Help - I am unable to work out how to post a commemt without leaving a picture
UNABLE TO TEXT PHOTOS OR RECEIVE PHOTOS
images for UNABLE TO TEXT PHOTOS RECEIVE
Unable to send MMS (pictures via text) - Android Forums at ...
forums.androidcentral.com > ... > More Google Devices > Google Nexus 4
Jul 3, 2013 - 10 posts - ‎8 authors
I've notice I have not been able to send MMS picture messages ... I've downloaded Handcent SMS and now I can at least send/receive MMS. New Samsung Galaxy s5 unable to send or receive text ...
May 14, 2014
Unable to send pictures in text messsges
Jan 25, 2013
Unable to save picture received via text
Mar 17, 2012
Unable to send or receive picture messages
Oct 20, 2011
More results from forums.androidcentral.com
Nov 17, 2015 | Cell Phones
When on the wall of Facebook and I look at pictures or photo albums that have been posted, I am unable to exit from them. I hit the X in the top right hand corner of the pictures but nothing happens. I...
When you're looking at pictures, you can just click around the area of the picture viewer, and that also gets out of the pictures. For example, click to the right of the pictures viewer's black box, and then you can go back to using Facebook for other things, without having to close the window.
Aug 21, 2011 | Facebook Social Network
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
Monitor does awake from sleep mode
You need to check the inverter fuse, transistors, caps, solder joints. Please see my pictures here to get some ideas so you will know what to look for inside.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Please post back.
Replacement board: http://www.lcdrepair.us
Apr 27, 2010 | Dell E173FP 17" LCD Monitor
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Can`t pair to Bluetooth in Lexus RX 350
make sure both bluetooth devices are in pairing mode.
go into your phone settings and find bluetooth, add device and pair
Here is a video on youtube that explains how to do in without navigation from the talk button on the steering wheel.
Click here to watch the video
You will find many great videos regarding this subject in youtube.
do a search for pairing bluetooth lexus rx350
if this post helps please leave a vote on fixya
May 23, 2009 | Samsung Cell Phones
Unable to chat on AIm with camera that is already set up
Which ever Messenger or Skype you are using has to be setup in order to function. Same way wih AIM. Normal 0 I'll assume that you are using YAHOO MESSENGER and walk you through the setup. All Messengers and Skype have an Audio & Video setup in them so the camera and microphone work properly with their program.
Bring up Yahoo Messenger and on the top left click on MESSENGER.
Then click on "Messenger Preferences."
Next in Category click on "CALLIN & DEVICES."
When that comes up check and check to see that Microphone is set to your audio card.
Next insure that the speakers are set to you audio card.
Then go to "Test Audio"
In Blue "Open the call setup Assistant"
When the window opens follow the instructions. When finished your camera audio should function properly.
Also you need to go to the Video setup and do the same so it will broadcast the pictures.
Hope this helps. Bud
Jan 05, 2009 | Microsoft LifeCam VX-6000 Webcam
Pentax K10D picture blinks in playback mode
I don't know, pentax is not fimiliar to me. Please ask anoter expert or post your problem to all to see.
Please leave this solution without a rateing, thank you.
May 26, 2008 | Cameras
The Picture is too big for the tv screen
Try your format button... or your wide/size button... they're all a bit different but they all have different screen size capabilities.
hope this helps
Nov 20, 2007 | Sylvania 6420FB 20" TV
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
