Question about Weather King 10AJA3601AH Air Conditioner
Can be the unit don't have enough gas?
I have a 10AJA3601 at home .i check the outside unit is running, inside the house the fan coming up but i can't feel a really cool air and the air blow the fan look to me is not enough. everything is working but i think : can be the unit don't have enough gas ?
    Sergeant:
  • 340 Answers
I would have the evaporato ,blower wheel and condenser cleaned then and only then can ya properly charge the unit. Tom
Posted on Jun 26, 2009
  • 43 Answers
Yes, you could be low on refirgerant. You should have a air conditioning technician test it.
Posted on Jun 23, 2009
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Outside A/C unit not working
is this 3 phase? 3 phase is diffrent from single phase
Jun 18, 2013 | Goodman CLQ36AR49 Air Conditioner
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
Our unit is making loud clicking noise and spraying water when in the cooling air condition mode, but not when the fan is on. What could be the problem, and is it fixable?
you may hear water splashing that is because it is coming off of the condenser the part that is outside the water runs off the condenser and is forced out by the fan for as the noise could be something in or on the inside fan blade or outside fan blade as long as the water is not coming inside your house and you have enough slope on the unit you should be ok
Jul 04, 2011 | LG Electronic Window Air Conditioner
Bosch nexxt 500 series dryer producing intermittent gas smell when running. wife says the smell has even permeated the clothes a time or two, but I haven't noticed it. heat exchage box? if so, how hard...
A few things to check...
First, check that the dryer vent is not clogged. You'll have to go outside to check. If you are not sure of a clog, disconnect from inside and have your wife hold a flashlight by the vent, then go outside to see if you can see it. This will also cause laundry to dry slower than it used to (your wife may have a feeling if this is the case).
Second, make sure you don't have negative pressure in the house (large house fans are good for cooling but move too much air out so the dryer cannot vent its exhaust gasses well). You can check by opening an exterior door about an inch and check if it swings open with a gush of wind. Even houses without whole-house fans can do this if you have enough bathroom fans and furnace fans going.
Third, If it is a smell of natural gas, then you should call a service technician because the valve is not opening/closing correctly (or fast enough) if you have a pilot-less starter.
May 05, 2011 | Bosch Nexxt 500 Dryer
I had my a/c charged today because it has not been cooling the house down. It took less than a pound, but it still blows worm air. Fan and compressor all running. I cleaned outside unit, filters, replaced...
It could be that it is not charged correctly. Check the insulated copper
line outside if it is sweating and the condensor is discharging hot air, then the ac is doing all that it can. Check the evaporator inside to see
if the drain has condensate coming out of it.
Getting the heat out of the attic is a good idea, but you must have enough make-up air in the attic for the fan. If you do not have enough
make up air, it will start to draw air from inside the house. One way to check this is if you have a gas water heater and or furnace. If you put
a flame by the exhaust pipe in the basement and it blows it out, then you now have a backdraft problem.
Run the AC withoutthe fan, my real guess is the unit is not properly
charged or you do not have a big enough AC unit.
Jul 17, 2010 | Goodman CKL36AR36 Air Conditioner
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
If both fans runs (inside and outside), check if the compresor runs , if does probably the unit is low in freon and needs to be recharged after the freon leak has been fixed (remember this is a seal system and it shouldn't leak), but if the compressor doesn't work , it could be the capacitor , the pressure switch (if it's low on freon ) or the compreessor itself.But befor do anything ,if you have a digital thermostat replce the batteries.
Sep 30, 2009 | Ruud UBHC Air Conditioner
The outside unit on our Ruud heat pump won't turn on. The inside fan blows but the unit outside sits idle - no fan turning, nothing. It was cooling earlier today, but when I came home from shopping, the...
first look for red button neer the copper line set if has one push it second inspect thermostat wires for weed eater damage check disconnect for fuses check breaker at main panel pull disconect and remove cover check stat wire connections look at the capacitor if swelled up on top bad if all look ok put disconect in using insulated object manually push in contactor if unit comes on check for 24 volt ac on yellow stat wire to common if none stat wire could be loose at indoor unit or stat bad hope this helps you
Jun 05, 2009 | Ruud UPMC036 Air Conditioner
Fan is still running in house constantly
Check your wall thermostat to make sure the "fan" switch is in the "auto" position. If it is set at the "on" position, the indoor fan WILL run continuously. Not really enough info as to what type of split system you have. Gas? Electric? Heat pump? Oil? Wood? Newspapers? See what I mean? Is it variable speed? Do you have a "special" thermostat for certain operations? Does your system incorperate inverter technology?
Apr 24, 2009 | Ruud Central System Air Conditioner
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
Weather King 10AJA3601AH Air Conditioner Logo
145 people viewed this question
Top Weather King Heating & Cooling Experts
John Tripp
John Tripp
acrman404a
Level 1 Expert
Bill Long
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
