Question about Therapure Four Person Inflatable Round Hot Tub
How do you change the heating element? - Therapure Four Person Inflatable Round Hot Tub
  • 1,631 Answers
Unfortunately, these Toy Spas do not give you the ability to make repairs to their components!
For a failed heater, it appears that you have to replace the complete control center. Because parts are extremely to impossible, to obtain.
Contact them, and do some squeaking, maybe they will oil that squeak?
Look here...
www.intexcorp.com/support
Posted on May 06, 2015
How do I change the heating element on a hoover vhc 691 b tumble dryer?
Many of the heating elements can be seen and changed by laying the dryer on its back...the element is usually visible from the bottom. I found the part on the link I am incuding for you. Hoover VHC 691B80 Dryer Element 2100W
Dec 15, 2014 | Hoover Dryers
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Tip
How to Change the Heating Element in a Electric Dryer?
1) When the clothes are not getting dried but dryeris running. That means the heating element needs to be replaced.
2) First of all unplug the dryer from wall outlet.
3) The heating element is located in the cabinet. Insome models the cabinet is located in rear or in some models its located infront.
4) Remove the screws on the heating element cabinetto reach the heating element.
5) You will see wires connected to the heatingelement terminals.
6) Remove the wires from element using needle noseplier.
7) Then remove the object blocking the heatingelement with the screw driver. But in some models the heating element can be removeddirectly.
8) After removing the object remove the screwsholding the heating element.
9) Theheating will have to be moved a bit to come out easily. Before removing theheating element out. Please note down the position of old heating element. Sowhile placing the new heating element you don’t face any problem.
10) Refit all the parts removed while removing theold heating element properly.
This will help. Thanks.
Change element in a samung dv665j
Usually, one takes the rear cover off revealing the element area. I doubt if the heating element is burned out. Typically the small thermostat or thermal fuse link blows before the heating element goes. You would have to see the diagram of your model online. Most sites have the exploded parts view of that section online. If you don't have a meter tester you may have to replace all 3. Some models have them all tied into 1 board. This site has video troubleshooting. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067262-/Samsung-Dryer-doesn-t-heat-DV665J Samsung Dryer Doesn Heat
Sep 13, 2014 | Samsung Dryers
I have an Amana stove model ART4002W. The oven will not heat above 250 degrees and the broiler element will not turn on. I replaced the broiler element and the heat sensor. No change.
if you have it on broil and the element doesn't heat up and you changed the element then you either have a loose or broken wire or a bad clock assy. part number 74009213 and it's around 166 dollars
Feb 11, 2011 | Amana AER5715QAS Electric Kitchen Range
The heating is not working.changed fuse,still nothing
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 19, 2011 | Heating & Cooling
Oven's bottom heating element does not heat
this should show you how to change it
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
The main fault when the oven is not heating is that the element has blown here is a video on how to change your fan oven element and the motor.
For all your fan oven element click here
Jan 07, 2010 | Frigidaire Ovens
Not getting any heat in my dryer.
mam if the drum is rotating and not getting heat then the problem will be in the heating element please change the element.before changing please check the power supply across the element terminals.
Sep 11, 2009 | Dryers
Hotpoint tdl52 no heat, element changed, but still will not heat
Check your all fuses that are suppose to protect your element. should have a high and low limit fuse
Aug 23, 2009 | Dryers
HEating element
The heating element is located in the bottom left corner. You will need to remove the drum for access. Once you have the drum out of the way, look for a square box with wires attached. There are 10mm fasteners that hold the heating element to the vent. Rome the screws, mark the wires and positions then remove the heating element. Before replacing the element make sure the thermal fuse and the high limit switches are not faulty.
Jan 10, 2008 | Amana DLE330RAW Electric Dryer
Therapure Four Person Inflatable Round Hot Tub Logo
247 people viewed this question
Top Therapure Pool & Spa Experts
Raymond Richards
Raymond Richards
David Harrelson
David Harrelson
J.D. Browning
J.D. Browning
Are you a Therapure Pool and Spa Expert? Answer questions, earn points and help others
