Question about Craftsman Garden
How to open a stuck oil filler cap lawnmower craftsman
2 Suggested Answers
  • 2239 Answers
SOURCE: oil coming from my oil filler tube craftsman mower model 917-376572
There will be an o ring on the bottom of the dip stick tube to seal it to the crankcase, i think this is leaking due to age or has split, remove the screw securing the tube remove it and replace the o ring.
Posted on Oct 09, 2012
Model 917297140 does it need gear oil in white filler cap and motor oil in yellow filler caps
Type "Craftsman 917297140 User Manual" in your search engine and it will show sites for manual. The manual should be able to help you.
May 19, 2016 | Craftsman Garden
Lawnmower hardly running after I cleaned it by tipping it on its side. I noticed oil dripping. If I open the oil filler cap it starts to run properly but with oil cap open oil spits out everywhere.Briggs...
Tipping the machine on its side can allow engine oil to enter the air filter box via the engine breather, this will then soak the paper element air filter, you will need to remove and replace the filter.
Sep 23, 2013 | Briggs & Stratton Garden
I have a briggs & stratton riding lawnmower it cuts for about 30min, then cuts off and wont start untilit cools off
Slacken off the filler cap when it starts to die, if it picks up again then it could be a blocked tank breather, it could also be an ignition coil breaking down with the heat
Apr 13, 2012 | Craftsman Garden
Where is the oil drain plug
The drain plug on a Briggs and Stratton engine is underneath the deck. Most likely it is concealed by cover for the self propel belt and possibly the blade as well.
The suggested method for draining the oil is to warm up the engine by running the unit for 10 minutes or more, though this should be sufficient time for the engine to have warmed up. Then drain the oil.
An alternate method is to drain the oil out of the oil filler tube. To do this, after the engine is warmed up, tilt the mower onto the side that has the oil filler tube. Put the drain pan under the filler tube, then remove the filler cap. The oil will drain out into the oil drain pan.
CAUTION: The oil that will come out of the engine will be HOT! So be careful when removing the oil filler cap.
I hope this will answer your question. Best of luck in this mowing season.
Apr 04, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Where is the oil plug underneath the mower?
Depending on what engine is on your Toro lawnmower, there may not be a oil plug under the mower deck. A briggs and stratton engine will have one, but if the unit has self propel then you will have to move the guard over the self propel cable. This is a 1/2 in bolt, you will also have to loosen the other bolt to swing the guard around.
On a Kawasaki or Honda, and even if you have a Tecumseh engine then just start the mower up for a few minutes and let the engine oil get warm, then shut the engine off and then lay the mower on the side that has the oil filler cap and put your drain pan under the oil filler cap. You can then drain the oil out of the oil filler tube. You can also do this with the briggs and stratton engine. I find this to be a very convenient way to change the oil.
Then put fresh oil back in the unit. I always suggest to put the engine manufacturer's oil back in the unit, or if that is not available then use another oil from another engine manufacturer. IF you use automotive oil, the oil will break down faster since the heat level for the engine on car is less than that of the engine on your lawnmower. The engine has a water cooled design, that keeps the engine temperature from raising over about 250 degrees F. The engine temp on your lawnmower can get as hot as 400 degrees F in the summer heat and being run for 30 minutes or longer.
A longer answer than you had hoped but I hope the information keeps your lawnmower running well for many summers to come. :)
Apr 04, 2011 | Toro Power Lawn Mower
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a Mountfield HP474 lawnmower. We cannot locate the sump plug to drain the oil. Please could you advise. Many Thanks Gavin
According to the operators manual there is no sump plug, instead you "dump" the oil out using the oil fill.
Below is step by step instructions copied from the Operators manual:
Drain oil while the engine is warm being careful not to touch the hot engine nor drained oil
a) Place engine level
b) Clean around oil fill
c) Remove filler cap
d) Have a container ready to collect the oil
e) Tip the lawnmower on its left side so that the oil will drain from the oil fill
f) Place the lawnmower level and top up with new oil
g) Check the oil level on the dipstick
Oil should be at "MAX" mark
h) Close the filler cap and wipe off any spilled oil
NOTE: The oil capacity is about 0.6 liter
Sep 20, 2009 | Garden
I h ave a Craftsman Push Lawnmower 917.387205 and cant find where
Not very many are the type you need to add oil to gas, on the mower look for a small cap at the bottom base of the mower's engine you may need a pair of pliers to turn it counter clockwise to remove don;t add too much just about one cup shoul do it. if you can't find it then it may be the typr with the screw on cap that is higher up look for a knob at the top part of the mowwe rthere is only two and there should be some type of writing either the type of oil or the word oil filler on it.
Jul 15, 2009 | Garden
Craftsman 2.3 14" / Poulan 1800 auto oiler leaking
Loosten the oil filler cap before putting it away. The tank is pressurized to force oil to the chain. Relieve the pressure before storing. Lou
Jun 05, 2009 | Poulan 1630 16" Chain Saw
Garden Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
