Question about Sharp Aquos LC-20B2U 20 in. LCD Television
Aoc 32in inside fuse - Sharp Aquos LC-20B2U 20 in. LCD Television
    Top Expert:
  • Sharp Master
  • 74,136 Answers
What do you know more about the fuse? If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Posted on May 14, 2014
How to reset my 32in aoc tv
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 12, 2016 | AOC Televison & Video
I have a AOC 177sa-1 Monitor with a bad light bulb where can I buy a replacement so I can get it fix
WWW.LCDPARTS.NET
Are you sure that the lamps are bad, very delicate repair works.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed AOC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 16, 2011 | AOC 177SA-1 (BLACK) Monitor
I have an AOC 19MVWk monitor with a flashing blue power light and the screen isn't on. What does this light indicate? Thanks
It does the same when attached to another PC? It may be indicating that it is in safety shutdown/restart mode due to shorted or failed circuits in the power supply due to bad caps or in the backlights inverter circuits, you need to open it up and inspect the inside and circuits.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Mar 15, 2011 | AOC 19LVWK LCD Monitor
My AOC 2019Sw1 - 20" LCD monitor is not working.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Jan 31, 2011 | AOC 2019SW1 20" Monitor
Turns on with low unstable video, then display blanks out shuts down.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Basic LCD monitor troubleshooting guide:
Dec 01, 2010 | AOC LM740 (Black) 17 in. Flat Panel LCD...
Backlight inverter aoc lm729 Schematic diagram Please I am a repair technician (Retired) Lcd layer working picture on screen backlight goes off intermittently and now for almost all of time. Flashes...
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=AOC%20&megnev2=LM729%20&kategoria=&kat2=all
You will need test lamp to verify if it is the inverter or the lamp assemblies.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Sep 09, 2010 | AOC LM729 17" LCD Monitor
No display of monitor AOC!
Power suppply will be the first place to look, look for caps with leaking/bulging tops.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 29, 2010 | AOC 193FW LCD Monitor
My aoc monitor goes on and off..
When you are trying to do DIY repair, first place to check will be the power supply section. Make and model will help also.
May 28, 2010 | AOC Monitor
Aoc monitor shut off by itself
If the screen just goes black, more likely to be the problem inside the monitor, if you decide to DIY repair, please read below and go to my pictures so you will get some ideas what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 19, 2010 | AOC LCD Monitor
Need schematic diagram for AOC 5 En model (white 15 inches color monitor) - thank's
my AOC crt monitor 5En model has this problem. it has over width the compress button (<> ) is no longer functioning what particular component should i check or adjust inside the circuit? please i need ur help..
Nov 21, 2009 | AOC 5 En 15" CRT Monitor
Sharp Aquos LC-20B2U 20 in. LCD Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
