Question about Boating
1992 evinrude 60hp boat motor
I'm not shure if I'm in the wright place to ask about my problem with my 60 hr evinrude. I'm removing the eng from the foot I've got them split about 1/4 inch apart & the eng. want come apart any more is there something I need to remove still have I misted something
    Sergeant:
  • 456 Answers
Have you disconnected gearshift rod ? 7/16th bolt under bottom carb
Posted on May 13, 2014
  • 23 Answers
SOURCE: Can not lower the motor manually
There is a screw usally on the right side looking at back of motor use large screw driver loosen motor will come down I guess you have trim and tilt
Posted on Jun 19, 2009
  • 5537 Answers
SOURCE: 1975 75 hp evinrude water in lower unit
You could take off the lower unit and leave the boat home. All they need is the bottom. The propshaft seal can be cut from fishing line. There should be another seal on the shift assembly and a third on the powershaft. Some you could do, but the shop can pressure test before and replace only what you need. Then pressure test after the repair to verify it seals.
Posted on Jul 20, 2009
SOURCE: 20 hp evinrude boat motor will not start
broke key off of ignition trying to jump over, can't find wire to keep motor running, will start, but not stay running cause wired to toggle switch. can u help, please thanks, wayne (20hp johnson/evinrude
Posted on Nov 08, 2009
agent91
  • 2100 Answers
SOURCE: how to remove starter from 1983 30hp evinrude OMC
I just read up on the removal of your carb, It says to remove the flywheel to get more room, and then the carb, the left side bolt is harder to get to but it can be done. Only get 1/6 turn of the wrench, remove the fuel line, and be careful not to lose any throttle parts. Hope this helps.
Posted on Apr 15, 2010
Testimonial: "The main problem is NOT knowing how to remove the starter. Thanks in advance, Wayne"
  • 45245 Answers
SOURCE: How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Posted on Apr 25, 2010
Need yr for evinrude E8RLNR
Bruce,
Do you have the serial number of the motor? Reason I ask is twofold. Evinrude started using this model number layout as of 1980. Having said this, something is not making sense with the location of the "N" in your model number. Those last two letters as of 1980 are the year. Here is the chart. Letter on top with corresponding year below it.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
So... Example
1980= CS
1990= ES
2000= SS
2010= IS
You have E8RLNR which breaks down as:
E= Evinrude
8= 8hp
R= Rope start tiller steering
L= 20" shaft
N= 2nd year
R= 4th year
I would expect to see the N in the last spot:
1982= CN
1992= EN
etc.
Serial number is another way to identify the year.
This may hep point you in the right direction. Hope it helps.
marineengine.com/parts/engine-model-guides/omc-johnson-evinrude-model-number-guide/omc-johnson-evinrude-model-number-guide-00004.html
Regards,
Fred
Sep 26, 2016 | Light Outboard Motor Boat Bass Fishing...
Identifying this outboard motor from evinrude, AQABVA71K899
Rob, AQABVA71K899 does not seem to come up as a valid # for referencing engine. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Outboard Engine Serial Number Year Match up
Evinrude Outboard Motor Model Numbers
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE 1913 1979 MASTERTECH MARINE
Jul 11, 2016 | Boating
What sparkplugs go in a 92 60hp twostroke evinrude
I'd ring your local dealer he should help or email evinrude direct?
good luck.........
Sep 17, 2015 | Boating
What would cause water to leak into the upper partof a 1992 evinrude 48spl outboard boat motor
I Presume You Are Talking About Water In The Combustion Chamber.
If So The Head Gaskets Or Water Jacket Gaskets Are Corroded By The Salt Water.
Replace Gaskets.
Aug 18, 2013 | Light Outboard Motor Boat Bass Fishing...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 | Boating
Boating Logo
79 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
