug 22, 2009
anjana03
  • 361 Answers
SOURCE: how do i disable double click on my dell touch
go on control panel.look mouse settin and correct it according to your choice.
Posted on Oct 09, 2009
How to disable touchpad
how to disable blue touch pad on dell lat.d820?
Jan 01, 2014 | Computers & Internet
My typing keeps jumping around on my Dell vostro 2520 laptop, shut on internal pad but still jumps around with my Logitech mouse
Regular answer for this problem is to update BIOS / Touchpad drivers. Since you have already disabled the internal touch pad, can you also check if you have a track-stick that needs to be disabled. That should fix your problem!
Drivers available on Dell's award winning support site :)
Oct 12, 2013 | Dell Vostro 1510 Laptop
The cursor jumps backward in text. It jumps several lines up and down.It also does not respond to a simple left tap when I need it to open or close wish to delete something. I am not accidently doing...
Replace the mouse with a known good working one.
If you are not using a mouse (bad news) the touch pad may be failing.
In that case, an easy test and fix is to disable it in "Control Panel" then install a mouse in the USB Port.
If the problem is corrected then it is your touch pad.
Here is a link to the manual from Dell. FREE!
http://support.dell.com/support/edocs/systems/ins6000/en/om/D5181bk5.pdf
See Page 42 on disabling the Touch Pad.
Go to EBay and insert "6000 Dell Inspiron touch pad". It's cheap but difficult to replace.
Jul 24, 2011 | Dell Inspiron 6000 Notebook
The arrow on the mouse kepts junping around ?
You are probably using a laptop with a touchpad. What is happening is that your thumbs are touching the touch-pad as you type and the cursor is jumping around. Solution: disable your touch pad. You can go to Start > Control Panel > Mouse > Touch Pad > Disable
Another solution is to go to the Dell website > Support and Drivers > download and install the Synaptics Pointing Device driver and disable your touch pad using the options in this new driver.
Oct 15, 2010 | Dell U0636 Mouse
Jumping letters on acer laptop when I type
You need to disable the touch pad while typing. During typing your palm can accidentally touch the touch pad causing the cursor to 'jump' randomly resulting in the problem.
You have not mentioned the model but on Acer laptops there's a key in the upper row with a 'pad and finger' figure on it. If the figure is in blue, press Fn together with the figure key to disable the touch pad and then again to enable it.
Mar 31, 2010 | Acer Computers & Internet
It jumps around the screen when I'm typing
you may be touching the touch pad while resting your thumbs. this laptop does not have a key to disable the touch pad.
Nov 18, 2009 | Dell Inspiron 1521 Laptop
How can I lower the brightness of my screen in my Dell 1525 lapto
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Jul 28, 2009 | Dell Inspiron 1525 Laptop
Need to disable touch pad because when i type letters go all over the place...on different lines and between word i already typed
Yes, this happens when you have a mouse connected to a laptop. I had the same problem .... was worried I had a serious problem. But when I disabled the touch pad, everything was fine!
May 18, 2009 | Averatec 3200 Notebook
Pointer jumps around on screen when touching touch pad
hello, have you tryed adjusting the sensitivity of the touch pad to a less sensitive touch ?
Mar 31, 2009 | Acer Aspire 5610 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
