Question about Ricoh Aficio MP-201 Copier w/ Duplex Document Feeder MP201
Side tray jams internally
Copier runs fine with from the regular drawer but jams every time from the side tray when using 8.5 x 14 paper
  • 4 Answers
SOURCE: ricoh 2022sp internal tray 1
Where the paper comes out there is a little black thing that is supposed to stick out. Somebody has pushed it in.
Posted on Sep 01, 2008
20YrsCompExp
  • 227 Answers
SOURCE: Aficio Copier 1013 light on to load paper ( paper is loaded)
Check the paper end sensor, remove the tray, look inside of opening, at the top toward the right side, make sure there is an arm sticking down, wires are connected and the sensor is in place. Most common problem is the arm is dislocated or sensor out of position, See graphic 91009d0.jpg
Posted on Apr 15, 2009
Gunslinger
  • 62 Answers
SOURCE: My Ricoh Aficio 220 has routine paper jams. I
Needs new feed rollers in the paper tray. You can try and clean them but it probably will need replacing.
Posted on Feb 10, 2010
  • 32 Answers
SOURCE: Describe your ricoh aficio 2232c manual copier
just take a air blower and flow the area from where the paper comes out ur internal paper tray sensor is dirty
Posted on Apr 23, 2010
santosj27
  • 263 Answers
SOURCE: I have a Ricoh Aficio
This jam problems are always very difficult to solve without seeing the machine!
Because i need to see the jam location or take a report to see where the paper jams.
you say that it is on the Point C, but that just helps a little.
I can tell you that you have a problem in the duplex door (but you already know that). It could be several things like; transport rollers, gates, solenoids... well, the best help i can give you is to advise you to call your technical support.
See you!
Posted on Apr 30, 2011
Testimonial: "thanks for the help you could give! ill have to have a look to see what i can do"
Paper jam sign appears after first copy
if jam indicated but no paper is found. clean the roller that feeds paper out of the paper tray.also make sure paper guides are touching paper front rear and left side.
Feb 23, 2014 | Ricoh FT5832 Copier
I have a Richo 2035 black and white copier. Recently the copier has begun to paper jam...and its done frequent every time i clear the jam..it runs for a while maybe 10 copies and jams again. What can i do?
Not surprising - it may need some service. It is 7-8 years old. There are a few areas that could be affecting output. Most likely you need to replace the rollers that pick the paper out of the tray (3/drawer) -especially if the problem occurs with 1 specific tray. Try using another tray to isolate the problem
Jul 10, 2011 | Office Equipment & Supplies
Paper jams every sheet. Checked the paper weight, made sure it was faned edges and not rolled. Catches on the left side as it rools in from the drawer. What can I do to fix it. I have used it many...
Marie, there is something stuck between the paper tray and the transport section of the copier. Probably a small piece of paper. try to push a piece of paper up from the tray to the rest of the machine to push this obstructing paper out of the paper path. Also try using the handfeed section on the right hand side of the machine by folding down the tray and putting paper in it. You may have to choose this "manual" feed tray on the operation panel. Good luck !
Feb 20, 2011 | Canon imageCLASS D860 All-In-One Laser...
Copier keeps telling us there is paper jam, we have looked where screen shows jam and find nothing. We have taken out the paper tray, still don't find even a tiny scrap of paper anywhere.
There are several possibilities. After you inspect for the Jam and close the drawer, does the copier come to ready? Have you checked the behind the doors on the right side. If the copier comes to ready and you press the start button does the copier jam right away. If so check the dial on the paper drawer and be sure its set to the right size paper. If its not the copier will jam, right away. It is important with a Canon to check all areas and open both the paper drawer and the right side doors when checking for jam, if the right sequence is not followed in checking for jams the jam may not clear. If still Jammed you might take some canned air open the right side door and blow out the paper feed area, a sensor may be blocked or dusty. If all else fails turn the machine off and un-plug it from the wall, let it set a few minutes and plug it in and try it again.
May 20, 2010 | Canon imageRUNNER 2000 Copier
Minolta Di3510 indicates paper tray jam. I check the tray and open all jam clear areas but find nothing. Close everthing back up indicator goes away and when system starts to print again the machine...
Paper feed clutch is bad. I see this all the time. You can get the machine running by opening slightly the drawer that the machine is trying to feed from. Delete the current job and let the machine use the other drawer until you get it repaired.
The feed clutches in this series are small electromagnetic clutches and they do fail from time to time. Part# 9322-1500-12. Don't pay more than around $60 for the clutch. Here is a pic.
Good Luck and Thank You for using Fixya.
Apr 19, 2010 | Office Equipment & Supplies
11x17 paper jams from drawer - will not feed from sheet bypass
Check to see if the actuator arm is stuck in the bypass tray,therefore not seeing the paper and be sure the side guides are up against the paper. If that doesn't work and you have 2 cassette cavaties put the 11 X 17 where the other tray is . Hope it works for you.
Apr 09, 2010 | Office Equipment & Supplies
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
Printing crooked from one drawer, and no option to print from another drawer
Try this spray on a little WD40 on the GLASS and wipe it off.
Yes, you heard me correctly, make sure you wipe it off leaving no residue, but it's still slippery.
the problem may be coming from the glass being too dry and the paper is getting stuckand shifting.
If the paper itself was going crooked it would get jammed or ripped. There is no room for the paper to go through the path crooked so the only way for it to copy crooked is somewhere in the optics.
try doing 1-2 on the glass itself and see if it copies crooked.
The envelope tray is a By-pass tray and can be used for any size paper.You can switch which tray it copies from on the panel tray button.
Aug 28, 2008 | Canon imageRUNNER 2200
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
My printer jams frequently
More info is needed where does it jam ie. going to print from paper tray or coming out of the fuser in back before it comes out on top?
Feb 26, 2008 | Lexmark E330 Laser Printer
Ricoh Aficio MP-201 Copier w/ Duplex Document Feeder MP201 Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
