Question about Canon PowerShot A560 Digital Camera
How to replace, Canon Powershot G10, Digital Solution Disk
  • 30 Answers
SOURCE: Canon PowerShot A540 Digital...Problem
To view the pictures on the computer, remove the card from the battery compartment and put it in a card reader connected to your computer.
Posted on Mar 25, 2008
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
Only for the brave, on a warrenty expired camera.
Buy a set of jeweller's screwdrivers.
Make sure it is off, with the lens retracted, and remove the battery and SD card.
Remove the 11 screws holding it together
The metal shell is in two halves that can be pulled apart. The rubber socket cover flap has to be removed once one half is off. A rubber gasket round the eypiece lens may drop off - it is easily replaced.
Hold the inner chassis by the edges.
The lcd screen is held by one screw, half hidden under the wiring to the flash - remove it.
Push the wiring to one side just sufficiently to enable you to hinge the lcd screen up on its flexible printed circuit wiring loom.
Underneath you will see the back of the ccd pod, with a flexibe printed circuit wiring loom pinioned under a metal plate with two Y shaped holes filled with brown gunk, and held down by a torex screw locked with some holt melt adhesive, and two further screws inaccessible under the metal chassis to the right.
I hypothesised these were the contacts that become detatched in hot conditions, and (1) tried to shift the flexible printed circuit minutely from side to side using the hole in it (it didn't move appreciably)and (2) pressed down quite hard in the centre of the metal plate, having supported the chassis from below so as not to damage the lens.
I reassembled the whole thing and it worked immediately, with just a faint light smear down the left hand side of the image (the whole image had been completely smeared, then dark, before) which was only noticeable when photographing in dark conditions.
So I took a gamble and it seems to have worked. If it hadn't I was going to break the glue seal on the Torex screw and unscrew and then screw it up again.
Obviously doing this is on your own responsibility.
Posted on Oct 25, 2008
SOURCE: Replacing a part on my Canon PowerShot A610 Digital Camera
is it the same Powershot A540 as well?
Posted on Nov 11, 2008
ginko
  • 19396 Answers
SOURCE: lost installation disk of my canon digital camera
Download the software from Canon Website here:
Official Canon Drivers and Software
Posted on Nov 30, 2008
dlundmark
  • 797 Answers
SOURCE: how do i replace the lcd window glass on a Canon G10
This may not something you want to do.
What is wrong with the LCD?
Here is a page at Canon which may be your problem.
These cameras, if the problem exists, will be fixed by Canon for free!!
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=222&modelid=17624&keycode=2112&id=57370
Posted on Aug 23, 2009
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
HOW DO i RESET MY CANON G10 CAMERA SO I CAN TAKE PICTURES?
There is no magic reset button. You need to take it in or send it in for service.
CANON G10 Google Search
The best telephoto lens for this camera?
Canon G10 - Ken Rockwell
www.kenrockwell.com/canon/g10.htm
Oct 20, 2008 - The Canon G10 is the best compact digital camera I've ever used, ...The G10 is a regular Canon Powershot point-and-shoot, in a tough ..... On the G10 theISO dial moves under the mode dial to make room for ... Neither the G10 or G9 have true zoom lenses; they only change focal length in discreet steps.
Canon PowerShot G10 Review ' Digital Camera Resource ...
www.dcresource.com/reviews/canon/powershot_g10-review/
Nov 24, 2008 - Is the PowerShot G10 the ultimate compact camera? ... Telephoto lens, TC-DC58D, From $109, Boosts focal range by a factor of 1.4X, ..... For bestresults, you'll want to attach one of the Canon Speedlites I mentioned back in ...
Jan 01, 2016 | Canon PowerShot G10 Digital Camera
G10 how can i restart the camera?
Go into settings and scroll down, then click reset. You can manually reset it by replacing the sim card or pressing the button inside of the area wher the sim card is.
Jun 13, 2014 | Canon PowerShot G10 Digital Camera
Canon G10 screen broken showing coloured jagged lines. Can it be fixed?
Yes. If you want to do the replacement yourself, you can order the part here.
May 11, 2012 | Canon PowerShot G10 Digital Camera
Canon G10 screen broken showing jagged coloured lines. Can I fix it?
How can I turn o the date stamp on my Canon G10?
www.canon.com.au/~/.../DSC%20-%20PS%20G10%20Tech%20Sheet.ashx
Mar 26, 2010 | Canon PowerShot G10 Digital Camera
Canon G10 flash recharge very slow at 10sec. Any way to make it faster?
Has it always been this slow? Are your batteries fresh and charged?
Oct 22, 2009 | Canon PowerShot G10 Digital Camera
How do i replace the lcd window glass on a Canon G10
Aug 22, 2009 | Canon PowerShot G10 Digital Camera
Canon PowerShot A560 Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
