Question about Water Heaters
Ge wiring diagram
How can I retrieve the wire to connect part # WB44T1001 to my Model # J CB900BK2BB oven. The wire on the right when facing the front of the stove has retracted out of sight. What color is it and how can I reach it?
  • 25 Answers
See if you can remove back panel and push it back through hole. fasten it so you wont lose it again.
Posted on Jun 08, 2014
4 Suggested Answers
  • 5245 Answers
SOURCE: i need a wiring diagram for a ge 240 vac timer please
GE sells several timers rated for 240Volts.
Including the 15307 timer made by Tork, rated 208-277Volts, 40 amp, 60 Hz
Copy following link for wiring GE 240Volt timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Posted on Oct 18, 2012
  • 5245 Answers
SOURCE: there is no clear instructions for wiring the unit to the fuse box. diagram in manual is not clear wich color wires get connected to what.
1) Copy following link:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
2) 30 amp breaker and 8 gauge wire?????????
This is why Rheem manual says to call electrician.
http://waterheatertimer.org/Color-codewire.html
3) Add comment before you burn down house.
Posted on Dec 16, 2012
0 when i check it i only get 120 on both when i ground then in 0 when i check the white to black is this right the make is a ge 19.9 hot water heater
You did not post the make and model of the unit. However you should have three wires on a 120 volt heater. Black is HOT. White is neutral and green or bare copper is ground. Anything that you check with a meter connected to black should show 120. white connected to ground across the meter would show 0.
Mar 03, 2017 | Water Water Heaters
Wire diagram for GE 0102287763
What is a GE 0102287763
Add a comment with photograPH.
Understand also that fixya cuts off questions so we cannot see everything you are asking.
Gene
h
Sep 28, 2013 | Water Heaters
GeoSpring GEH50DNSRSA wire diagram
Here are all the resources that are available for GE heat pump without calling GE and hearing them tell you to call service technician:
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
There is no wiring diagram for the bundles of wires coming from chip control board.
As general rule, these things are made to last 10 years, and afterwards will not function or be repairable. It's like a window air conditioner, except connected to water pipes, and connected to computer chip and multiple sensors, each susceptible to failure, and then the machine is used 24 hours a day, 365.
Designs have changed continually from 2009 to 2010 to 2012 models.
It's likely you got a nice piece of junk with depleted anode rod and failed sensors that stopped working and somebody got rid of it because it wasn't repairable.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Add a comment
Jun 02, 2013 | Reliance & 40 Gal Electric Mobile Home...
I need a wiring diagram for a ge 240 vac timer please
Oct 18, 2012 | GE 15307 240 VAC 24-Hour Outdoor...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
