Question about Casio Watches
Forester casio ft 600w
Before opening this watch up, what kind of battery does it use.
  • 3422 Answers
SOURCE: Casio Wave Ceptor 2296 watch battery replacement
yes, what they said is right and will cost upto $30 and can only be fixed by them.The problem is not wid ur battery it is wid some other parts also inside it..
Since they are professional technicians for casio they charge that much.i suggest u to go for it..
Goodluck..
please don't forget to rate me as fixya..
Posted on Feb 02, 2008
escapement
  • 2334 Answers
SOURCE: need directions on how to move analog hands on
Check out my tips here and find the instructions manual for your watch.
Posted on Feb 07, 2010
mcdevito75
  • 1970 Answers
SOURCE: My old brother has A old casio watch illuminator
mcdevito75 here, Most likely 2 batteries. 1 for the illuminator on top once you remove the cover and 1 for the time mechanism.
Posted on Jun 30, 2010
mcdevito75
  • 1970 Answers
SOURCE: My Casio watch Battery was just changed now I can
mcdevito75 here, Return to where the battery was changed, for adjustments.
Posted on Jul 12, 2010
  • 10 Answers
SOURCE: casio says open
Check YouTube video for battery replacement process
http://www.youtube.com/watch?v=ogCz2vjUKVg
Posted on Jul 14, 2010
What is the battery number for the casio ft 600w?
CTL1616 and there is a video on you tube showing you how to do it.
I assume this is the casio Forester.
Oct 02, 2017 | Casio Watches
Casio forrester date will not change
https://www.youtube.com/watch?v=I9VGeriSTOI CASIO FORESTER
Jul 12, 2017 | Casio Watches
Battery
The Casio Forester FT500WVB watch has an EL (Electroluminescent) backlight and requires one silver oxide button battery. The SR621W battery (also known as type 363) is recommended by the instruction manual for the watch. Note the suffix "W" means this battery is a high drain type which is suitable for powering a watch mechanism and the EL light as well for 2 to 3 years, depending on use of the light. "SW" suffix batteries are low drain and are intended only to power a watch mechanism, and not a light. Note also the "SR" prefix indicates the battery is silver oxide and not lithium. The SR type batteries do not use mercury and are therefore safer to dispose of when they are discharged. I have found the type SR626W (also known as type 377) battery is also suitable for the FT500WVB watch and it has more stored power and should therefore last longer.
Last, the Casio Forrester FT500WC looks exactly like the FT500WVB, but it is a different watch internally. The FT500WC has an LED light and requires two batteries- the SR920SW low drain silver oxide battery which powers the watch mechanism and the CR1616 lithium battery which powers the LED. The LED is brighter than an EL light and stays on longer than the EL light when activated. But the LED has a bright dot light source that some might find annoying.
Apr 17, 2014 | Casio Forester FT500WV-3BV Wrist Watch
Casio prt 41
If you have that kind of problem with your Casio Watch, there are 2 possible problems here:
-Battery is leak
-They did not reset the watch properly if the battery was replaced.
Best you can do is take it to an official Casio dealer, they will handle your Casio watch properly.
You can find any spare you need for your Casio in our website. At TicTacArea.com we are official Casio dealers and we will be glad to help you with this and any other problem you may find related to your Casio Watch. Casio Watches Casio Multi Task Gear Watches
Apr 10, 2014 | Casio Watches
How do I set the analog time to correspond to the digital time?
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Aug 05, 2010 | Casio Forester Watch AQF100WD9BVCF
What is the main internal assembly of the Casio forester watch called? Replacing the battery does not work.
mcdevito75 here, The Internal workings of all watches and clocks, Quartz and mechanical is called the movement. You may have a weak or even dead battery, even if the battery is new. If you"ve dropped your watch, got it water logged, you could have hurt the Quartz movement. It'll take special equiptment to check the Quartz movement to see if it"s burned out. I would try another battery or at least double check this batteries instalation in your watch. For more info, here is Casio"s contact number, 800-435-7732 9AM--5PM EST.
Aug 03, 2010 | Casio Forester PAS400B-5V Wrist Watch
Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
My old brother has A old casio watch illuminator does it hav only one battetr or two. Has forester on the outside above the watch face
Jun 18, 2010 | Watches
Need directions on how to move analog hands on casio forester watch 1737
Feb 07, 2010 | Casio Watches
Instructions for my Casio Forester Illuminator 600
Check on back of watch for 4 letter module code and downlaod manual on Casio website.
Nov 10, 2008 | Casio Watches
Watches Logo
102 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
