Question about Refrigerators
Defrost timer kitchenaid
Why would the 8 hour timer defroster- model# 482493 on my Kitchen Aid model # KBR S22K6 Fridge stop working and need to be replaced every 2 or 3 years?
4 Suggested Answers
mgprice
  • 744 Answers
SOURCE: Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 11, 2009
  • 547 Answers
SOURCE: ON A NEW FRIG, KITCHEN
It's fully automatic -- it will very briefly kick on the defrost cycle once a day (variable by model) to prevent frost buildup, but not long enough to warm the food.
Posted on Sep 26, 2010
Sea Breeze
  • 4654 Answers
SOURCE: I have a Kitchen Aid refrigerator model KTRS20K which stopped working (everything felt warm and freezer not working ). I replaced the defrost timer, it didn't quite match but was told it was a re
That does not sound like a defrost timer problem. Sounds like a condenser or evaporator fan is beginning to fail. They don't always stop when they fail. Many will slow down and stop while you are not looking causing the refrigerator to stop cooling for a while. Let me know if you have any questions, Thanks Sea Breeze
Posted on Feb 13, 2012
My Kitchen Aid Superba refrigerator Model # KSRS25FGWH01 stopped working. no fans come on no noise only fridge lights. working the other day but fridge was not cold enough freezer was fine now nothing
The machine goes into the defrost mode every day or two. During defrost mode you will see these symptoms. After an hour or two, it should return to normal. If not, the defrost timer may be stuck in the defrost position.
Mar 05, 2017 | Refrigerators
Whirlpool fridge,freezer has build up of snow and ice,model#et4wskxk000
I want you open up the control panel or look for an opening where you can place a flathead screwdriver through the panel to turn the defrost timer slowly until the compressor and fans turn off. Thish should manually force defrost providing the defrost heater and defrost thermostat are still good. The defrost timer is location number 4 in this photo HERE Leave timer in that position for up to 45 minutes. If doing this causes defrost to work simply replace the=> 482493 Defrost Timer If this does bot work then you will need to move and check out or replace the=> 2263749 Defrost Heater Assembly Let me know what you find Sea Breeze
Jun 02, 2013 | Refrigerators
Feb 12, 2012 | KitchenAid Refrigerators
ON A NEW FRIG, KITCHEN AID KSCS23FVMK, HOW DOES THE DEFROST CYCLE WORK? DOES IT ONLY COME ON WHEN IT NEEDS DEFROSTING OR DOES IT DEFROST EVERY 8 HOURS OR SO BY TIMER IF IT NEEDS IT OR NOT?
Sep 26, 2010 | Refrigerators
Freezer works, Fridge doesn't
The defrost timer inside the fresh food compartment is most likely the problem. Need to turn the timer slowly clockwise until compressor stops. I should remain off for about 25 minutes. During that time the freezer should be in defrost. You may be able to open the freezer door and hear the crackling and sizzle of the defrost taking place. If the timer does not restart the refrigerator after 25 minutes the turn the timer clockwise again until the compressor restarts. Number 6 in photo below is the defrost timer. The replacement timer part number is 482493. Here is a photo. Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Aug 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
DRIPPING SOUND MAYBE POPPING ALMOST
This is normal operation, every 8 to 10 hours the heater in your freezer section turns on to defrost ice and frost from evaporator coil, this melting water hitting the heater is what is making popping and hissing noises.
Jan 20, 2009 | KitchenAid KTRS19KMSS Top Freezer...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
