Need wiring diagram for run capacitor for model CPLE36-1
  • 306 Answers
SOURCE: model#SRCF30U01D. Serial#920-629-3049.
Are the wires going to capacitor correct. You have two sides to the capacitor one side is compressor or herm as stated on top the fan. should have one wire only on fan side then two wires to the common side and one wire to herm side. trace out the wires I'm sure it's electrical and make sure you can see that it does in fact have a dual capacitor. Turn off all electrical supply before even touching this as you are around some big voltage. I do this everyday and I won't even get close unless I pull the safety disconnect on the side of the house. Get back to me and can help further. Ken
Posted on Aug 22, 2009
  • 415 Answers
SOURCE: need a wiring diagram for capacitor on carrier ac
Here's your wiring diagram. :-)
Posted on Apr 02, 2010
  • 82 Answers
see page 2 here...the drawing section with H (hermetic compressor) F (fan) and C (common. -- http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/38en-1w.pdf
Posted on May 10, 2010
wise_jf
  • 66 Answers
SOURCE: NEED WIRING INSTRUCTION FOR CAPACITOR FOR
On top of the capacitor you will find the terminals marked. One will say C, or Com. The others will be marked fan and herm. There will be a hot wire going to C. Usually this comes of the top of the contactor and is red. Find the wire that runs to the compressor. It will likely be yellow. This will hook to the Herm. Next find the fan wire (probably brown) it will hook to the fan. Hope this helps.
Posted on Jul 14, 2010
shastalaker7
  • 1515 Answers
SOURCE: wiring diagram worn off outdoor ac unit,capacitor
Hi, if the first 35 uf run cap shorted, you most likely have a shorted to ground compressor. This is what causes them to burn out.A 35uf, x 440 volt run cap is for the compressor only. You should or will have a smaller one for the out door fan.1 lead from the contactor feeds one side of the capacitor, energizes it. The S wire also plugs into that same terminal. Then the R or run wire from the compressor, and C will go to the other side to start it. The 2 left ove have to be commons to feed other componants, you will need to follow them to see, as I can't pull up any diagram for that model. You need to have the compressor ohmed out, or checked to see if it is shorted to ground. To do this, remove the 3 wires to the compressor terminal. Make sure the power is off! If you have a voltage tester that has the audio alert for checking fuses and so on, touch the black lead to a clean spot on the compressor of copper line, and tough each one to each terminal. If you get a beep, it is shored to ground, and you will need to replace your compressor. Do this check and let me know.
Shastalaker7
A/C, & Heating contractor
Posted on Jun 06, 2011
I need the wiring diagram for a Nordyne GS3BA-024KA condenser
3 wires for compressor, 3 for fan. 2 comp. wires go to the top of the contactor, the remaining goes to herm terminal on capacitor. 1 fan wire goes to the top LEFT of contactor, remaining 2 go to com and fan on capacitor. You will then have 1 wire left that goes to the com on the capacitor and should go back to the top RIGHT of the contactor. NOTE: IF YOUR FAN MOTOR IS RUNNING BACKWARDS (MEANING AIR IS NOT BLOWING OUT OR UP) swap the to fan motor wires on the capacitor (fan and com) this should reverse rotation. ALWAYS REMEMBER TO TURN POWER OFF AND DISCHARGE CAPACITOR BEFORE TOUCHING WITH INSULATED SCREWDRIVER. Good Luck!
Apr 22, 2017 | Heating & Cooling
Do you have wiring diagram for the capacitors
Why are you replaceing capacitors? If they are "shot" put new back just the way the old were. Mark wires before you remove old. If capacitors are missing I understand the problem. Since you didn't indicate a model, you may find a service manual with wiring diagram here:
http://www.manualslib.com/
Mar 11, 2015 | Heating & Cooling
Capacitor Wiring
I would think you have solvrd this by now but anyway I needed your model number of the unit outside more than the capacitor. Here is a simple diagram.so try to go by location and your colors. Should you have questions I will be here, Thanks Sea Breeze
More Carrier AC Wiring Diagrams
Jun 14, 2013 | Heating & Cooling
How to wire in new hard start
It's very simple to install a 3N1 Supco Hard Start Relay, Some refrigerators have a run capacitor located on compressor or mounted nearby. It will be important that you use the run capacitor in with the 3N1 Hard Start. Here is a Photo of the=> URCO810_3_N_1
The instructions come with the 3N1 Hard Start Relay. Can you please post the model number of your refrigerator here so I can look up a wiring diagram? Look around the fresh food section door frame for your model number. I do need to know so we can get the right run capacitor in the 3N1 hard start circuit, Thanks Sea Breeze
Jan 30, 2013 | GE GSS25LGP Side by Side Refrigerator
Wiring- Connecting wiring on replaced fan motor
Your new fan motor should have a diagram with it or at least printed on the side of the motor, that will help a lot from your end. As for me, I don't know what unit you have, so I will try to help you with just the basics.
Your old motor probably had 3 wires. One went to the contactor, that is the "Line Voltage", one went to the Common terminal on the old capacitor (COM), that's the other "Line Voltage" wire, and the last one went to the "FAN" terminal on the old capacitor. The reason the old capacitor looks different is because it works for both the compressor and the fan motor (split capacitor). You still need this hooked up for the compressor to work.
The new fan motor.
These vary in brands and wiring so I can not tell you the colors without knowing exactly which motor you have. On the new motor wiring diagram, you should see the "Line Voltage" as described above that 2 of the wires are ran to each other (just on the diagram, not wired together on the unit). This is your power wire that goes to the contactor on the unit, usually black, and your Common wire that runs to the capacitor. You can still run this wire (COM) to the common terminal on the old capacitor since you still have to use the old capacitor for the compressor and the common terminal should still be jumper-ed from the contactor to the (COM) terminal. Then you will probably have 2 wires for the new capacitor, usually Brown and Brown/White. These wires run to each side of the new capacitor and doesn't matter which terminal. Then you will take a new jumper wire from the (COM) terminal on the old capacitor to the terminal on the new capacitor that has your Brown/White lead. Make sure you secure the capacitors inside the unit so not to touch anything surrounding them. Your new motor might also be a "Reversible" motor that has reversing wires also. Again, your new motor diagram can tell you how to hook these up. You have to have it spinning the right way, most of the time it is CCW (counter-clockwise).
I'm sorry I can't be any clearer on this, but without knowing the brands, models, etc, I'm in the dark. If you need any additional help, I would be glad to help! Good luck and hope you get to cooler days!
Jun 28, 2012 | Heating & Cooling
Wiring diagram worn off outdoor ac unit,capacitor burned up got replacement part fixed all burned up ends keeps shorting out,carrier model 38RE042300,capacitor that burned up35/UF motor run capacitor +-5%...
Shastalaker7
Jun 06, 2011 | Heating & Cooling
All three of my capacitors blew in my IR T30. I failed to diagram the wiring. There are two start capacitors and one run cap. There are two white and two black wires from the motor. Does anyone know...
Hi, my name is John. Welcome to FixYa. Both of the black wires go to the + side on each capacitors, and the white wires go to the - side of the capacitors. Thanks For choosing FixYa...John
Nov 29, 2010 | Ingersoll Rand - Rand Type - 30...
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
What terminal on the capacitor gets the blue wire from the run terminal on the compressor? Does it go in the terminal with the white wire or the blue wire?
Follow the start wire from the compressor to the capacitor, the run wire will go to the opposite side.
For instance if the white wire is the start wire on your compressor then the run wire will go to blue wire and vice versa.
Apr 14, 2009 | Fedders A7DH45B2A Dehumidifier
Need wiring diagram for Ruud Model UPCA-048jas
The wiring on these is pretty straight forward
Basically a contactor, either DPST or DPDT, depending. Input power connects here.
Compressor C terminal connects to one side. R terminal connects to the other. 1 terminal of the run capacitor connects to the terminal with the R terminal of compressor. The other side of run capacitor hooks to S terminal of compressor. One wire of condensor fan hooks with compressor R terminal, the other condensor fan lead hooks with compressor C terminal.
Only things missing from all this is a hard start kit and crankcase heater. Let me know if you want to know how to hook those up.
Jan 29, 2009 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
