Question about Whirlpool WTW5300VW 3.5 Cu. Ft. Top Load Washer - White
How do i remove the hydraulic pump on an international 1066
    Habit-Forming:
    New Friend:
  • 70 Answers
If I remember right there is more then one pump 1 for hydrostatic drive and steering and one for hydraulic equipment operation the
Here is a link to a manual for the IH 1066 there are a lot of variables that could cause pressure or flow drop I hope your sure its the Pumps before you have to go through all the work of tearing it down to get to it
https://docs.google.com/file/d/0B4aybwuVwai2MWJkZGJjMjYtOWYwNi00YmJkLTgwODYtMmRlZDhiZDJhMTNl/edit?pli=1&hl=en#
Good Luck Rickie
Posted on May 13, 2014
2000 3.2 CONCORDE CHANGED WATER PUMP TIMING MOVED HOW TO FIX
I know on some dodge products the timing belt drives the water pump and has a hydraulic pin tensioner. Generally you will half to press the pin back in bleeding it with a press then lock it in place with a pin and keep it upright up to the reinstall. If this is the case your gonna half to retime your engine aligning all timing marks carefully to avoid bending any valves or damaging pistons and various other internal engine parts. Once they are aligned properly then reinstall the belt and then the hydraulic tensioner and release the pressure on the tensioner by removing the pin holding it down. If this is the kind of system you have genrally dodge recomends changing your belt along with the new water pump.
Sep 30, 2017 | Cars & Trucks
John Deere 455 mower deck will not raise With the hydraulic valve with turned 100 % counter clockwise
If the cylinder is out of hydraulic fluid, or if the hydraulic pump has quit, or is leaking internally, any of these could be the source of the problem.
Oh, yes, and if the deck is bent or jammed, perhaps the pump or cylinder cannot raise it.
God bless your efforts.
Aug 31, 2017 | John Deere Garden
Low hydraulic pressure to raise implements 8650 john deere
Could be the charge lube in the rear differential. It supplies oil to main Hydraulic pump up front on engine. The charge pump drive can strip and not turn pump. To remove pump drive remove third link plate on rear frame, remove plug behind plate, pull out hex shaft, about 5 foot long and inspect.
Oct 01, 2016 | John Deere Garden
Where is the abs pump in a 2000 galant
Galant and Mirage
Fig. HCU mounting-Mirage
Fig. HCU mounting-Galant
  1. Use a syringe or similar device to remove as much fluid as possible from the reservoir. Some fluid will be spilled from lines during removal of the hydraulic unit; protect adjacent painted surfaces.
CAUTION Brake fluid contains polyglycol ethers and polyglycols. Avoid contact with the eyes and wash your hands thoroughly after handling brake fluid. If you do get brake fluid in your eyes, flush your eyes with clean, running water for 15 minutes. If eye irritation persists, or if you have taken brake fluid internally, IMMEDIATELY seek medical assistance.
  1. Remove the splash shield from the left front wheel house or fender area.
  2. Remove the coolant reserve tank.
  3. Remove the coolant reservoir bracket.
  4. Remove the dust shield from below the hydraulic unit.
  5. Disconnect the brake hoses and lines from the hydraulic unit. Correct reassembly is critical. Label or identify the lines before removal. Plug each line and each port immediately after removal.
  6. Remove the cover from the relay box. Disconnect the electrical harness to the hydraulic unit.
  7. Remove the bolts holding the 3 mounting brackets to the vehicle; remove the unit downward and out of the vehicle.
NOTE The hydraulic unit is heavy; use care when removing it. The unit must remain in the upright position at all times and be protected from impact and shock.
  1. Set the unit upright, supported by blocks on the workbench. The hydraulic unit must not be tilted or turned upside down. No component of the hydraulic unit should be loosened or disassembled.
  2. The brackets and relays may be removed if desired.
To install:
  1. Install the brackets and relays if they were removed. Tighten the bracket bolts to 16 ft. lbs. (22 Nm).
  2. Install the hydraulic unit into the vehicle, keeping it upright at all times.
  3. Install the retaining bolts holding the brackets to the vehicle. Tighten the bolts to 16 ft. lbs. (22 Nm).
  4. Connect the hydraulic unit wiring harness.
  5. Install the cover on the relay box.
  6. Connect each brake line loosely to the correct port and double check the placement. Tighten each line to 10 ft. lbs. (13 Nm).
  7. Fill the reservoir to the MAX line with brake fluid.
  8. Bleed the brake system.
  9. Install the dust shield and the coolant reserve tank with its bracket.
  10. Install the fender splash shield.
  11. Check ABS system function by turning the ignition ON and observing the dashboard warning lamp. Test drive the vehicle and confirm system operation
Jun 09, 2012 | 2000 Mitsubishi Galant
I have a 1992 Crysler Imperial. The ABS light is on and the ABS pump runs all the time. Help.
Either the ABS Module is bad or the Pump is bad--- Pump REMOVAL & INSTALLATION 1989-90 Models
  1. Disconnect the negative battery cable. Depressurize the hydraulic accumulator. CAUTION
    Failure to depressurize the hydraulic accumulator, prior to performing this operation may result in personal injury and/or damage to the painted surfaces.
  2. Remove the fresh air intake ducts.
  3. Disconnect all electrical connectors to the pump motor.
  4. Disconnect the high and low pressure hoses from the hydraulic assembly. Cap the spigot on the reservoir.
  5. Disconnect the shift selection cable bracket from the transaxle and move it aside.
  6. Loosen the nuts on the 2 studs that position the pump/motor to the transaxle differential cover.
  7. Remove the retainer bolts that are used to mount hose bracket and pump/motor. The engine inlet water extension pipe is also held in position by these bolts. NOTE: Do not disturb the inlet water extension pipe, or engine coolant will leak out.
  8. Disconnect the wiring harness retaining clip from the hose bracket.
  9. Lift the pump/motor assembly off of the studs and out of the vehicle.
  10. Remove the heat shield from the pump/motor, if equipped and discard. To install:
  11. Place a new heat shield onto the pump/motor bracket, using fasteners provided.
  12. Install the pump/motor assembly onto the studs.
  13. Install the wiring harness retaining clip onto the hose bracket.
  14. Install the retainer bolts to the hose bracket and pump/motor. Tighten securely.
  15. Tighten the 2 nuts until secure.
  16. Install the shift selection cable bracket onto the transaxle.
  17. Connect the high and low pressure hoses to the hydraulic assembly and tighten to 13 ft. lbs. (17 Nm).
  18. Attach all electrical connectors to the pump/motor.
  19. Install the air ducts.
  20. Readjust the gearshift linkage, if it was disturbed.
  21. Connect the negative battery cable and check the assembly for proper operation.
1991-95 Models
  1. Disconnect the negative battery cable. CAUTION
  2. Depressurize the brake system.
  3. Remove the fresh air intake ducts from the engine.
  4. Remove the clip holding the high pressure line to the battery tray.
  5. Disconnect the electrical connectors running across the engine compartment in the vicinity of the pump/motor high and low pressure hoses. One of these connectors is the one for the pump/motor assembly.
  6. Disconnect the high and low pressure hoses from the hydraulic assembly. Cap or plug the reservoir fitting.
  7. Disconnect the pump/motor electrical connector from the engine mount.
  8. Remove the heat shield bolt from the front of the pump bracket. Remove the heat shield.
  9. Lift the pump/motor assembly from the bracket and out of the vehicle. Fig. 1: The pump/motor assembly mounts to the top of the transaxle case and is covered by a heat shield 86729g75.gif
    To install:
  10. Fit the pump motor assembly onto the bracket; install the heat shield and its retaining bolt.
  11. Install the pump/motor electrical connector to the engine mount.
  12. Connect the high and low pressure hose to the hydraulic assembly. Tighten the high pressure line to 145 inch lbs. (16 Nm). Tighten the hose clamp on the low pressure hose to 10 inch lbs. (1 Nm).
  13. Connect the electrical connectors which were removed for access.
  14. Install the high pressure line retaining clip to the battery tray if it was removed.
  15. Install the fresh air intake ducts.
  16. Bleed the brake system.
Oct 07, 2010 | 1991 Chrysler Imperial
Is the clutch slave cylinder internal or external of transmission?
external if it's like my 1979 Honda. Internal if like the following information:
Slave Cylinder on 1999 Chevrolet Cavalier
  2. Detach the master cylinder assembly from the actuator cylinder by disconnecting the hydraulic line.
  3. Remove the transaxle assembly, as outlined earlier in this section.
  4. Remove the clutch actuator cylinder from the transaxle. Fig. 1: Clutch actuator cylinder assembly mounting 91147g02.gif
    To install:
  5. Lubricate the inside diameter of the bearing with clutch bearing lubricant GM part no. 12345777 or equivalent.
  6. Install the actuator cylinder in the transaxle, then install the transaxle assembly.
  7. Connect the master cylinder-to-actuator hydraulic line.
  8. Bleed the hydraulic system, as outlined later in this section.
  9. If removed, install the air intake duct.
  10. Connect the negative battery cable.
Jun 20, 2010 | 1999 Chevrolet Cavalier
Hydraulics get were they won't lift anything like round hay bales etc.
can be a lot of different problems-check fluid level if low fill to proper level --leak in hydro line-check all lines for leak--air in system -bleed system -wrong hydro fluid in system-check for correct fluid---seal at pump leaking-check around pump--controls leaking not holding allowing back pressure--test controls for internal leaks repair or replace if necessary--hydro pump internal malfunction/valves/piston/gears-pressure test repair or replace if necessary
Feb 01, 2010 | Diesel Allis Chalmers 190xt Tractor...
HYDRAULIC PUMP FOR CONVERTIBLE TOP
Call PRECISION FLUID POWER Inc.
1-800-728-5168
They might be able to help you.
Sep 24, 2008 | 1987 Toyota Celica
Whirlpool WTW5300VW 3.5 Cu. Ft. Top Load Washer - White Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
