Sony tc 260 reel reel
Stuck on high speed
  • Audio Player... Master
  • 1,267 Answers
This is because the unit has hard dried up grease in it and needs to be taken apart and cleaned out and new Lubriplate 105 grease applied as that has never been known to dry out at least not in the 40 years I have been working on these. These old Sony unit usually require 3-5 hours to get them working again. Better off buying a restored Teac A2300S, SX or SD.
Posted on Jan 02, 2015
robotek
  • 1512 Answers
SOURCE: Repairing or replacing old tape decks
Hi m522posner
There is a surprising interest in "vintage" hifi products these days. Your tape machines probably needs new belts. Check this site out. You can get spares for your tape machine here. Belt kits are $17. He does repairs also, but the transport to and from may be an issue for you. I suggest emailing Bob, he may be able to refer you to someone in CA > I could do the repairs,but I am in Australia. :)
Vintage Electronics
P.O. Box 941
1241 Conestoga Creek Rd
Florissant, Co 80816
Email: Bob@Vintage-Electronics.cc
You could have a go at freshening up the belts yourself:)
regards
robotek
Posted on Jul 12, 2008
SOURCE: Sony reel to reel TC -765
I too had this problem with my tc765. I found the two pinch rollers were not lifting up and fully pushing the tape against the rotating capstans in the play/record mode. Solution to my problem involved partly dismantling the pinch roller assembly, cleaning off the old solidified grease and re-lubing with a molybdenum grease. Note: the top plate has to come off first,then the rotating guides and tensioning pegs. Then the cast head cover and flap. It was a time consuming operation, but well within the scope of competent DIY in my opinion.
Posted on Aug 20, 2009
vanderlinden
SOURCE: Sony TC-255 reel to reel Tape won't turn
you need to have a tape in place on the reals or it will stop.Hold the tape feeler spring in place and prevent it from moving forward it is located on the left side just remove the SONY stereo tapecoder cover and you see it
Posted on Dec 11, 2009
robotek
  • 1512 Answers
SOURCE: My Sony TC630 reel to reel recorder, is playing at
Hi there
MOst tape drive problems of this nature can be directly attributed to failing belts and idler drive surfaces. If you are a bit of a mechanical gun, you could overhaul and resolve this problem yourself. You can get a belt kit to freshen up the deck from here
Replacing them may be a little daunting if you are not mechanically minded, but within the realms of most home DIYers. Happy to help you with advice and answer any questions you may have if you choose to go this way. Cheers
regards robotek
Posted on Jan 11, 2010
Testimonial: "Thank you for your very kind help. I shall try replacing the belts first. Kind Regards, wilf"
  • 9 Answers
SOURCE: I have a Sony TC 630 Reel to Reel Stereo
Sounds to me like your Sony has a common problem among vintage reel tape decks..dried /frozen grease/ and or a lack of lubrication. carefully apply a tiny bit of fine lube oil, like 3in1, on the swing mechanism that carries the pinch roller...(you may have to remove the front metal deck face to fully access the swinging pinch roller mechanism) ) . do NOT get any oil on the rubber pinch roller..(best to make sure after by scrubbing the pinch roller surface with a cotton swab lightly dipped in non chemical household cleaner, like 409, or awesome orange i get at the dollar store. Then use the dry end of the swab to ensure the pinch roller is dry. .The pressure pads should swing upward and press the tape against the heads when in play/record mode..if they do not swing up, they are binding/ or out of adjustment....they are spring loaded so when the reel deck is in the stop position the spring loaded pressure pads are held down...play/record mode releases them to freely swing up and press on the tape against the heads.
Posted on Jun 08, 2010
Sony taperecorder TC-355 will only run in fast forward. when trying to play in any speed tape moder went into fast forward and would not play tape.
If the speed-controlled roller is not closing to pinch the tape when PLAY is selected, the recorder will play in a fast mode. You will need Isopropyl alcohol, contact cleaner, Q-tips a screwdriver needle-nose pliers and a steady hand to clean every moving part in that Reel-To-Reel and then lightly lubricate the moving parts.
While you are in there I would change the belts as well. Or send it to a qualified repair shop and pay $ 125.00 to $ 200.00 for same thing to be done. Take your time, it's just a big puzzle, make sure you video or document everything you remove so it goes back together correctly. Good Luck!
Nov 11, 2016 | Sony Audio Players & Recorders
Is there an internal speed adjustment to fix tape speed selector that has no affect on tape speed. This is on Sony TC-440 reel to reel.
There is a cam with solidified grease on a lot of Sony Mechanisms. The deck need to be cleaned of the grease they used that solidifies and then a better grease such as Lubriplate 105 should be applied.
The Idlers need to be reconditioned as well. The Sony units can be labor intensive due to this required work but I do fix them when people want them done. I am in the Chicago area as Skywave Tape Deck Repair
Jun 08, 2015 | Audio Players & Recorders
Where can I find an owner's manual for Sony TC-355 tape recorder
Hi Cloise,
Go to HIFI engine at this link. Sony TC 355 Manual Stereo Tapecorder HiFi Engine .
Here is the TC355 page. Sony TC 355 Manual Stereo Tapecorder HiFi Engine
You must create an ID and Login to obtain the free download.
Fare. Well.
Dec 12, 2014 | Sony Audio Players & Recorders
Sony TC 330 reel to reel tape recorder. Tape will rewind and fast-forward but will not play. I think a new drive belt might be needed. How do I check?
REEL TO REEL RECORDER SONY TC 330 - on back side of the set voltage selector knobe is lost,so how can i fix it ?
Oct 15, 2010 | Sony Audio Players & Recorders
I have a sony TC-660 reel to reel player, it had been in great condition, and i love using it. All of a sudden however, the reels will ONLY move in one direction (clockwise for the left, and counter...
In order to maintain tape control and tension the reels always pull lightly in opposite directions during PLAY mode. The capstan moves the tape in the desired direction at a precise speed. If the capstan doesn't engage the tape BETWEEN itself and the pinch roller you'll get the reels battling over control of the tape. Check the tape routing.
May 25, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
I have a sony TC 530. Fast fwd and rewind work
You need to replace the motor run capacitor. It's a small aluminum can looking thing with three wires right next to the motor; they often leak paraffin wax into the bottom of the case when they overheat. Whether or not yours has leaked it's easy to replace if you can use a soldering iron. Search eBay for a Sony reel to reel 1.5uf 250VAC motor run capacitor - they're less than $15 and come with detailed instructions.
Please wait Image not available
Jun 14, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
Slow tape speed on reel to reel tape deck
My TC-230 has the same problems and it is mechanical. Actually, its real hard to say what your problem is, but it is most likely the pinch roller is to tight on the piece that is connected to the motor. This extra tension is from a spring inside the machine and, when in storage for a long time with the machine set to stop, extra pressure builds up on this spring. Try leaving it unplugged on fast forward/play overnight. that might help.
May 08, 2009 | Audio Players & Recorders
Sony Reel to Reel preamp board.
Did you ever get your schematic? I recently got the Model 260 and it has the original owner's manual. I could try scanning the page for you, if you still need the info (if you think that would help you).
--Dave
Mar 28, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
Sony TC 530 tape speed problem
If it's slightly faster than normal, that's fine. You'll just need to check the rollers and tighten them slightly as well. They might be loose or sort of that.
Dec 26, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
147 people viewed this question
 Grubhead
Grubhead
