My,beko,wme7247,is,stuck,on,quck,cycle,but,wont,start wme,7247.what,ever,cycle,you,turn,the,knob,to,its,read,as,the,quick,cycle,but,wont,start
  • 6277 Answers
SOURCE: my beko 7247.is not draining,and
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 20, 2011
  • 41 Answers
SOURCE: I have a Beko WME
you do not have to try taking sump hose of the bottom and gain access from their i have tools for this and it works for me you can even use a bit of fence wire to get hold of it. if you have to take of front panel its fairly straight forward power off lid off screws at front base doorlock door seal retaining wire this can be carefully prised off remove soap drawer and retaining screws lift off fascia then there is a couple of screws .once you lift panel off then you will see the retaining clips on the front of the tank just prise them off with a screwdriver. and there you are hope this helps .ps its agood idea to lay out screws as you take them out then you wont have to figure which is which.
Posted on Jun 07, 2011
vladmototole
  • 226 Answers
SOURCE: beko washing machine WME 7267 fills with water but will not continue through the cycle
See if the filter is clean or if the exhaust hose isn't blocked.
Posted on Feb 23, 2012
MNfisherman
  • 11896 Answers
SOURCE: My beko washerwo.t work it gets stuck on quick
sounds like a problem with the selector switch or computer board. A bad switch will cause the cycles not to advance
Posted on Jun 04, 2012
  • 66 Answers
SOURCE: beko wme8227 stuck half way through cycle
Ring ds suplies 01782-625551 and ask for chell
Posted on Aug 16, 2012
Beko washing machine
Try letting the program run through
and see if that clears the problem sometime it will if not holding the power button for a wile should re set it
Jan 23, 2014 | Washing Machines
Beko washing machine stuck on rinse cycle water I drum but wont move onto spin
all you need to fix your beko
pump fault
or spin problem
i hope this helps
Buy Paul Beer
Jan 11, 2014 | Beko Washing Machines
My washing machine fills up but the drum is not spinning
Hi calex if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 18, 2013 | Beko Washing Machines
My beko washerwo.t work it gets stuck on quick wash and it wont go any further than rinse
Jun 03, 2012 | Washing Machines
Beko washing machine WME 7267 fills with water but will not continue through the cycle
Feb 23, 2012 | Beko Washing Machines
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
The brand new washing machine beko 7247 is not going through the whole wash cycle, it is stopping when it gets to rinse. the rinse sign is flashing on the display, there is nothing wrong with the water...
Hi and welcome to FixYa, I am Kelly.
Since this is a NEW washing machine there is little you can do as a consumer that would not void your warranty. Check and make sure the drain hose is no folded or kinked. The locate your filter assy:
http://www.buyspares.co.uk/washing-machine/wme7247w-7143081500/pump-filter-assy/product.pl?pid=1905802&path=445291,110919&model_ref=583085
(inside the machine)
and make sure it is clean.
http://www.beko.co.uk/manuals/wme7247.pdf
See page 27 of this manual for directions on how to access and clean your pump filter.
If after performing this task and testing, if it still does the same thing, your are pretty much stuck with going through the warranty process. The warranty information is on pages 35 and 36 of the pdf link above.
Kelly
Apr 13, 2011 | Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
