Question about Hitachi Cameras
Zoom lens won't open when i switch on
I have a HDC-1209ER and when i switch on the zoom wont open. Please can you tell me how i can fix this.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
  • check if the batteries are fully charged.
  • try resetting the camera.
  • zooming motor has gone bad. have it replaced.
Posted on Feb 22, 2015
  • 76 Answers
SOURCE: zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
Posted on May 11, 2007
t00nz
  • 4738 Answers
SOURCE: Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 17, 2008
shockwave727
  • 262 Answers
SOURCE: zoom lens stuck out
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Posted on Nov 12, 2009
  • 11967 Answers
SOURCE: Zoom Error with Fuij FinePix - looking for "telephone trick"
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 28, 2009
SOURCE: Hitachi HDC-887E wont switch on
I have the exact same problem and also do not know how to fix it. Were you able to fix the problem? If so I woulsbe keen to know how you fixed it.
Posted on May 28, 2010
Hdc-1209er screen failing can it be repaired
Roger, the LCD screen can be replaced and they are listed on E-bay under camera parts under your make and model camera.
Jan 16, 2013 | Hitachi Cameras
My camera will not zoom
Zoom motor or control assembly is responsible for the issue. If lens removable try another one to see if it is the lens or camera. Shame
Sep 12, 2017 | Panasonic HDC-SD90 Camcorder
I just got my Panasonic HDC-SD80 in the post. I am charging it but tried to turn it on just for a quick look. The camera turned on and I could scroll through the menus on the touch screen and stuff but...
sometimes this happens if there is a fault with the memory card. switch the camera off, take the battery and memory card out, leave it for 2 mins, put the battery in (DO NOT PUT THE MEMORY CARD BACK IN) wait for the message on screen saying no memory card detected. switch off camera, put memory card in, switch on the camera, this normally cures the blank lcd screen issue
Aug 22, 2011 | Panasonic HDC-SD80 Camcorder
I have a Canon EOS 550D camera fitted with a Canon Zoom Lens EF-S 18-200mm lens. I bought both together sometime early in 2010 from London Camera Exchange, Nottingham. I am not in Nottingham at the moment,...
Just a thought - are your Image Stabilizer and Auto Focus switches On or Off?
Might be worth experimenting with them.
Otherwise, sorry, can't help.
May be necessary to contact your vendor.
Aug 09, 2011 | Canon EFS 18200mm f3556 IS Zoom Lens + UV...
The lens cover on my Pansonic HDC TM300 won't open up. I can hear a motor trying to open it when switched on. If I hold open the lens cover the camcorder functions as normal.
The lens cover mechanism in these cameras is susceptible to debris and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com
Oct 24, 2010 | Panasonic HDC-TM300 AVC HD Camcorder
Aug 10, 2009 | Hitachi M2L Digital Camera
My Lens wont retract on my exilm zoom ex-z60
If it is under warranty Casio can fix it for free. other wise you end up paying the labor/parts. Can become very costly. I suggest open the case and replace the plastic housing that hosts the saw wheels. Should fix the problem
Jun 23, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Zoom lens
Oh I'd love to be able to see this one. OH well. What batteries are you using? If they are ordinary alkaline, then you should get a set of NiMH rechargable batteries. (As strong as you can find) If the problem continues, taale the camera into Nikon and send your friend the bill.
Apr 01, 2007 | Samsung Digimax A400 Digital Camera
Cameras Logo
Top Hitachi Cameras Experts
DocZachary
DocZachary
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
