Question about Lexmark X5470 All-In-One InkJet Printer
My lexmark 5470 will not print.the usb cord is attached to my laptop. the printer is on and ready but, its not printing...help! if I turn my printer off then back on it will print the jobs that I wanted.
  • 27 Answers
Change the ca,ble (USB) and see the effect. If it does not work, reinstall the printer, Before the check if the printer is working offline by going through the control panel and clicking on printers and then view printers. Right click on yours and click on properties
Posted on Jun 23, 2009
Why won't my printer print after I installed the software? It says its ready but nothing will print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
I have a lexmark x63 and everytime i try to print something it says the device is busy try again later. i click on the printing icon that pops up in the bottom right hand corner of my screen and there is...
hi Cavschick104.
this is all i could find out.
COMPLETELY uninstall the printer and
reinstall it..... It may have occurred if you have your printer connected
during the installation of XP.... it is normal practice to keep the printer
disconnected during an upgrade or clean install.... and then correctly
install it afterwards.
This from the Lexmark site:
Remove the USB cord and the power cord from the back of the printer, and then remove
the USB cord from the back of the computer.
Uninstall the printer/scanner software from the Program menu and restart the system.
Check the part number on the setup CD. If it is not P/N 13H0350, you need to download
the XP driver from the Lexmark web site, www.lexmark.com.
When the PC has restarted, log in as an administrator and insert the setup CD into
the CD-ROM drive
Click OK and Install now.
Follow the setup instructions to install the scanner software. When you see Connect
the USB Cable to the printer on the screen, first attach the power cord to the
printer, then attach the USB cord to the printer, and finally attach the USB cord to
the computer.
Follow the setup instructions on the screen to complete the printer software
installation.
If you want technical support of Lexmark, you can contact us on Lexmark Printer Support 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/bpBgcR
Lexmark Printer 1 866 877 0191 Help Support Service...
Nov 27, 2017 | Lexmark X63 InkJet Printer
My lexmark X4650 gives me a message that the network printer is busy when I try to print wirelessly. There is no other computer trying to print.
Make sure there are no print jobs stuck in the queue then unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging it back in. When the printer's ready, try printing again. If the problem persists, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 14, 2010 | Lexmark X4650 InkJet Printer
Problem with USB cord, but the usb cord fits in printer and laptop fine. Computer screen says Printer ready, but when I try to print a message says check USB cord. Don't understand
Try using another USB port if you have one. If the others are full, disconnect one of your devices from the USB port and try your printer there. For some reason, switching the USB port sometimes makes devices connect. Good luck!
Mar 13, 2010 | Lexmark X2600 InkJet Printer
Lexmark -5470 prints to small- with my new Dell Inspiron -1525 .
check your printer settings the computer is not at fault here did you reduce the zoom i mean did you zoom out too much put it. go to print preview and then put the zoom to 175% and try. see if this workks
Mar 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Drivers for Lexmark x5470 disapear after the laptop is turned on.
Hey,
Fully uninstall the lexmark from your computer, everything, delete the printer from printers and faxes and make sure there is no trace of the printer on the computer.
Then get the files you downloaded and install the printer again.
Everything should work normally.
Thanks,
Ekse
Feb 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lost my cd to install lexmark 5470 need to download to install my printer
Hi you can download the lexmark software from
www.lexmark.com When you open the page, look at the right side where it says drivers and downloads. Click on it and then select driver finder from the list.
On the driver finder page enter your 5470 model into the search field, is it X5470? well try x5470 or 5470 if it says just 5470.
Anyway all the lexmark drivers are there you just need to find your printer from there, then select your windows version and download. Finaly install the software and happy printing.
Nov 17, 2008 | Office Equipment & Supplies
Print server thinks printer is offline
This printer works only with selected printer and they do not work with other print sever to know the print server which they work please click on this link and then click
Hide/Show Additional Results
http://search.lexmark.com/printer/US/en/22N5000
This server will cost $149 instead you can buy wireless Lexmark printer X6570 at the same price,
Good luck..................
Jun 21, 2008 | Lexmark X5470 All-In-One InkJet Printer
Unable to print
sounds like a dogy usb cable try a nother usb cable before you give up
Feb 07, 2008 | Lexmark Z600 InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
109 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
