Dryer will not turn off once it gets to the stop position (all cycles). At the same time, it stopped drying. Cool air only.
  • paireyes Jun 23, 2009
    My solution does not seem to be correct. I posed a question about a Whirlpool Dryer, not washing machine.
    In all cycles, the knob moves, but it will not stop once it gets to the end. At the same time, it stopped heating as well.
    Are you talking about a heating element? I am sitting here with a handyman and he does not know what you saying.
  • 530 Answers
Friend the problem is in the circuit connections. heater filament that produces hot is air is broken or disconnected or short circuited thats why you need to check the circuit connections.
Posted on Jun 23, 2009
  • 520 Answers
The main control knob " cycle timer "is bad, and needs to be replaced.
  • 250 Answers
Its probably got something to do with the electronic circuit of the front panel
i would advice you to get it replaced
show a mechanic
let him examine it
replacing the front panel might be the best thing
it probably happened due to switching off the dryer during spin
dont do that
let it complete the whole cycle
My dryer does not blow hot and will not shut off and no digital reading will display.
Hello Bryan;
My name is Peter. I am a retired field service appliance technician.
So, here are the probable causes:
1.) The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may be plugged up or not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft. Check the blower hot air discharge manifold for blockage.
2a.) If the dryer won't stop, the gas valve solenoid coils might be defective. Over time these coils will fail, causing the burner to run intermittently. If the dryer is not heating properly it may not stop. Replace the coils as a set.
2.b) The heating element warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element isn't working - which greatly increases the drying time. Check the heating element for continuity.
3.) Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
4.) Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or shorted
5.) If the dryer won't stop, check the high limit thermostat. If defective, the high limit thermostat can turn off the heat prematurely, lengthening the time it takes to dry a full load. This is not common.
6.) The cycling thermostat regulates the temperature of the air in the dryer. If the dryer won't stop, it may be caused by a defective cycling thermostat turning off the heat too early. This is not common.
7.) The thermistor senses the temperature of the air in the dryer and cycles the heat on and off. If the dryer won't stop, the thermistor may be defective. This is not common.
Nov 16, 2014 | Dryers
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
My dryer is a whirlpool electric dryer that was brand new in 1998. The dryer was on, working fine...suddenly it just stopped. It was making a clicking noise. It refused to cut back on when I pushed the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Whirlpool GEW9250 Electric Dryer
The dryer stops after about 15+ seconds.
No, but mine started doing the same thing today. Did it once before and same- started working again. Any suggestions for last poster and myself?
May 31, 2010 | Frigidaire AGQ6000ES Gas Dryer
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
