Question about Maytag MED6400TQ Electric Dryer
Dryer won't start cycle, stays on sensing
I set everything and click start, it goes to sensing and the drum turns a few times with a loud noise then stops. Stays on sensing, timer will go down but thats it. I just changed the plug from a 4 prong to a 3 prong to fit our socket and I bought it used
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
It sounds like the pullies (drum guides ) need attention the motor is having trouble rotating cause of pressure of not being balanced ,
Posted on Jun 01, 2014
  • 2920 Answers
SOURCE: Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Posted on Jan 29, 2009
jumptrout51
  • 3361 Answers
SOURCE: 4 prong outlet - 3 prong plug :(
Change the dryer plug to a 4 terminal plug.
Posted on Mar 15, 2009
jsrock516
  • 5911 Answers
SOURCE: Can you tell me how to hookup the three wires of 3
The following link explains how to connect a power cord to your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Now keep in mind, some newer appliances REQUIRE a 4-prong plug in order to work properly. You may consider having a four-prong outlet installed to accomodate your dryer.
You can try these steps by referring to to section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, please let me know. I hope this helps you.
Posted on Jul 06, 2009
Controlfrk
  • 304 Answers
SOURCE: need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Posted on Oct 04, 2009
  • 112 Answers
SOURCE: Changing a 3 prong plug into a regular outlet plug.
NO. YOU HAVE AN ELECTRIC DRIER--THAT REQUIRES A 220 VOLT OUTLET. THE REGULAR OUTLET LIKE A LAMP WOULD PLUG INTO IS A 110 VOLT. IF ALL YOU HAVE IS A 110V OUTLET BACK THERE THEN YOU NEED A GAS DRYER OR HAVE AN ELECTRICTIAN RUN 220V FOR YOUR DRYER.
Posted on Nov 03, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Hi i have a novotronic T560C there is a loud noise that starts after a few mins and moisture on the drum door when I put in dry clothes
Buzzer sounds when the drum turns during the
intermittent anti-crease action period. When the programmable switch is set on the following settings: Normal+, Normal, Hand iron
Refer to page 4 of the user's / owner's manual
Dec 03, 2013 | Dryers
An extra loud noise starts when drying
In all likelihood the belt that turns the drum is frayed. and may need replacing. It would be a good idea to unplug it and take a good look at the belt before it comes completely off, this way there won't be any confusion about how the new one goes on.The only moving parts when it is in operation is, the drum, belt and a very small wheel on which the belt travels.
Dec 03, 2013 | Miele Novotronic T220 Electric Dryer
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
When the dryer starts it makes a quick grinding noise like it is having trouble starting. After only 1 second that noise goes away and the dryer appears to be working fine. It will stay running anywhere...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 09, 2011 | Whirlpool LER4634J Electric Dryer
DRYER IS MAKING A CONSISTENT BANGING NOISE WHEN RUNNING. DRUM IS TURNING AND DRYER DOES DRY OK.
There are several things that can cause a dryer to be noisy. There are a lot of moving parts in a dryer that can cause noises to occur when they get worn. Several parts support the drum, and may make noise or vibrations when worn out. Many times a dryer will squeak just a little bit as it first starts. This should go away in just a few seconds. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks. The blower wheel is always moving and lint is constantly going by it. If it’s noisy, it may have gotten clogged with lint, or it may be worn and need to be replaced. Clean out the area around the blower. If it’s still noisy, replace it.
Many dryers use a center spindle to support the clothes drum. This spindle may be a ball-and-socket support, or it may be a shaft inside a sleeve. When these component bearings get worn out, they may make a squealing or rubbing sound. Replace this bearing when it gets worn out. Many dryers also use plastic glides in the front end of the clothes drum. When these glides are worn out, you may hear a lot of noise. If the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these rollers or wheels are worn out, they can be extremely noisy. You ought to replace the whole set at the same time. A belt that has been damaged or frayed may make a thumping or slapping sound as the drum turns.
The gas valve solenoid will make a buzz type of sound as it opens. The valve itself will give a little click as it starts the heat cycle, when ignition begins, and when the burner is turning off. The burner flame itself makes kind of a low-pitched roaring wind sound.
Thanks for using Fixya.
May 28, 2009 | Frigidaire Dryers
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Maytag MED6400TQ Electric Dryer Logo
96 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
