Question about Casio Watches
Casio how to change a battery - Casio Watches
My Casio WV-58A keeps losing time and date.I reverts to date 1-1-2005 . This is my third wave-cepter. Is there any to fix this malfunction. This watch is just over two years old.
Try the battery first. Make sure to do the all reset inside of the watch after changing the battery. If it is not the battery send it to Casio. They may change out the complete module.
Jan 17, 2018 | Casio Watches
How to change battery casio amw 330
According to their site, they don't want you replacing the battery. The battery is a silver oxide type, and the number is sr927W. You can find one with a google search. I'm including a link to a youtube video for 320, which might be close enough. If it is, you'll need a tool they mention that they say costs $6 How to change the battery on Casio AMW 320R watch
May 24, 2017 | Casio Watches
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
How do I replace the watch battery for Casio DW-6900?
mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
Aug 27, 2010 | Watches
I need to change a battery in a baby g watch
mcdevito75 here, Casio watch with the LCD display, any wrong pressure on this display and your Casio is ruined, the liquid display can break very easily. BEST BET, look for a small watch repair shop in your area for this battery change.
Jul 14, 2010 | Casio Baby-G Wristwatch
My Casio watch Battery was just changed now I can
mcdevito75 here, Return to where the battery was changed, for adjustments.
Jul 12, 2010 | Casio Watches
SET AFTER BATTERY CHANGE
You need to follow the instruction manual after changing the battery.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
Feb 07, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I have a Casio DBC-60. I changed the battery because was not working for long time, but the watch stil is not working
This is an old problem, but maybe this will help someone changing a battery on a Casio. Many Casio watches must be "zeroed out" by putting an pointed tweezers between the back of the battery and the AC terminal off to the side of the battery. On my old Casio Telememo 50, the AC terminal is in a very small hole just above the battery. On the Baby G force, it was in a wider opening, way at the edge of the watch. It has something to do with resetting the watches circuitry so it will operate again. Good luck!
May 14, 2009 | Casio Watches
Casio G-Shock GW-300 2608
Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
After changing the battery I can now press the light switch button and the watch works normally.
Tony
Feb 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio Databank watch
The replacement battery may be defective.
Nov 08, 2017 | Casio E-DataBank DBC3101 Wrist Watch
Watches Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
