Question about LGDVT418 System
My lgdvt418 is 10 years old and won't put out sound. How do I fix this problem without buying a new system?
My lgdvt418 is 10 years old. It seems there isn't enough juice to put out sound. Shows that the unit is on. But no sound. It's been doing this for last few months. Turn the volume up to 11 out of 40 and it used to kick on. Put below that mark after it started working and sound cuts out. Now it won't even do that. How can I fix this and not have to for over $$$ for an entirely new system???
SOURCE: Digital Reciever Issues
Had same problem, fixed it by turning off at wall, wait 30sec, unplug antenna, turn back on, will say poor signal, click to another station at this point, should change OK. Switch all off again, plug in antenna, start up as normal, should be fixed.
Posted on Oct 01, 2007
SOURCE: my plasma tv picture is green
take off back panel and adjust the V12(A) adjuster wheel on the power board it adjust the gas flow to the screen is should light up your screen
Posted on Jan 06, 2008
  • 9 Answers
SOURCE: display screen says "Er ff"
LG's bottom mounts have had problems with air leaks in freezer making a iceball right under the evaperator fan actually coming close enough to the fan blades to slow them down or stop them all together also causeing the FFerror meaning the control board is not detecting the normal RPM's you should to keep it cool enough. Suggestion take the back panel off and remove any ice carefully if this be the problem. Make sure all doors are closeing tightly and gaskets make a air tight close.
Posted on Jan 20, 2008
SOURCE: Nothing seems to work
am also facing the same problem
Posted on Jul 18, 2008
ngfam1
  • 639 Answers
SOURCE: Fan Works But Unit Can't Start Compressor
Friend,
NGFAM! Happy to assist you!
Sounds like the freon is low therefore it will not or stay on!
My words alone can not help you fix the unit!
You need service!
Let me know how it goes??
Please give me a good rating here at fixya.com before you sign off!
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF
Posted on Aug 29, 2008
Philips DCB146 NO SOUND!!
The answer is straightforward. The main power amp has gone. If you are lucky it's a single IC unit which you will find on a big heat sink. It might look like the one shown below.
You will of course need to de-solder it and resolder a new one. The type needed to replace it will be shown by the letters and number on the IC itself.
May 02, 2017 | Audio Players & Recorders
2001 hyundai accent won't crank
Shifter ?? why do you bother with a lazy mans gearbox ,nothing but trouble cant beat the manual version ,from your description it sounds like a inhibitor switch failure but i couldnt be sure without the old one cell brain box under the bonnet to be sure
Apr 14, 2012 | 2001 Hyundai Accent
My Lennox ac is making a very loud buzzing sound and the fan blades are not turning. We replaced the dual capacitor and that seemed to fix the problem for a couple of days, now it's doing the same...
Fan motor is probably bad, if it is under 5 years old the parts are under warranty. Do not run the unit for very long without the fan working as it can damage the compressor.
Aug 23, 2011 | Heating & Cooling
Hello, I have a Kitchenaid Superba KSRB25FHSS02 side by side refrigerator. It was made in 1999 and came with the house. Two years ago, the compressor went on it and we had it replaced. A couple days ago,...
It's really up to you, to decide whether you want your refrigerator to be fix or replaced and buy a new one. You need to calculate the cost between repair cost and the price of a new refrigerator. Which one is suited your budget plus the convenient of the trouble free unit for many years to come.
Since your refrigerator is about 12 years old already and it's undergo several repair, including the most expensive compressor replacement. I think it's economical to spend for a brand new unit.
New unit have service warranty of about one year, it will take many years before it undergo service repair if you use and treat it with proper care.
Good luck on your decision.
Jul 03, 2011 | KitchenAid Superba KSRG25FK Side by Side...
There is a deep hum that started coming from my 20 year old huge Mitsubishi floor model TV. Any ideas? I know, buy a new one, but I love this old hunk of a TV. Thanks !!
sculin,
Certainly a new one would solve the problem but from what you have said it would seem that yours should be reaparable. The only question would be whether it would be worth fixing if it costs alot to fix. Putting a large amount of money in a twenty year old set is usually asking for trouble. You said that the unit has a loud hum. Sounds like a low voltage power supply problem. I have a tip at
http://www.fixya.com/support/r6396176-projection_tv_troubleshooting
which will walk you through the troubleshooting process and should help solve your problem with the least amount of money.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 05, 2011 | Mitsubishi WD-82838 DLP TV
My gamecube does not spin the discs that i put into it and does not read them. Is there something i can do to fix this without having to buy a new one?
One time I ccidently touched the lens in my 10 year old gamecube so now the lens and the laser dont read the discs anymore because it is knocked out of anglement so you could buy a new gamecube now or buy a wii because wii's can still play gamecube disc's too.
default.jpgGame Cube Disk Read Error Fix (Advanced Skill)
May 19, 2010 | Nintendo GameCube Console
LGDVT418 System Logo
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
