Question about Singer Inspiration 4210 Mechanical Sewing Machine
I have the same problem as random_havok who posted on jun 03 2011
Ive noticed the feet that came with my singer inspiration are different then the ones ive bought from singer mine are very narrow and the lever will not fit on the other feet is there another lever that fits the inspiration
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Singer Expert
  • 300 Answers
Talk to your Singer dealer.
Posted on May 14, 2014
  • 323 Answers
SOURCE: Singer-Inspiration 4220/4228
Send this machine back where it came from! machine. You have described a timing problem which you can not and should not need to do.
Change the needle first and test it to be sure the needle still hits on the hook. If it does,follow the above instructions. If it no longer hits then it's possible it is not as serious as I first thought.I'm not sure if the bobbin keeps coming out or the bobbin case(the plastic part the bobbin sits in) comes out.If it is just the bobbin, insert the bobbin in the case and pull on the thread. The bobbin should turn COUNTERCLOCKWISE. If it turns the other way, turn it upside down and try it again.
If it is the bobbincase,then Remove the needle plate and take the bobbin case completely out. On this machine there is a small lever which holds the bobbin case in position. Looking down on the bobbin case the lever is located at about 11 o'clock and has a small slot in it. It is also probably spring loaded which means it is not easy to turn without a small screwdriver. Insert the screwdriver in the slot and turn it to the left. Lift out the bobbin case and Carefully examine it for any nicks, scratches or rough spots. If you find any, they will need to be removed with an emery stick and or a sharpening stone. Buff with a very fine steel wool for total smoothness.
To replace the bobbin case use the screwdriver to open and hold the lever open while you insert the case back in. The straight part of the case will be on the right and you need to place the case so that the circular part rides on the slight grove in the hook.(The metal thing it sits on). Once you have it in place you can release the lever you've been holding open . It should fit over the edge of the bobbin case and not allow it to come out. Rethread the machine and turn it by hand a few times to see that it is working properly. Good luck!!!
sewman7
Posted on Jul 01, 2008
  • 17 Answers
SOURCE: thread balling up on my singer inspiration 4210
by all indications should be checked if the thread is properly set to the upper and lower...
Posted on Dec 27, 2009
omather
  • 98 Answers
SOURCE: I have bought a Singer inspiration model 4220c and
Here you go:
http://www.singerco.com/pdf/4205_4210.pdf
Hope this helps, Owen
Posted on Apr 22, 2010
  • 1788 Answers
SOURCE: Just bought a singer 8280
Usually universal, just be sure that it is a low shank because that is what your machine looks like to me. I looked up your manual online at www.singerco.com and here is a little bit of advice. Go there and download a copy to your computer. That way, you will always have a copy when you need it. You can make ruffles by using your machine stitch length, just make it the longest stitch, loosen your top tension, then pull on the bottom thread. Or you can do a basting stitch by hand and pull the thread and distribute evenly, then machine stitch to lock it down. I haven't used a ruffler in years. Try it first and see if you like that idea before you invest in a ruffler. They can be pricey, try ebay for a used one but be sure that it is a low shank . I am also sure that Singer sells them too, 1-800-4singer. Good luck and happy sewing.
Posted on Oct 31, 2010
SOURCE: can't find straight stitch setting on singer inspiration model 4228
do you have a manual? if not
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 4228) & click search
Posted on Apr 24, 2012
Which model old style cam type buttonhole attachment from Singer will fit on the Bernina 807 minimatic machine that is an equivalent to the singer featherweight that I can make keyhole buttonholes.
In my earlier response, you need a shank that is made for your Bernina 807 and Berninas made in that era. Only "Old Style" Bernina presser feet and adapters will fit your machine. No other brand will work, not Singer, not Janome, not Brother, nothing but Bernina Old Style. There are several Bernina old style presser feet. Look for presser feet with the number printed in black ink or presser feet that have the number stamped into the metal. Do not buy a Bernina presser foot with red numbers--will fit only newer Bernina machines.
If you want to use the Singer buttonholer attachment, it needs to be for a straight shank machine. You will need to have a Bernina shank adapter for your machine.
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." The first Old Style item is the shank adapter you would need to attach the Singer buttonholer attachment to your machine. (Am assuming it will work, no guarantees!) If it doesn't work, then you will probably not be able to use the Singer buttonholer with your Bernina machine.
This shank adapter would fit your machine:
http://www.ebay.com/itm/Adapter-Low-Shank-Feet-Foot-Bernina-500-1630-Old-Style-/380397208368
If you are looking for a snap-on adapter, it needs to state that it will work with a Bernina Old Style machine, ie the old Record machines (930 Record, 830 Record, 730 Record, 707, 807 Mini, 630 Record, and 530 Record--or in other words, Berninas manufactured prior to probably 1996).
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." If you are looking for the snap-on, go to the very last item on the page (Old Style). This will fit your machine. Remember, if it says Old Style, it should work on your machine.
This snap-on shank will fit your machine:
Presser Foot SNAP ON SHANK Adapter Bernina Old Style 530 532 1630...
This presser foot will fit your machine:
http://www.ebay.com/itm/BERNINA-ORIGINAL-20-SATIN-DECORATIVE-STITCH-FOOT-OLD-STYLE-830-1530-930-etc-/132055492681
This is an entire kit of snap-on feet with shank (included) that will work on your machine:
http://www.ebay.com/itm/20-Feet-Set-for-Bernina-Sewing-Machine-Old-Style-530-1630-Models-/381790565625
Here is a kit of snap-on feet with shank (included) as well as the buttonhole attachment you were asking about:
17 Feet Set for Bernina Sewing Machine Old Style eBay
Although, I believe you will be able to make only straight buttonholes with this buttonhole attachment.
Hope this helps.
Jan 07, 2017 | Singer Sewing Machines
The hook casing that holds the bobbin in my Singer Inspiration 4205 will not rotate when I sew. Therefor the top thread can not pick up the bobbin thread.
there could be something wrong with the hook and hook race, it needs to be checked to see it the parts are damaged or need a adjustment
Mar 07, 2015 | Singer Inspiration 4205 Mechanical Sewing...
How to attach zipper foot on singer inspiration
Here is a copy of your manual.
http://www.singerco.com/uploads/download/498_4205_4210.pdf
Most modern machines have snap off and snap on feet. Grasp the foot that is on there and push down. Then while lowering the foot, align the little bar on the zipper foot and watch it snap in. Easy.
Jul 07, 2012 | Singer Inspiration 4205 Mechanical Sewing...
Can't find straight stitch setting on singer inspiration model 4228
Go to the home page
Apr 23, 2012 | Singer Inspiration 4228 Mechanical Sewing...
Singer inspiration thread wraps around bobbin seat while sewing
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
Mar 30, 2012 | Singer Inspiration 4210 Mechanical Sewing...
How do you thread a Singer?
http://www.singerco.com/resources/threading.html Check out their threading diagrams, they are really helpful!
Jan 04, 2010 | Singer Inspiration 4206
Singer Inspiration 4210 Mechanical Sewing Machine Logo
54 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
