Question about Boating
How to take quicksilver 3000 siries throttle apart . Its a Murcury throttle handle.
Can't get it threw wall
    Top Expert:
  • 46,475 Answers
From the picture I would remove all the screwI can find or see.first a mechanic's mirrow on a stick might shed some light on the problem also.there could be a clip on it also .
Posted on May 18, 2014
Where can I see quicksilver 3000 shifter/throttle diagram
try putting what your looking for in google and then click images.
Aug 19, 2016 | Cars & Trucks
Just bought boat & prop will not in gage all the time
put your motor on the garden hose after you remove the propeller (you don't want to step into a spinning blade). remove the cover and start the motor.
Have some one shift the motor (without engaging the throttle).. This will show you which cable is the shift cable.Disconnect the shifter, and while it's running, shift it full forward and full reverse to fin the halfway point. Next return the control box to neutral and adjust the connector. Start it up and see if the control box will shift the gear box as far as you did by hand. If not you need to take the control box apart and move the cable anchor so you get more movement. Get a repair book and take pictures as the guts of a control box can be VERY confusing.
Sep 06, 2012 | Quicksilver Mercury/Quicksilver Parts...
Need to replace my shifter on my 1994 well craft 243 prima. I have a 5.7 liter v8 mercruiser engine. I need to replace a concealed mount shifter with a two tilt switches, one says trailer
Some where is an easy pop off plastic cove on the big end of the shift handle. When it is popped and you can see an allen head in the middle of the handle, you can remove the handle and let hang by the tilt wires. under the handle will be 3 or more long bolts that hold the shift control to the console. After you remove them the console will go inside the panel taking the handle and wires with it.
NOW comes the tricky part- the key switch has a power wire going to the control/ Try not to break it. Sometimes you need to loosen the key switch from the dash and allow the wires to follow the control out the back of the panel. Now you can see the cables and remove the faulty one.
Jun 24, 2012 | Quicksilver Mercury/Quicksilver Parts...
My kids 2007 honda crf100f idle is way to fast cant seem to adjust it ive taken the carb apart and cleaned it up blew air threw everything cleaned the air filter again and lightly lubed it doesnt run...
have you tried adjusting it up at the throttle on the handle bar? move ruber dirt protector and with bike running just loosen the nut and screw in to idle down and re-tighten the nut. this should work....
Aug 29, 2010 | 2005 Honda CRF 100 F
Quicksilver throttle
I recently aquired a 1982 Merc Bigfoot 60hp with a quicksilver throttle control. I am trying to find a manual as to the throttle operation. Any suggestions?
Chuck flochu1@yahoo.com
Jul 27, 2010 | Boating
I have a quick silver g4. I connect this to the outlet on the wall and it did not turn on. it has the power light goes on and off and it sound like a disco light. tic tic as it turns on and off
This report matches no common failure mode of the Quicksilver.
With power cord disconnected, test the internal battery voltage. If it is below 3.3V, it needs replacement. After replacing, you MUST reset the PMU by pushing the PMU button (located near the battery) ONCE. Then retry the startup.
If this does not solve your problem, you will need to bring your unit to an Apple-qualified tech for diagnosis.
Mar 29, 2010 | Quicksilver Power Mac G4 (Quicksilver)
Throttle assembly
try www.jackssmallengines.com parts look up poulan 2500 they have exploded views of all parts this may help you will probably have to search arond abit
hope this helps
Nov 01, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Boating Logo
182 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
