Question about Sony KDF-E50A10 50 in. LCD HDTV
Kdf-e50a10 dark picture - Sony KDF-E50A10 50 in. LCD HDTV
SOURCE: Sony kdf-e50a10
It is either a lamp sensor problem or a lamp driver problem.
Posted on Oct 13, 2008
mistersony
  • 320 Answers
SOURCE: Sony KDF-E50A10
Replace the lamp, sounds like a weak or old lamp. Use an original Sony, the replacement lamps are unreliable
Posted on Oct 18, 2008
  • 58 Answers
SOURCE: My Sony Wega KDF E50A10 has developed an excess of
Some of these models have this problem from production.
I would recommend to contact SONY and tell them the problem they may be able to fix your TV at no cost, since some of their Light engines have a recall but I'm not sure if your model number is one of those.
If you want to fix the TV yourself you need to replace the light engine and that requires advanced skills for this product
hope that was helpful
thank you
Posted on Apr 25, 2009
  • 197 Answers
SOURCE: Sony Grand wega KDF-E50A10
bad lamp
Posted on Jun 07, 2009
  • 608 Answers
SOURCE: My 50" Sony Wega KDF-E50A10
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 19, 2010
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Sony has a dark picture
the lamp life is coming to an end you need to replace it
Oct 13, 2014 | Sony KDF-E50A10 TV
KDF-E50A10 - hard to see details during dark scenes and a dark bluish tint can be seen in background. When tv is turned off the screen goes black but has bluish tint toward the edges before it all goes...
Hate to tell you this but it sounds like your picture module is going bad. The bluish tint tells me it is leaking to the outside. Some problems with the LCD picture module can be fixed but I never had to fix one. Might check out some videos on repairing LCD picture tubes on YouTube.
Gillight
Dec 03, 2013 | Sony KDF-E50A10 50 in. LCD HDTV
Where can you find the optical engine on a sony KDF E50A10 so you can dust it? Where do you find the projection lens to dust it? Help!
Try to download the repair manual to your set from internet. It has all the details. It is very difficult to include all illustrations about it here by this window.
Jul 22, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
I have a Sony kdf-e50a10 hdtvv that keeps shutting off every 5-6 min. And the picture appears dark.
It may be the lamp which sometimes will dim way down just before it fails-set monitors it and if too dim shuts down.
May 20, 2012 | Sony Televison & Video
How difficult is it to replace the lamp module for a sony KDF-E50A
It is customer replaceable and:
GOOGLE THE MODEL NUMBER WITH REPLACE LAMP AFTER IT.
You Tube may have video instructions based on the exact model number.
Mar 11, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
My sony kdf-e42a10 lcd projection tv has good sound but for some reason the picture has gotten real dark, you can still see it barely, what could be causing this
Cause of darker picture is lamp that has reached at end of its working life span and need to be replaced for brighter picture in tv.
Replace lamp in tv to get problem solved.
Thanks.
Jul 24, 2010 | Sony (XL-2400) Projector Lamp for...
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Loud pop from projection TV, then no screen
Ur power board it dead.Replaced capacitors that puff up or pop open.Or replaced the whole board.
Dec 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 50 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
