Question about HP Pavilion dv9628nr Notebook
Press the power button, lights come on then shut off
Press the power button on the laptop, the lights come on for a split second and immediately shuts off. Tried hard resets, removing the battery and connecting just the ac cord. No luck. Received a error code, 0x0000005c
ebenezer
  • 25 Answers
SOURCE: nc6320 Laptop power
hello the first thing to make sure of is that the ac adaptor cable is not having any partial contacts ofany kind whereby power gets into the laptop irregularly.this could have adverse effect on the circuitry. it is not enough just checking the output of the ac adapter by a meter.try straighten the cable from the adapter and check the meter for voltage fluctuations. if the above is okay then the problem could be on board leve.
Posted on Aug 11, 2007
  • 50 Answers
SOURCE: Laptop HP Pavillion zd7000 (model zd7058cl) does not turn on
go on www.hp.com and contact them
Posted on Dec 23, 2008
tat4u
  • 520 Answers
SOURCE: HP Pavilion zd8000 don't startup
remove battery plug in power cable boot up.. nothing may seem to happen but wait a minute or so then press and hold power button down until power light goes out then release button .
try to reboot now.
Posted on Jan 28, 2009
mraviteja
  • 51 Answers
SOURCE: dv2120us keyboard buttons light but screen black, won't boot
Hello Atty
I understand that your Notebook is not powering on. Your Notebooks , that is dv2120us is having a manufacturing defect. So HP accepted that the Notebook will be serviced under the plan "One Time Service Enhancement" . Even if the Notebook is out of warranty your Notebook may be serviced. For more information log on to the chat support .
.http://welcome.hp.com/country/us/en/contact/chat_1.html
They will assist you with the details and the procedure, how to send your Notebook to HP for service.
Posted on Feb 16, 2009
TechyDrood
  • 2072 Answers
SOURCE: pavilion dv7 starts up then shuts down
This sounds like you have a bad DC jack on your motherboard. This is one of the most common problems with laptops and can be caused by jarring the DC plug in or hitting it into something or simply from normal use. As a result the pins on the DC jack become loose and consequently do not provide a charge to the laptop and battery. Wiggling the plug can make the loose pins contact sometimes which would explain why it "sometimes" works when you unplug it and plug it back in. Of course if this is the case then your battery is mostly out of power and that is why it powers off after a couple seconds. This repair costs between $150-300 from a professional repair shop and I would not recommend trying it yourself unless you've had experience soldering DC jacks
Another issue could be the CPU fan/heat skin if this is failing or the CPU is overheating the laptop will power off.
Please comment if you need further assistance
Posted on Nov 21, 2009
My HP laptop restarts when I try to shut it down
Try checking if your power button is defective. Check if it's stuck.
Dec 20, 2012 | Computers & Internet
Sony PCG 2F8L won't start
USE IT WITHOUT THE BATTERY AND REPLACE THE BUTTON
Mar 24, 2012 | Computers & Internet
Water damaged Laptop
Attaching an external keyboard does not help because the keyboard controller is damaged.
I recommend you put your money towards a new laptop as the cost of repair maybe too expensive or beyond repair. Most computer repair shop charge for a quote and may drop this charge if you go ahead with the repair.
If the hard disk is OK then I suggest you remove it from the laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive for backups and data transfer etc.
Mar 04, 2012 | Toshiba Satellite C650 series C655S9520D
Hi: My Aspire 4710Z was not shutting down properly. I pulled out the battery to turn it of. Now, when I put back the battery after few hours, there is no power in my Lap top. Screen is black and now...
Remove the battery and the AC adapter from the laptop.
Press and hold the power button for 60 seconds then let go
Plug the AC adapter only back into the laptop
Now press the power button on the laptop
If it now boots properly shut down the laptop and insert the battery
Now push the power button again
If it now fails you may have a bad battery
Mar 05, 2011 | Computers & Internet
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
Shut down in sleepmode by mistake, how to awaken?
Press enter twice or press power button to awake.
Thanks,
satheesh
Jan 20, 2011 | Computers & Internet
Can not get the power button to shut down the computer no matter how long I hold it down and the computer appears to stay in hibernation. Will not reboot or do anything when power is applied and power...
Remove the battery and leave off for about 1 minute. Put the battery back in place and press the power button to turn the unit on. immediately after you see system light come on, press and hold the power button and see if it shuts off after a few seconds. If not, then its likely your motherboard is defective.
Sep 07, 2010 | Toshiba Satellite M100 Notebook
My Acer LCD Monitor AL1707A goes blank after 2 seconds
Try this,
When laptop on booting immediately press del.
And the screen will run normally.
But if the screen is still white, force to press power button soon.
And it will shutting down.
After shutting down, repeat this action.
It will work.
Vincent-Jember
Nov 05, 2009 | Acer Computers & Internet
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
Laptop power light is on, wont shut off and screen is blck
You could shut down your by forced shut down. to do this, press and hold the power button for 5 seconds, during which a long beep is heard. The system will shut down.
Try reinstalling the operating system to resolve this problem
May 13, 2008 | Dell Latitude D600 Notebook
HP Pavilion dv9628nr Notebook Logo
18 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
