Question about Bosch Dishwashers
My model is sgv5303gb/19 my machine turns on but no display comes up .
My machine turns on but timer display of cycle doesnt show so dishwasher doesnt work what do you think is wrong?
catriver
  • 878 Answers
SOURCE: dishwasher drain solenoid
Snoopy, first of all you did a good thing when you ordered the timer. I have got stung on this model by just changing the solenoid. The fact is the timer is stalling and sending too much voltage to the solenoid and burning it up. Just order the new solenoid and install it. The solenoid is a AC circuit so it doesn't matter which way the harness is on, you should be just fine with the new timer..Catriver..post back.
Posted on Mar 05, 2007
  • 51 Answers
SOURCE: Dishwasher not completing cycles
Is the water being heated??? When the timer reaches the stage where it will not move forward any further, after 5 minutes or so, open the door & see if the water is heating up. The timer often waits for the water to reach the correct temperature. Temp is measured by the thermostat. If the element tests OK, then it could be the relay that switches the element. The relay is turned on & off by the timer. I would say that if the timer is OK & the element has the correct resistance, then it is is more likely to be the relay. Last resort would be the thermostat, but my money is on the relay.
Posted on Aug 01, 2007
  • 1314 Answers
SOURCE: Timer on dishwasher not working
ok start the washer after it fills and starts washing open the door again and turn the dial to drain shut the door see if it drains if it does then open the door and turn it to heated dry shut the door and get you a small glass of warm water let it sit in heated dry for about 3 minutes open the door and pour the water on the heating element and let me know if it sizzles
Posted on Mar 27, 2008
garing
  • 998 Answers
SOURCE: no water entering the machine
be sure flood control float is in place ..under rack..check flood control switch under bottom of dishwasher...check inlet valve and timer
thumbs up
Posted on Aug 17, 2009
Krazytech
  • 725 Answers
SOURCE: Bosch dishwasher model: SGS56E02 will not complete a cycle.
Hi, The dishwasher must get to 70c to advance thru the heating cycle.. check to see if the heater is coming on( lots of steam coming out when you open the door )..not getting hot then you could have a heater problem. if you are getting hot then you have a Thermo ... the thermo holds the the dishwasher until the temp reaches 70c before it will let it go into the next cycle...the thermo is under the dishwasher at the right side, white with two wires .. it screws into the tub...hope it helps it not let me know and I can help you more...
Posted on Sep 29, 2009
Our Kenmore dishwasher model number 665.13163K701 display is always showing the heater cycle indicator on. Tried some reset instructions I found online and turned off breaker for a few minutes and still...
please follow the next steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. 87af5b68-272e-404a-951c-cd453d3cd7fe.jpg
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic control
Jul 06, 2013 | Dishwashers
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
My model number is FDB1500LFSO, my dishwasher quit...
Is there power to the dishwasher? Electricaly ground dishwasher. Connect ground wire to green ground connector in terminal box. Do not use an extension cord. Failure to follow these instructions can result in death,fire or electric shock.
Press and hold the Heated Dry option (button with lock icon) for five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
If these tips did not work or your controls are not working correctly you may need to schedule service.
May 17, 2010 | Dishwashers
1991 model 665.1691591 shows cycle and options on display but when you push start just beeps twice and does nothing. When you push cancel/drain it shows two minutes on the display and does nothing. Tried...
My 665.1691591 was exhibiting EXACTLY the same symptoms. It was a bad door switch. This machine is a bit unusual in that it has 3 door micro switches.
Whirlpool part number 431823 repaired my machine. It comes with illustrated directions.
Nov 26, 2009 | Kenmore Dishwashers
Dishwasher won't start, turns on but no display
1: Defective door lock switch
2: Defective electronic control board.
Get model and serial number of machine, enter model number on search engine and seek same like conditions. You should find solution to problem, or place model number here for me to correctly tell what is wrong.
Oct 01, 2009 | Dishwashers
Sep 27, 2009 | Bosch Dishwashers
Cycle doesnt stop
STUCK TIMER MANUALLY ADVANCE TIMER THEY HAVE NOT MADE THE SMU MACHINE FOR OVER 12 YRS MIGHT BE TIME TO REPLACE MACHINE OR GET A QUALIFIED TECH TO LOOK AT
Jul 20, 2009 | Bosch Dishwashers
Matsui mf160 starts its wash cycle and timer stops
on most machines, the timer will not run if the water is not up to temp. if the inside is plenty hot mid-cycle, then your heating element is probably good. it is the thermometer that needs located and checked. if the inside is not steamy, then your heating element is the most likely culprit.
don't hate your dishwasher. it just wants to make sure that you get a full wash cycle at a hot enough temp. to get the dishes clean. good luck
Jul 06, 2009 | Neff 24 in. S5543X2 Built-in Dishwasher
Touchpad--No Response
The "2H" is an error code indicating the control panel needs to be replaced.
May 08, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
