Question about Garden
Dewalt dxpw 3025 pressure washer builds up pressure and stalls motor
Bulids up pressure and stalls motor
  • 101 Answers
SOURCE: pressure washer won't build pressure
The problem sounds like its in the handle.. trigger mechinism
Posted on Dec 15, 2008
  • 15 Answers
SOURCE: builds up to much pressure in hose and stalls engine
Sounds like the unloader is not working. try replacing it and see if that helps.
Posted on Apr 23, 2009
  • 942 Answers
SOURCE: My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Good luck
Regards
PCmania
Posted on Jul 05, 2009
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
SOURCE: Ex-Cell EXPRO2530 w/Cat Pump. Pressure builds and stalls engine.
Your unloader valve is not wotking, get a diagram of the pump from cat and it will show what parts you need to replace, or check for blockage in the valve.
Posted on Jan 10, 2011
The machine shuts off when you let off the trigger. Seems like pressure must build up and it shuts off.
Your unloader bypass system has failed. Several pumps were used on this model, see link for parts breakdowns.
Sep 28, 2014 | Dewalt Pressure Washer - DXPW3025
What type of oil do i put in the DPD3100?
In the Pump Dewalt recommends
DeWalt DP70 Pressure Washer Pump OilIn the engine Dewalt Recommends
SAE 10W-30 is recommended for general use
Jun 26, 2011 | Dewalt DPD3100 Gas Pressure Washer
Pressure continues to build then stalls
if te unit builds up pressure then stalls the motor, the unloader isnt working. it bay be corroded or the O ring are U/S
Jul 01, 2010 | Honda 2500 PSI Gas Pressure Washer
Need to know type of oil DeWalt pressure washer 3800psi
Pump is specialty pump oil available at Home Depot. Engine is 10W 30 motor oil.
Mar 16, 2010 | Dewalt 3800 PSI Pressure Washer
Builds up to much pressure in hose and stalls engine
Mar 16, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
