Question about Hayward H Series Millivolt 250,000 Btu Pool Heater H2501
My Hayward pool 350000 heater will light and stay lit and heat the pool for a while, but will just shut off including the pilot light. When I re-light it it works for a while again and then shuts off again. Can you help me? Is there something that I can do before I have to call someone to come and look at it? Thank you, Ron
  • 15 Answers
Sounds like the pilot assy needs to be replaced. It has 2 functions one is to light the main burner but also to let the system know that the burner is lit. If it thinks the burners are not lit it turns the gas off
Posted on Jun 23, 2009
Why will my hayward h 250 millivolt pool heater pilot light not stay lit
Looks like your pilot generator may have some corrosion on it. Follow the stainless steel tubing on the gas valve as it goes down to the burner area. At the end of this is the pilot assembly. If you can remove this so your able to work on it you will se a short metal rod that the pilot flame touches when lit. This generates current that keeps the gas flowing to the pilot to keep it lit. Take some sand paper and give it a light sand to remove any corrosion on it. Reassemble at put it together. You may also need to clean the pilot tube(stainless tube from valve). Small spiderwebs can reduce the flow to the pilot and cause this problem also
Jun 25, 2014 | Hayward 250kbtu Ng Pool Heater - Inground
Hi I have an Hayward H Series pool heater and the pilot doesn't stay lit when I depress the control to turn it on. Any quick solution for that ?
Check the thermocouple that the pilot light heats up. If it is not working then the gas to the pilot will not stay on.
Jul 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward heater not staying lit
possibly poor pilot adjustment or insuficient mv output from thermopile
Jun 19, 2009 | Hayward H Series Millivolt 250,000 Btu...
Pool heater starting
What type of heater is this, millivolt or electronic, is there a standing pilot if so will pilot stay lit, if pilot does not light you may have an obstruction in it which needs to be cleaned.
as well as checking gas orifices for blockage
May 31, 2009 | Hayward Pool Products Hayward H-Series...
Pilot did not stay lit,replace gas valve , pilot stays lit,but now it won't fire up. Jumped the TH terminals and it shut off the pilot light.thermostat is set highier than the water temp.Jump all ths...
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H250 (millivolt) pilot won't stay lit
make sure the flame hits the thermo couple if so then replace it lows has them in the water heater section thermo couple gets hot makes millivolt signal then opens gas valve
May 08, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hayward H Series Millivolt 250,000 Btu Pool Heater  H2501 Logo
298 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
