Question about Jenn-Air Outdoor Liquid Propane Lp 7-burner Bbq Grill Convertible To Natural Gas
Were can i get a replacement gas regulator for my george forman gas bbq model 11413 ?
The gas regulator is missing to my George forman gas bbq model 11413
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
If it is set up for propane gas you require a regulator set at 2.75kpa
Posted on Jul 10, 2014
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
I hooked a thermador cooktop to a BBQ propane tank. The flames are large for a second and make a puff sound and the shrink to nothing. All 5 burners do the same.
It does sound like a faulty regulator, propane operates at 2.75kpa and if the existing regulator is for natural gas it is only 1.1kpa.
If you are operating off a bulk tank the regulator on the tank may be high pressure then the secondary regulator on the appliance may be to bring it down further. See if you can get a manometer and check it all out before doing any regulator removing.
Apr 05, 2014 | Thermador Cooktops
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Intalled the 30" gas oven, converted to LP (both
Hello, thank you for posting. It sounds like you have done a little work to get the unit converted to LP. Make sure you didn't install the regulator upside down. Sometime you can get a defective regulator out of the box. Some of the regulators have the "N" for natural gas if so you need to convert this as well. I suggest you send a factory repair person just to double check on the unit. It well not cost anything to have them test out the unit if you feel the part is "broken".
Happy Holidays!
Please rate me "4 thumbs" if that was helpful.
Dec 20, 2010 | Maytag 30" Built-In Gas Cooktop - White
Missing manual and gas diffuser
May I get the make and model # to help you get the manual.
Also from the gas supply from house to cooktop it should go like this.
gas valve
gas line
regulator
then cooktop
May 31, 2010 | Maytag MGC5430BDS Gas Cooktop
Hi I am trying to convert my Dacor stove/oven from NG to Propane. We can't find the conversion kit anywhere. Any ideas?
Hi, to convert from NG to LP is easier in some ways but harder in others. The pressure part is easy because LP runs at the same pressure that comes into the house so the regulator is normally locked wide open to allow a direct by-pass. You could just as easily remove the regulator and plumb straight in from the houseline. You don't say what model but usually the sealed cooktop burners will need smaller orifices and the oven and broiler orifices are adjustable. If that is the case, the oven and broiler orifices can be tightened until they bottom out which be the correct output for LP. You would need to remove the cooktop orifices and find replacements which are correct for LP, these are non-brand specific. Honestly, if you go to repairclinic.com and enter the brand and model number, I'd be surprised if you couldn't find the conversion kit. Even the Dacor site should be helpful. I found many different kits available at the repairclinic.com site even without a model number. Best of luck.
Jan 29, 2010 | Dacor Preference SGM365SS Gas Cooktop
Hi 3 of my 6 gas burners won't light. Can you help me with this?
I had the same problem and was about to call for service, but I decided to try this: I took the brass rings where the gas comes out and soaked them in a good bbq grill cleaner and then brushed them all off. I took a long toothpick and cleaned out each hole in the ring well. Then I put some of the bbq cleaner into the ring on the cooktop where the brass rings sit to clean out the accumulated cooking junk. I brushed them well and used a toothpick around the ignitors to clean off the junk. At first, none of them worked (cause they were still wet I think) but after careful drying and a few moments all of the burners are now working fine. Im sure this saved me a couple hundred dollars and took me an hour.
Jan 21, 2010 | Viking Cooktops
St George Rotomaster stove/oven turning itself on.
This certanally sounds like a bad switch.
Availablity of a replacment switch I am not shure.
But you can try. Here is a link to service agents that
should be able to help you
http://www.sga.com.au/Services/default.aspx
Hope this helps.
Please leave feedback.
Dec 06, 2009 | Cooktops
Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
Jun 21, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Gas hob ignition
1) try leaving it off for a while to see if the ingition box needs to reset
2)when you turn on the burnner does the ignition start by itself or do you have to "ignite" the burnner yourself?
3) if oyu have to ignite the burnner yourself, try using a bbq lighter to see if the gas has gotten to your range yet.
4) if no gas present, there is ussually a reset in the regulator. it needs to be reset if it gets low on pressure. you need to have the lines connected and then turn on the gas AND then the appliance. if the appliance is turned on before the gas in turned on the rest will pop.
lets us know what happens :)
Jan 30, 2008 | Cooktops
Jenn-Air Outdoor Liquid Propane Lp 7-burner Bbq Grill Convertible To Natural Gas Logo
121 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
